Question about Dishwashers
The dish washer draining pump keeps going and water dose not come on
    Scholar:
  • 59 Answers
Tmachine is probably in flood sense mode. Tip it forward onto a towel and see if water runs out from the base. If so be careful not to flood the house, but empty the base carefully and run the machine. Check that it does not overfill again if it does there may be a sensor or water valve proble. Good luck
Posted on Sep 07, 2010
Kenmore model 970c44102 front load will not drain while spinning
sound's like the water pump is going out I got a old washer and it dose the same
Sep 15, 2012 | Kenmore 98702 Stacked Washer/Dryer
What dose oe mean on the display and it makes a grinding noise when it drains the water i think
Drain error: Not fully drained in 10 minutes. Causes: Drain hose too high. objects in pump, drain hose kinked, drain hose air locked, bad control.
Jan 27, 2010 | LG WM-2277HW Front Load Washer
Dish washer runs and drains water only. I turn it on and you can here the drain pump running. But it just keeps trying to drain ut won't go into the fill cycle
it sounds like the re-lay switch on the pump is stuck and therefore only pumping inthe one direction.
some pumps come with re-lay switch built-in and orthers with it seprate less hassel not built -in.
P
Aug 07, 2009 | Dishwashers
Water wont drain after wash!! Dishes wont dry all the way also
HI, usually, if the dishwasher dose not drain properly, it will be the fault of a defective or, malfunctioning pump. i will list several problem areas to check. Inspect each area properly and, replace any component that is faulty or fouled.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/control board
Replace if defective (note: uncommon problem).
Jun 17, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Dish washer wont drain
HI. check the following areas for faults.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Feb 02, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
When we start the washer dose not keep the water insid going out right away in the same time befor the wash
basic engineering princaples water will take the easiest path, if your drain is lower than the washing machine fill level it will run through the machine to the drain. raise the drain pipe to above the top level of the drum that should do it. otherwise you have a faulty wiring and your drain pump is on all the time.
Nov 12, 2008 | GE Washing Machines
Dish washer IDL 550
Hi meeey,
I'm Harvey the Master Plumber.
Your problem is: Your dishwasher dose not drain water, and now dose not turn on the machin
Any body can help you?
If the motor runs but it won't empty then the pump needs replacement. If the unit washes but the motor won't come on to empty then you have a control problem. Either way I don't recomend this repair to the average homeowner. You might consider utilizing our Repair Directory to find a repair man. If the d/w dosen't come on at all then it may be time to consider replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | Indesit 24 in. IDL500 Built-In Dishwasher
Washer making a weird noise
I didn't get to answer this but It makes "cents" to me.
Sep 09, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Neff intergrated dish washer
Drain pump is either faulty or blocked, follow drain hose back to d/washer pump is at the end, always isolate from power supply before attempting any work
Jul 24, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Dishwasher dose not drane
YOU CAN TRY REMOVING THE LOWER RACK AND LIFT OFF THE SPRAYER. THE DRAINAGE WHOLE IS USUALLY VISABLE. YOU CAN FLUSH OUT THE DRAIN TO SEE IF THAT DOES IT. THERE SHOULD BE NO STANDING WATER IN THE BOTTOM OF YOUR DISH WASHER AFTER WASH CYCLE AND DRY CYCLE. HOPE I COULD HELP.
May 02, 2007 | Hotpoint 24 in. DF55 Free-standing...
Dishwashers Logo
67 people viewed this question
Top Dishwashers Experts
