Question about Epson FX 2170 Matrix Printer
How i can set the paper size to maximum? - Epson FX 2170 Matrix Printer
    Sergeant:
  • 237 Answers
In print dialogue box there is option page setup
in page setup you may choose predefined sizes or CUSTOM size which you can define yourself
you must vote for solution
Posted on Sep 07, 2010
I need to pull an 11" x 48" sheet through my printer
That will never work as the printer looks for pages that are standard sizes. If it comes across something that is larger, the printer reports a paper jam. Making banners is best done on dot matrix printers using listing paper. Otherwise on a home printer, you use the banner setting in your creation software, MS Word, MS Publisher, and you print as separate pages and stick them together or stick them on a backing sheet.
Oct 22, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
HOW TO SET PAPER SIZE FOR KM1500 COPIER MACHINE
The paper sizes that can be used for Offset copying are A4, B5 and. 11 ?? 8 1/2" ..... access code (set using KM-NET Printer Disk Manager) is entered to ..... NOTE: SPSZ is the size specified with the PRESCRIBE SPSZ ...... 1,500 lux maximum. Kyocera KM-1650 printer user guide manual Operating Instructions
Mar 02, 2015 | Office Equipment & Supplies
I have created a custom paper size 14' * 4' but i am unable to select the same paper size to set the page setup.
The maximum paper width the 6306 can print on is 13.6 inches, you will not be able to select a custom size form larger than the printer is capable of handling.Simply set the for size to 13.6 inches or the maximum width you will be printing.
Aug 11, 2011 | TallyGenicom 6306 Matrix Printer
I wish to use my HP Photosmart C8180 to print heavy weight cardstock... is there a setting that I can select to do this?
Step Three: Check the paper type Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include:
  • Plain paper, 20 to 24 lb (75 to 90 gsm)
  • Legal size paper, 20 to 24 lb (75 to 90 gsm)
  • Card stock, up to a maximum of 110 lb (200 gsm)
  • Envelopes, 20 to 24 lb (75 to 90 gsm)
  • Photo paper, 145 lb (236 gsm)
NOTE: Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.
If you use card stock up to a maximum of 110lb then there should be no special mode to enter to print on this type of paper. Photo paper weighs in at 145 lb maximum which is heavier and can be printed on without selecting any special 'mode.'
Good luck on printing on heavy card stock.
Jan 21, 2011 | HP Photosmart C8180 InkJet Printer
Am running windows7 and when i try to add a form with 21" width and 30.50" height my form is not added.
The form width you are trying to create is wider than the T6215 is able to print on. The maximum page width that you can print is 13.6 inches, if you try to create a custom size paper wider than 13.6" Windows will not show you this form within the T6215 printer driver. As you can not physically print 21" wide you do not need to define a paper size this wide. Simply create a paper size which reflects the maximum print width or 13.6" You will then be able to print the maximum width the T6215 is capable of and also see this form in the printer driver.
Jan 03, 2011 | Tally T6215 Matrix Printer
After creating a new form of size 15 x 12 fanfold in the printer settings option, form is saved but not applied. So after selecting printer in a software, the paper size option of 15 x 12 fanfold does not...
THe T6215 can only print a maximum width of 13.6 inches. If you create a form wider than this Windows will not allow you to select this form within the printer driver as the printer is not physically able to print this wide. Your paper may be 15 inches wide but it is unlikely you will be printing 15 inches, simply create a form whose width is equal to the maximum print width or 13.6 inches. You will then be able to select this form in the printer driver.
Dec 13, 2010 | Tally T6215 Matrix Printer
Parts of page being scanned are cut off
Whcih version of CapturePerfect you are using?
I use ver 2.0. In the settings page select scanners maximum. In the 'advanced' select auto detection. Then whatever size of the paper guides you choose, that will will be the width and ofcourse the length is automatic. There is a sensor under the paper guide, and it detects the paper width. Any rotation chosen will be after scanning the required size.
S. Mohan, Chennai, India
Jul 20, 2009 | Canon DR-5010C Scanner
Hp color LaserJet 3700 jams 70# uncoated letterhead stock
Hi manitou344:
Here is some info that might help you.
Table 1-8. Tray 1 paper sizes1
Media Dimensions Weight or thickness Capacity
Minimum size paper 76 by 127 mm
(3 by 5 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
(75 g/m2; 20 lb bond)
Maximum size paper 216 by 356 mm
(8.5 by 14 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
Minimum size glossy
paper
76 by 127 mm
(3 by 5 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
height: 12 mm (0.47 in)
Maximum size glossy
paper
216 by 356 mm
(8.5 by 14 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
Minimum size
transparencies2
76 by 127 mm
(3 by 5 in)
0.12 to 0.13 mm thick
(4.7 to 5 mils thick)
50 sheets
Maximum size
transparencies2
216 by 356 mm
(8.5 by 14 in)
50 sheets
Minimum size
envelopes
76 by 127 mm
(3 by 5 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Maximum size
envelopes
216 by 356 mm
(8.5 by 14 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Minimum size label 76 by 127 mm
(3 by 5 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Maximum size label 216 by 356 mm
(8.5 by 14 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Minimum size
cardstock
76 by 127 mm
(3 by 5 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
Maximum size
cardstock
216 by 356 mm
(8.5 by 14 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
This printer can
detect transparencies that were not designed for use with HP Color LaserJet printers.
Jun 30, 2009 | HP Office Equipment & Supplies
Canon DR 2580C Scanning issue
In Captureperfect, select page size as 'Scanners Maximum'. Select automatic paper size, check the output now. If you select bigger paper size and smaller paper, you will see lack output, outside the paper area.
Nov 26, 2008 | Canon DR-2580C Path-Through Scanner
Epson FX 2170 Matrix Printer Logo
102 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
