Question about Toshiba 32C100U 32 in. TV
I just bought a toshiba 32c100u and I have hooked up my ps3. There is, however, no sound. I am sure that it is not a wire problem as I have tried every possible connection, but the sound does not work. Moreover, the hooking up process is simple. The tv also doesn't not make noise when it is on the cable setting (there is currently no cable, but it does not make the white noise). I am wondering if the tv is just made broken, or is there something I can do. Any help would be greatly appreciated, Aleksandar
marked
  • 6487 Answers
SOURCE: Picture but no sound on a Toshiba Theaterwide HD tv
You can check the user manual for some troubleshooting tios about this problem and also try resetting the audio part of the TV its on page 42 of the user manual if resetting the audio still didn't fix the problem reset the entire unit you can also see the steps from the user manual http://www.tacp.toshiba.com/tacpassets-images/models/50hp16/docs/50hp16_om_e.pdf
Hope that helps.............
Posted on Sep 12, 2008
SOURCE: closed caption problem
I had the same issue... here's what I did.  If power off your cable box, then press the menu button, there's a selection to enable or disable Closed Captioning.  This works for both HD series Motorola boxes Comcast offers, at least in the Minneapolis/St. Paul area.  Hope this helps!
Evan
Posted on Sep 28, 2008
  • 50 Answers
SOURCE: No picture with VIDEO INPUT, only AUDIO INPUT works
Hi ,disconnect the cable and leave the three RCA cables in.Switch off TV and DVD player ,then switch on tv and dvd player next .If you see the dvd picture and have sound then i think the cable box is overriding the rca channel.I normaly use a scart connection for the dvd to cable box then another scart from cable to tv.Hope this helps..
Posted on Feb 06, 2009
  • 814 Answers
SOURCE: no sound on my Toshiba Regza 42HL167
Found this troubleshooting method on the www.Toshiba.com website. Q. My TV has a picture, but there is no audio?
Models: 20DL77, 20HLK67, 26HL47, 32HL17, 37HL17, 42HL17, 26HL37, 32HL37, 20HL67, 26HL67, 32HL67, 37HL67,
42HL167, 42HL67, 47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00128
1. Please check your connections and make sure if you are using COMPOSITE “yellow, white, and red cables”, SVIDEO,
with “white, and red” or Color Stream COMPONENT “green, blue, red, white and red cables,” that the white
and red cables which are used for audio are plugged in securely into the same inputs as the video.
If your connections are secure, the station may have broadcast difficulties. Try a different channel.
2. If you are using the coax cable from the wall, press the “ENTER” button on the middle of the remote. If the
information provided shows that you have SAP selected we will need to change it to STEREO or MONO. To do
this, we will need to press the “MENU” button, and use the RIGHT or LEFT arrow keys to highlight the AUDIO
menu. Next we will need to use the DOWN arrow to select AUDIO SETUP press “ENTER” and then arrow down to
MTS and use the RIGHT arrow to select stereo.
3. If you have a cable box or satellite receiver, please make sure the TV’s volume, as well as the box’s, volume is
turned up sufficiently.
4. The station may have broadcast difficulties. Try another channel.
5. The sound may be muted. Press VOLUME.
6. If you still have problems after following these steps please contact Customer Solutions at 1800-631-3811 Monday
through Friday 8am to 7pm CST. The Toshiba customer service number is 1-800-631-3811. I hope this helps you with your problem.
Posted on May 17, 2009
SOURCE: Toshiba Regza bought 1/28/08 makes squealing noise
It's in the repair shop. I'll write back what the problem was and how much it cost to ship.
Posted on Oct 08, 2009
Toshiba 32c100u keeps blowing fuse and my tv wont come on
If fuses keep blowing, the power supply may have shorted.
Jun 23, 2014 | Toshiba 32C100U 32 in. TV
Toshiba 32c100u dead; power supply board replaced but still nothing
Have you checked whether mains power reaches the power board? Check it first. If yes, the power board you purchased newly should be checked.
Jan 09, 2014 | Toshiba 32C100U 32 in. TV
Toshiba 32C100U popping sound no picture
Might be worth the effort to open it and have a look for loose plugs or a ribbon cable somewhere--if do look for any plugs that are held down with tape near where they plug in.
Jun 14, 2012 | Toshiba 32C100U 32 in. TV
I need to change the mainboard of one toshiba tv 32c100u i. how I can get it by internet
Just disconnect all the connectors and make sure you keep track will each screw that you have removed goes, and you be able to get a new board at www.partstore.com
Aug 12, 2011 | Toshiba 32C100U 32 in. TV
I have a toshiba 32c100u tv i dont see exactly were to plug all white and red wires
red and white colored plugs are for audio, red it right channel and white is left. Plug your DVD player (if that's whay you have) into the red and whte on the tv, some tv's only have one audio in and its usually white, in this case plug in only the white wire from your player. the yellow plug is for video and you should plug that into the yellow jack on your tv. If you tell me exactly what you are trying to plug in I can help you better.
Mar 16, 2011 | Toshiba 32C100U 32 in. TV
Looking for an instruction manual for Toshiba tv model #TV32C40
Would like to know if the Model # stated is correct as the Toshiba site does not display any model with this numbers? Anyway it appears that this model has been superseeded by another Model namely 32C100U for which you can download the manual from this link. I am confident it will carry all the details which you are looking for.
http://www.retrevo.com/support/Toshiba-32C100U-TVs-manual/id/23630ag400/t/2/
Oct 27, 2010 | Televison & Video
When im playing a game or a dvd on my ps3 i only have background noise thats it. i cant here people talking on the dvd just the background sound. what can i do to fix the problem?
get your ps3 checked and are you sure you hooked up your audio and sound wire hooked up right and if that doesn't work than try using a HDMI cord it really helps............
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
I just bought a PS3 slim and hooked it up to my 65'' Toshiba DLP TV using a HDMI cable. The problem is i have picture but no sound. I have tried the settings and all seems to be fine, also tried different...
not 100% sure but check the manual for your tv it may be that you need a faster hdmi cable, as with having a larger tv it will work at a faster rate so the basic hdmi cables wont work.
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
PS3 Video Connection--Lines on TV
this may be due to the fact that your ps3 will be set up to hd. go into video settings when you switch it on and this should solve the problem. i had similar problems and bought a hdtv until someone pointed this out to me. however once you have experienced ps3 in hd you will not go back!!! hope this helps
Jan 13, 2009 | Sony Playstation 3 (PS3) Console
Toshiba 32C100U 32 in. TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
