Question about Compaq Presario 700 470024-192 Notebook
My laptop is not detecting my headset , the built-in speaker and mic is working perfectly. How to solve this problem.............
    Guru:
  • 689 Answers
First check headset plug they fail all the time,then socket,then "mute"enablement
Posted on Sep 07, 2010
I can't seem to get my microphone to work. Every other sound is working.
You do not say what sort of mic you have - if its a built in laptop mic, a standalone mic or one built into the webcam.
It would also be useful to know what your OS is and what chat program you want to use the mic in
However we can generalise and hopefully put you on the right track
Have you set the mic you wish to use with your webcam as Default ?
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end.
Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure your webcam and mic to the Chat program
Aug 31, 2010 | Logitech Webcam
How to configure a headset with mic?
Headset will have two pins .plug the pin initially
The green pin should be plugged to speaker and the red pin to the mic.
In the volume button select the advance properties and increase the volume of mic .sometimes it may be in mute if so un mute it.
Ensure proper drivers are installed and mic is detected i the system.This can be seen from the sound devices option in control panel .
To check whether mic is working try to record using the sound recorder which is present in system
Mar 04, 2010 | Computers & Internet
XGR WebCam
You do not say what your audio setup is - if you have a laptop you are using the built in speakers or a desk top with add-on speakers. Also you do not say what your OS is
Here is Vista x laptop x Yahoo Messenger
TEST SPEAKERS
The speaker icon (checked as working) and volume level graph should be visible
Click on Speaker icon to highlight, click 'Properties' ramp up sliders - test again
Set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and set slider to 100% (adjust to suit later)
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Calling and Audio
Set mic and speakers to show Default equipment
Run call up assistant to test audio equipment > Apply > OK
If you do not have Vista - you will have to access your audio equipment via the Control Panel
Sep 28, 2009 | Computers & Internet
What type of headset do I need?
You're laptop has already the mic, so need for you to buy headset with mic. But, make sure that your laptop built in mic is still working.
Regards,
Jeep Brainy
Sep 20, 2009 | Computers & Internet
Headset Problem Rosetta Stone
I found the answer. Rosetta Stone has a problem detecting the mics if the speaker input is not in someway connected to the mic. I'm not exactly sure how it works, but I don't care and neither should you.
Follow these steps each time you want to use it and you should be fine.
*I'm on Vista, but this should work for every one.
1. Open Control Panel
2. Open Hardware and Sound
3.Open Sound
4.Set Line 1 as your Default Speaker
5. Refresh the Mic list
*All of your mics should now show up.
6. In Rosetta Stone, apply the mic you want and finish the setup.
7.Start whatever language you're using and switch back to the Sound menu.
8.Set whatever speaker you want to use as default.
*Rosetta Stone will continue to work fine until you close it, switch Users, or remove the mic.
In short you have to set the default speaker to LINE 1 to get the mics to appear. Then when you apply the settings switch the default speaker back.
Dec 27, 2008 | Rosetta Stone Chinese Mandarin Level I &...
Acer aspire 4720z Built-in microphone only records loud static
You did great troubleshooting for your laptop. If the sound is fine and good for the headset, your sound card is probably not the problem. The driver aspect, should not be the problem either if it works with your headset. So herein lies the dilemma...the problem is most likely due to some physical componenent between the built-in mike and the computer case itself. You should take it to a laptop repair shop and see what they can do. It has nothing to do with the software or the sound card. It is the physical component of the built-in mike and speakers. Get that checked out and you should be good to go!
Nov 15, 2008 | Acer Aspire 4720 Notebook
External Microphone - Not working
good day
have you tried inserting the microphone plug to the red/pink socket in your sound card?
Sep 20, 2008 | Compaq Presario 700 470024-192 Notebook
Headset and inbuilt speaker works at same time
Can you not just disable the built-in speakers in control panel while you're chatting on the mic?
-Aaron
Jul 30, 2008 | Acer Aspire 3680 Laptop
Mic
If your headphones have a single plug you cannot plug these into a regular speaker connection or headphone connction and get mic and sound, you will need a headset that has 2 separate plugs (one for Mic and one for headphone) or a splitter you can get a radio shack. Most headsets have only one plug and there are connections for both the mic and the headphones on this plug, but the headphone connection on the computer has only connections for the headphone and therefore cannot detect the microphone.
Feb 20, 2008 | E-Machines eMachines Refurbished EMA...
Compaq Presario 700 470024-192 Notebook Logo
27 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
