Question about GE 18.2 Cu. Ft. Frost-Free Top-Mount Refrigerator - White-on-White
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
  • billy miller Dec 31, 2012
    whats the difference in your odel and mine is CTX18GAZARWW? DID YOU GET TO CLEANING THE DRAIN TROUGH THERE THE FUNNEL DRAIN CONNECTS ? IF SO HOW DO YOU GET TO IT ?
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Posted on Sep 07, 2010
  • 122 Answers
Sounds like your defrost drain may be frozen, if there is a sheet of ice on the bottom of your freezer and water leaking is leaking from the vent from your freezer, you may want to remove the back panel of your freezer and check the pan under the evaporator, if it is frozen that would explain the water at bottom of you vegetable drawers, turn unit off and melt ice from pan with hair dryer or hot microwaved water, or open both doors and unplug unit for 48 hours to manually defrost
Water collecting under vegetable drawers on Refrigerator only model
The drain line from the freezer is blocked. You will need to clear it out.
Oct 22, 2012 | Whirlpool Refrigerators
I have Hotpoint model CTX18BABKRWW Serial#ZT515963. Water is collecting in frige under two drawers. I cannot find a drain or a drain tray. Sounds like a low hum noise. Frig is cold and freezer is...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center.
This picture may be a slightly different moldel that years but it shows where that drain is
Aug 15, 2011 | Hotpoint Refrigerators
Water appearing in the refrigerator and collecting on the back of the shelves as well at the bottom under the vegetable and fruit containers.
could just be condensation,which is normall,have you put any uncovered/warm/food or salad/fresh fruit in lately,these all add to the"problem"there is no "fix "other than kitchen tissue under the salad /fruit drawers,and throw away once a week.fridges are not frost free.(condensation in freezer is frost)
Apr 01, 2010 | Refrigerators
Cold water collects in the bottom space below the drawers
this is just condensation as the fridge is not frost free.try placing a sheet of tissue in the bottom of the salad drawer and one under it, take out about once a week to keep dry
Mar 08, 2010 | Frigidaire FRT21H8 Top Freezer...
GE TBX18JA. Water is collecting below the
defrest freezer drain is in freezer. use hot water and a turkey baster untill water flows thru drain.
Jan 18, 2010 | GE J Series 18.2 cu. ft. Top Freezer...
Bottom of fridge under vegetable drawers lots of water collects. Every two days have to soak up.
I assume it's a top freezer model. The drain is either blocked, or frozen up. You'll have to be able to remove the the rear panel in the FREEZER compartment and inspect.
One other thing that can cause this, is if you have an Ice maker, and when filling, the fill hose to the ice maker hose has become dislodged.
Oct 19, 2009 | Whirlpool Refrigerators
Model TBX21KLK water pooling UNDER vegetable bins
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 21, 2009 | Refrigerators
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
Water under drawers, condensation on top of freezer
Water collecting on the top of a freezer, I have to wipe it every week, it is on the outside of the freezer, on top of the formica surface. Please Help.
Jan 12, 2007 | Kenmore 72202 / 72204 / 72209 Top Freezer...
GE 18.2 Cu. Ft. Frost-Free Top-Mount Refrigerator - White-on-White Logo
498 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
