Question about Meade DS-2114 ATS (325 x 114mm) Telescope
Do you need to oil gears - Meade DS-2114 ATS (325 x 114mm) Telescope
  • 3,186 Answers
No- the coffee grinder noise is normal.
Posted on Sep 07, 2010
I have a kymco bug espresso 2005 model 150cc. about to do oil change and just read the bit in manual about gear oil. Does this scooter need that too?
Hi, Sonia excellent question it all depends on how long you have owned the scooter and it's mileage, engine oil needs to be changed every 2000 km or 1250 mi. gear oil needs to be changed every 4000 km or 2500 mi.I recommend 10w40 in a synthetic "motorcycle" (not automobile) engine oil if you can find it, Amsoil and Mobil1 are the best and for the rear differential, SAE 80w90 gear lube is recommended, for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Kymco, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Kymco People 150 Espresso oil filter change
Gear Oil change on 2013 Kymco Super8 150
http://www.kymcousa.com/owners/onroad/People50-150.pdf
Aug 04, 2016 | Kymco Motorcycles
What gear oil commonly used for motoposh. With 125cc only, is it 2t?
Your'r motorbike has a 4stroke motor, avoid to use 2t oil! You will break the engine!
Instead use 4t oil engine! your gear box share the oil with the engine. You don´t need an extra oil for the gear box.
Hope it helps!
Dec 11, 2014 | Motorcycles
There is gear oil on the rear left side tire what should i do?
First make sure its gear oil and not brake fluid. If gear oil the outer axle seal needs to be replaced. If brake fluid the wheel cylinder needs to be rebuilt or replaced. You can tell by the rank smell of the gear oil.
Mar 18, 2013 | 1A Auto Parts 1996-2004 Chevy S10 Blazer...
How to put gear oil in..
The only place to put gear oil is in the "pumpkin". Otherwise called the rear-end.
To do so, I recommend driving the car backwards onto two ramps to raise the rear end up in the air, this also tilts the car forward.
Between the rear wheels, in the center of the axle, is a large metal container of gears and gear oil.
There should be a large hex-headed bolt less than half-way from the bottom to the top on the rear, facing your back bumper.
This is where the gear oil goes in, but after you take the bolt out, before you add any oil, stick your finger into the hole and try to feel the oil level.
If you can feel it, you don't need any more gear oil to be added.
Jan 21, 2013 | 1998 Ford Expedition
What is the measure of gear oil for F premio 2007 VVTI ?
Gear oil level is even with the oil fill port. Just fill it until you can insert your finger slightly into the port and feel oil.
Aug 23, 2012 | Toyota Corolla Cars & Trucks
What is the weight of the final gear oil for the suzuki boulevard M50? Is it 20W-50 gear oil?
NOOOO! Do not put 20w-40w in the final drive!!!
This bike has hypoid gears (beveled gears that create a sliding action across the teeth and therefore energy loss and a lot of heat). A 20W-40W oil will destroy those gears, it can't handle the high friction in the final drive.
You need an SAE90 Hypoid gear oil with a GL-5 rating as defined by the API (American Petrolium Institute) classification system. If you operate your bike in temperatures less than 32 degrees F (0 degrees C), you will need to use SAE80 GL-5 Hypoid gear oil.
Aug 07, 2010 | 2005 Suzuki Boulevard M50
BMW 523 Auto gerbox when cold change from 1 to 2 gear is hard
hello there
The problem is with the gear oil. To keep ahead of the rest BMW started what they call life time oil for their gear boxes, though that sounds great it doesn't really work in reality, they have now gone back to recommending a gear oil change every 60k miles.
In short you need to change your gear oil and soon, the oil in your gear box is no longer effective and will damage the gear box. You'll need about 5 litres for your car and costs around £15 a litre, expensive stuff!! I had the same problem with my 328i auto, the dealer was clueless and kept quoting the lifetime oil, I changed the oil and the problem has gone and it's so much smoother.
Hope this helps, please don't forget to rate me.
Apr 30, 2009 | 2001 BMW 5 Series
Need Gearcase oil
you just might want to change out you trans asm pn 3360629 for about
$175 part is not field servicable. even if you know what type or wieght oil then how much?
Dec 13, 2008 | Washing Machines
Gear box
check the gear oil in it, it sounds like it is low they will usually still go into gear but will be more stiff, if it is not low on gear oil you may have a hard part problem that would require internal repair
Jul 13, 2008 | Peugeot 405 Cars & Trucks
Meade DS-2114 ATS (325 x 114mm) Telescope Logo
24 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Are you a Meade Optic Expert? Answer questions, earn points and help others
