Question about LG Flatron F700B 17" CRT Monitor
How i can increse my refresh rate up to 85 hertz and ware i can find monitor lg flatron driver
    Sergeant:
  • 237 Answers
Go to following steps
Posted on Sep 07, 2010
HOW TO FIX LG FLATRON 1750HQ OUT OF RANGE WITH WINDOWS XP?HOW TO START THE MONITOR ON A WINDOWS XP IT WORKS ON VISTA HOWEVER ON XP WINDOWS IT SAYS OUT OF RANGE WHAT ARE THE CORRECT SETTINGS FOR WINDOWS XP...
your refresh rate is set too high. boot into safe mode set to 640 x 480 then reboot. once it is up try adjusting the refresh rate to around 60 or lower. or buy a newer monitor.
May 20, 2014 | LG Flatron 563LE 15.1" LCD Monitor
Screen is flickering laptop
hi i hope this helps i found this info 4 you
Right click on Desktop main screen.
click properties
click settings
click advanced
click monitor
set your screen Refresh rate
( try at 85 Hertz or a step less)
In case you are using graphic card, click on Graphic Card Control Panel..
(in control panel)
select change resolution
select Refresh rate , as per requirement of your system.
Aug 06, 2013 | Computers & Internet
My screen wont move to the left all the way
1. Make sure you have the latest driver installed for your Graphic Card
Or Built-In Graphic
2. On your Desktop, Right Click>Properties>Settings>Advanced>Monitor
and change the Screen Refresh Rate (60/70/75/80/85...etc)
You can also try to change the Graphic Adapter Mode (Screen Resolution)
For example: 1280 by 1024,True Color (24 Bit), 60 Hertz...etc.
Jul 12, 2011 | Computers & Internet
MY MONITOR MODEL IS LG FLATRON T705SH I CANNOT ADJUST MY SCREEN RESOLUTION I WANT TO KNOW THE VALUES SUCH AS POSITION: SIZE: SHAPE: PLEASE HELP ME OUT SIR AS SOON AS POSSIBLE
Your monitor supports a maximum resolution of 1280 x 1024. If windows fails to give you the option of changing to this resolution and those below it then please follow these suggestions:
Update your video card drivers, if you don't know the manufacturer of your video card try windows update.
Install the latest drivers for your monitor as well.
Your monitors driver click HERE
May 04, 2011 | LG Flatron F700B 17" CRT Monitor
LG Flatron l1515s which is giving Out of Range 64.0kHz / 60Hz and can not even give setup menu. Please help.
This is not a setting on your monitor. It is a setting on your operating system. The display settings needs to be set to a 60Hz refresh rate.
Hook up your old monitor and right click on desktop --> properties --> and then to display and advanced settings. You can then set it to proper refresh rate and plug the new monitor in.
Mar 28, 2011 | LG Flatron L1515S 15" LCD Monitor
What is default monitor screen setting LG flatron e700sh
1280x1024 resolution
I would try using a 60hz refresh rate though it does state the monitor will support up to 85hz
Feb 18, 2011 | LG Flatron F700B 17" CRT Monitor
When I open game the monitor become black and show: Analogique shortcut 53.6 Khz/85 hz
Your resolution or screen refresh rate sounds like it is too high.
Try dropping your resolution to 1024 x 768 and see if the issue persists.
If it does then perhaps your game is trying to force you into a higher resolution output and faster screen refresh rate than your graphics card or your screen can handle.
Assuming that the graphic output is fine when your not playing this game and just using windows?
Thanks
Pete McDowell
Geek2Door Ltd
http://www.geek2door.com
Feb 15, 2010 | LG Flatron L1752TX 17" LCD Monitor
Monitor displaying 'check signal cable'
Make sure the refresh rate is set at 60 hertz before using the new monitor also check the display settings to see if they are set to use the external display also. Yours may automaticaly do this and your partners may not. If this does not help please let me know the type of notebook and monitor. Good Luck!
Jan 15, 2009 | LG Flatron 776FM 17" CRT Monitor
LG Flatron L194WS 19" LCD
check the VGA card of ur CPU.
load the LCD drivers
also check it's refresh rate, are they enable, if not then the VGA card did not accept the LCD properly. load the lcd drivers seperatly...
Feb 08, 2008 | LG Flatron L1750S 17" LCD Monitor
LG Flatron F700B 17" CRT Monitor Logo
185 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
