Ordered a new cooling fan How do I get the case off to replace it
    Guru:
  • 689 Answers
Hey dude thats cool youll have to work out how to open your pc yourself,take it slowly and methodicaly youll need a set of fine screwdrivers.
keep your bench clean of wires etc and have a good light to hand.
If your talking about the fan itself it comes enclosed as a unit you should only have to unscrew it an replace it as a unit,
Posted on Sep 07, 2010
Loud fan noise on desktop pc
Could be the case fan or the CPU fan. Open the case and determine which fan is noisy by unplugging them one at a time. Replace the bad fan with a new one and you are good.
Apr 16, 2014 | Compaq Presario Fan
My n4030 dell cooling fan is stoped and before that it was very laod amd noisy so i want to open cover may be ther is somthing is blowin it up
The good news is that you will get to open that case.The bad news is you will open the case to replace that fan.
Remove the power cord.Then open the case.Make sure you do NOT do this while standing on carpet or a rug.Before you touch anything make sure to touch some one or some thing to discharge static electricity.Now use a small screw driver and remove the 4 screws that hold the fan down.Now gently lift the fan out and put in the new one.Screw it down not to tight or it breaks the fan.Put the case together and you are done.
May 16, 2011 | Dell (6F858) Cooling Fan
Where can I purchase a replacement fan for one of these?
Newegg.com one of the best pc websites. If its for the cpu be sure to get thermal paste, or for the computer case measure the old fan and order the same size, most common is 80mm & 120mm. Also make sure to get the right power connector. If its really small its a 2 or a 3 pin. If its really big like what plugs into the harddrives its a 4pin/molex connector.
Feb 16, 2011 | Intel Xeon 5140 series Socket LGA771...
Can fan be replaced or do we need a new power unit
Are you referring to the fan which keeps the microprocessor cool, or the case fan? It depends upon the manufacturer but you can replace the case fan. The microprocessor fan can be replaced also. It involves opening the case and releasing the the brackets which are securing the fan to the processor. To replace the case fan, it's a relatively simple process of loosening the support bolts on the fan and removing it. Unless your system is not powering up at all (no beep sound, processor fan not running, hard drive led not flashing during boot up), you shouldn't need to replace the power supply.
Jan 27, 2011 | Computers & Internet
How do you replace the cooling fan of the Dell dimension 2400 desktop computer?
To replace the cooling fan follow these steps:-
You will notice that replacing the fan is not specifically mentioned, but it should be fairly easy.
Open the case as noted in the instructions, follow the power wire from the fan to the motherboard, then unplug the connector from the motherboard, and remove the assembly.
Some of the earlier fan shrouds just lift up and out, but others have tabs to hold them in.
Regarding the fan, there might be two release levers accessible from inside the case, but the one by the PSU can be hard to reach.
It might easier to push the retaining tabs, in from outside, using a small screwdriver, pen or whatever.
The installation of the new fan, is just a matter of fixing the new one in place and connecting the cable.
Good luck, and do rate the solution if got help
Dec 02, 2010 | Dell Dimension 2400 PC Desktop
I need a replacement fan for my medion computer the part# is cI5-9hdpb-m2 / mgt921ur-w25
You can use any generic 80mm fan, many local computer stores usually have a selection available.
Sep 30, 2009 | Magic Protechnic 80mm Sleeve Bearing Case...
Cooling Fans compatible with Toshiba A15 laptop
You can't replace the fan, you have to replace the power supply. In order to find out whih one you need the best thing to do is open your PC and find out the Wattage. It will be marked on the outside of your power supply. Just in case you do not know where the power supply is, if yo see where the vents are on your computer the power supply is there. It has a fan to blow the hot air out of it..
Don't forget to rate this solution with four stars before you log out.
Jan 23, 2009 | Antec TriCool 3.125" LED CPU Cooling Fan -...
Acer 5003 fan noice due to unknown reasons
your fan has worn bearings what I do in this case is remove the little sticker over centre of fan and just put a little drop of sewing machine oil on it replace sticker and check for noise
Jul 13, 2008 | HP (344872-001) Laptop Cooler, Cooling Fan
Fan Noise on Dell Dimension 8100
All computer fans have a general design.  The name in front of "fan" really refers to the designation.  You'll see case fan, processor fan, CPU fan, cooling fan, etc.  In the case of CPU/Processor fan, some are sold with heatsinks (the metal block sitting on top of your CPU).
The first thing you want to do is make sure the fan is clean.  Chances are dust buildup is causing the excess noise.
If that's not the case and you're looking to replace the fan, then you first need to find out the size of the fan. General sizes(diameter X width in mm) are listed on this page:
http://www.svc.com/case-fans.html
Generally, you're looking for something that will match the size of what you're replacing & push enough air at a reasonable noise level to cool the heatsink/CPU.  You want to stay in the area of 30dBA max for noise.  You also want to see if it has a 3-pin or 4-pin connection.
For example, if you have an 80mm fan, I would suggest something like this:
http://www.svc.com/saf-b82-19.html
It's pretty quiet with good airflow.  Also, it has a 3-pin connection, but includes an adapter for a 4-pin connection.
Z
Oct 27, 2007 | Dell (6F858) Cooling Fan
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
