Question about Sony STR-DA90ESG
Sony STR-DA90ESG in Protect
Trying this once again now that I have been able to establish a user account - sorry for repeat post but I REALLY want to get my DA90ESG working !! Any help is most appreciated -
I have the same model, same problem. I understand that one or more of the output transistors are shorted. I took it to a repair shop in Orlando. My problem is the repair tech said there are 16 (I think) output transistors and they are around $25 each his cost - he showed me in his parts book.
He said no way to tell if one was bad, a few, or all, without expending the labor to lift their legs off the circuit board, and he was not going to order 16 replacements which would cost him $400.
So I am stuck. I used to repair commercial power amplifiers so I could do the work myself but the way consumer units are built 0 including this one - its a real pain to get in there and isolate each output drive transistor to see how many are blown.
I love this unit, despite its use of non-standard IR carrier frequencies, which is why no programmable or universal remotes can learn its codes. But s allows separate routing of audio and video, which is a rare feature in consumer units.
Any advice is appreciated. It seems to be the COST of the replacement transistors and the labor to find out how many are even bad that is why this repair shop just handed me the unit back. Maybe another repair shop in the Orlando area ?
Thanks !
  • bbittel May 14, 2008
    I will open the unit and get the part numbers off
    of the transistors. Are these just standard 2-junction transistors or are they
    monolithic hybrids, push-pull pairs or something like that ? If just regular
    2-junction transistors, I should be able to lift their legs and measure the
    junctions with a meter set on diode test - You usually see a dead short across
    the emitter/collector junction IIRC.
    Also, I can look for the voltages you specify but
    if the pins are lifted, do I measure at the pin itself or on the circuit board
    where the pin is normally soldered to ? I would guess I am going to see rail at
    the collector, 0v or close on the emitter and 0.6 or so on the base, w/ respect
    to ground. Is this correct ? THANKS !!!
  • 4,234 Answers
Doesn't sound right to me. I work on these all day long. First of all the transistors from Sonty are probably $25 each. What were the parts? I usually use the Japanese equivalents. I'm guessing that the transistors are Mp and MN numbers. These equate to 2SB and 2SD numbers. These devices are the same. Sony re-brands the numbers. Also, if one of the transistors is shorted for one channel, change both for that channel even if the other measures good. I'll research your model and try to narrow this down a bit. In the meantime, lift the pins on ALL of the transistors and measure the voltages on all 3 pins. You should read (+/- 0.6 or 1.1V, 0.0, and B+/B-). Post those readings here.
More to follow...
Dan
Posted on May 14, 2008
  • ABRsvcs May 14, 2008
    Measure at the board. What we are looking for here is whether or not the output transistors are the problem. With them removed, I believe that the voltages should be correct at the 3 pads. If not, then we need to look at the driver stage. With the unit off, you should be able to check the outputs in-place with a diode checker. You should not read a short. If you do, that tis the bad channel. Lift all 6 legs for that channel (2 transistors) and try turning on the unit. If that was the bad channel, you should see the unit start up.
    Dan
SOny DA90esg sound distord like it have a cold ? any ideas
Check your wiring. Sounds like your "out of phase" The easiest way to tell if this is the problem is to adjust the balance from left to right. all the way on either side should sound good, then move to the middle and it sounds dead. That's it. Find your speaker wire that has the + and the - reversed and switch. If this is not the fix, post a comment and I can help you dig some more. Hope this helps
Jun 24, 2009 | Sony STR-DA90ESG
Is there a way to reset the STR DE898/B 7.1 channel Receiver
Reset can mean many things... Input/ output/surround/ or is it saying "Protect" on the display?
If that's the case, unplug, wait a minute, plug it back in and turn on. If it still say's Protect, disconnect the speaker wires and test again. Chances are you have a shorted wire or speaker. If you need something different, post a reply and I will help you further. Hope this helps
May 25, 2009 | Sony STR-DE898 Receiver
Error code - protector
Try disconnecting all the speakers from the back and turn the unit back on. If the "protector" display goes away, turn the unit back off and reconnect one speaker. Turn it back on and check for "protector". Repeat.
If you find that one of the speakers causes "protector" to appear, you either have a bad speaker cable or bad speaker. Try swapping each of those out to see what happens.
Apr 20, 2009 | Sony STR-DA90ESG
PROTECT DISPLAYED ON RECEIVER
This generally means you've got a short somewhere, and the received is trying to protect itself.
My suggestion is to disconnect all of your speakers at both ends, and reconnect them.
Most times this happens because a speaker wire is lose, and the positive and negative connections are touching each other, causing it to short out.
Mar 24, 2009 | Sony STR-DE485 Receiver
Sony str de415 ( protect
You can try tighting the ground screws that hold the circuit boards and heat sink to the chassis, But more times than not it will need a pair of output transistors replaced (and a few resistors). This is a job for a pro. A rough estimate is $100-$130.
Sorry for the bad news.
Mar 08, 2009 | Sony STR-DE485 Receiver
Function Selector Bypasses Input Sources
Hopefully this post isn't too late... That receiver has the ability to disable certain inputs. The easiest thing to try is to do a factory reset.
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Unfortunately, this clears out all of the other settings on your unit. It should, however, re-enable the inputs.
Let me know if this helps!
Dec 28, 2008 | Sony STR-DA90ESG
Direct tuning
Unfortunately, according to the manual you can not directly tune a station.
Dowload the manual here:
http://esupport.sony.com/US/perl/model-find.pl?mdl=STR-DA90ESG
and go to page 50.
Oct 23, 2008 | Sony STR-DA90ESG
I don't have the remote control
You need remote control for STR-DA90ESG, its details are as follows...
1-475-133-11 RM-H501 REMOTE CONTROL
Currently In Stock: Yes Unit Price (in USD): $98.95
Its available at Sony Accessories, enter model number of unit in search box and see details.
Sep 27, 2008 | Sony STR-DA90ESG
Wiz sony
The receiver has detected a problem in the final output stage and has shutdown to prevent further damage to either the amp or the speakers. The most common cause of this is shorted output transistors. Figure about $15-$30 for parts plus the local labor rate.
Dan
Apr 08, 2008 | Sony STR-DA90ESG
Protector mode
The problem is that the output transistor(s) are shorted causing the unit to shutdown in what is called "protect" mode. This is a common failue and should be easily repaired by a service shop for about $25-$40 in parts plus labor.
Dan
Mar 17, 2008 | Sony STR-DA90ESG
Sony STR-DA90ESG Logo
246 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
