Question about InFocus LP70+ Multimedia Projector
I broke the adjustable foot on my infocus lp70 projector....how do i replace the part?
projdoc
  • 2236 Answers
SOURCE: infocus projector lp70
in order for the lamp to strike and stay on, the fans and the colorwheel must be spinning and up to speed. if you remove the lamp and start it up, see if the 2 fans are spinning. and look inside to see if the colorwheel (a colored glass disk) is spinning. you'll also be able to hear a high-pitched squeal coming from it. unfortunately, you'll need to take it in to a repair center to have them replaced.
Posted on Jun 03, 2009
  • 74 Answers
SOURCE: InFocus LP70
Have you tried another lamp? Sometimes thats your problem, but I've seen a several occasions that the a defective power supply causes this symptom. Do you see an image flicker before the projector shutsdown? I do have some spare parts for this projector.
I'm on Ebay - gtitubro if you want to contact me through there.
Posted on Sep 19, 2009
projdoc
  • 2236 Answers
SOURCE: i have infocus lp70 model projector. i replaced
if you don't hear a high-pitched whir, your colorwheel needs replacing. you can remove the lamp and see the colorwheel inside (colored glass wheel). if you turn it on without the lamp, the colorwheel should still spin. if it does, you have a ballast problem. if not, the colorwheel. you'd still need to send it in to an infocus authorized service center. try av solutions in ny. they're pretty good.
Posted on Oct 22, 2009
Testimonial: "i understand what the expert is saying and this information is very helpful"
projdoc
  • 2236 Answers
SOURCE: InFocus LP70 projector is running hot
clean the dust out of it with canned air. the dust keeps in the heat that the projector is trying to expell. it also shortens the life of the lamp.
Posted on Dec 09, 2009
projdoc
  • 2236 Answers
SOURCE: LP70 infocus projector is casting a shadow on the
the light tunnel is collapsing and need to be replaced. you could get the part from an infocus service center and do it yourself or send it in to one and have them repair it. speaking from experience, it's a quite involved repair. you have to basically take the whole thing apart to get to it, and make adjustment to it really close to the power supply while it's on. kinda risky. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Posted on Dec 16, 2009
I have an Infocus LP70. My question/problem is in regards to the lens. I dropped the projector from about a foot off the carpet and onto the lens. The focus/zoom became jammed together, AND the lens came...
What I would try to do is, loosen the screw so its not stiff to adjust, adjust the lens to the right position then tighten up the screw again. Hopefully this should work for you!!
Nov 03, 2013 | ASK Proxima InFocus LP70, LP70+ and...
Process to upgrade firmware for InFocus lp70 ... can some describe this for me please? I've got the firmware downloaded, but my PC does not see the projector .. Help!! I also can not find the USB drivers...
Go here: https://portal.infocus.com/support/Product%20Pages/downloads.aspx?mic=LP70%2b&on=downloadsthen down load the file then find the text document "D3 D3+ firmware upgrade instructions.pdf" in C:\LP70plus\002-0870-08\I , or where ever you saved it. That will give you the complete instructions on how to upgrade.
Apr 27, 2011 | InFocus LP70+ Multimedia Projector
LP70 infocus projector is casting a shadow on the left side of the screen. It seems as if something is blocking the lens from inside? Could this be a bulb issue?
Dec 15, 2009 | InFocus LP70+ Multimedia Projector
LP70 Infocus Projector light will not start up
if you don't hear a high-pitched whir, the colorwheel needs to be replaced. if you do, it's either the lamp or ballast. if the lamp is new, replace the ballast. you can get the parts if you want to do it yourself, or you'll have to send it in. either way, try av solutions in ny. they are an infocus service center and they're really good. www.avsolutionsny.com
Nov 22, 2009 | InFocus LP70+ Multimedia Projector
Infocus LP70 powers itself down after 30 seconds or so.
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
Nov 12, 2009 | InFocus LP 70 Multimedia Projector
Sep 21, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP70
Sep 17, 2009 | InFocus LP70+ Multimedia Projector
Does anyone know of a repair/service center in NYC for an In Focus LP70 Projector?
there's one in rochester, ny. av solutions. i believe they are an authorized infocus service center. www.avsolutionsny.com
Jun 29, 2009 | InFocus LP70+ Multimedia Projector
Why does picture brightness change up and down on LP70.
Hi there
Sounds like the lamp is going , but it could be the Ballast as well ( lamp's powersupply ) Rather have a certified technician look at.
Mar 22, 2008 | InFocus LP70+ Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
113 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
