Question about Dell Inspiron 6000 Notebook
My dell inspiron 6000 is having issue with the monitor not coming on. I am able to boot the system and go into the the boot menu. I am not sure what is going on, Please help advise me on what to do?
    Guru:
  • 689 Answers
Firstly you can reset bios settings to default if you can find this option,use "tab" and arrow keys to navigate and "tab "or enter to select options .. Run through a few times to get to know the bios pages dont alter anything untill your sure you know what your doing --you will be given the option to save changes and quit
Posted on Sep 07, 2010
Monitor will not come on on my dell insprion 6000 but works fine with an external monitor
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jun 11, 2012 | Dell Inspiron 6000 Notebook
Hiya, I have got problem with my dell insp 6000. I installed window xp on it using recovery CD sent to me about 3years ago. After the installation i tried to log in but it asked if I want to activate the...
try to clean install xp to your system again. recovery cds work only on clean install. boot to boot menu with the disc inside then select your dvd drive.make sure to select new installation and not "upgrade". ( please also make sure that your system is plugged into the walloutlet to avoid interuptions with the installation.
Sep 07, 2010 | Dell Inspiron 6000 Notebook
I have a Dell Inspiron 6000 that is not quite 4 years old. When I turn it on the scree shows the dell insignia, then the windows screen and then goes black. I don't know if the system is booting up or what...
Sounds like a definite no boot issue. Turn the system on to the diagnostics (Fn + Power) see if the diagnostics show a failure. If the hard drive passes diagnostics, then boot to the XP CD and try repairing the WIndows installtion
Jan 13, 2010 | Dell Inspiron 6000 Notebook
My Dell Inspiron 6000 (which I think I bought in
Have you tried this:
1. After removing the battery
2. Press and hold the power button for at least 10 sec.
3. Put back the battery
4. Turn it on
if this doesnt work, there could be a problem with your operating system. Try accessing safe mode if you can login .TAP F8 continously on the dell logo screen, and it will open advance boot options. (Just select safe mode) If safe mode boots properly try running system restore to restore it back to the previous date where your computer is still booting to windows. Hope this helps
Dec 08, 2009 | Dell Inspiron 6000 Notebook
Inspiron 6000 starts to boot but then shuts down after only 10 seconds. New Battery, power supply measures ok. Caps lite is on.
Try reseating the RAM memory modules, see if any change.
If no change, remove, battery, Drives, Wireless card and RAM, see if the system will run longer or give an error code. If something changes, add 1 RAM module and try again. If the system runs, then add items back one at a time until you determine the faulty item.
If the system issue doesn't change, odds are a motherboard problem. Motherboard are about $100 on Ebay
Dec 06, 2009 | Dell Inspiron 6000 Notebook
My Inspiron 6000 screen is blank. I can get an image on a monitor through the serial port, but when on its own, the notebook screen is black. I have noticed that there is a brief flash when booting up, but...
Hi ,
1. You can check the display on external monitor>If the display is blank on external monitor also, its pretty clear that there is an issue with system board
2. If the Exernal monitor comes up fine, it will be an issue with the display of the laptop, you can cross check the issue by booting the computer to BIOS, IF you get same response on BIOS as well. Its an issue with the Display itself you can replace the display panel.
Hopefully, its covered under warranty ;)
Jun 29, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 laptop won't boot up
Pleae reboot your system and when you see the Dell logo , press the F12 key a couple of times .
In the menu, select only HDD diagnostics and post the results back . If the harddrive fails, then the only solution would be to replace the same. If the hardrive passes , we may be able tp fix the system
Thanks
proton
May 31, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 6000
u need to check the same issue using another monitor or a display device if u get the same 4 screen resolution then its the video card or else the issue is with the LCD.
May 15, 2009 | Dell Inspiron 8600 Notebook
No sound Dell inspiron 6000
hi
open RUN from start menu and type msconfig. On the "system configuration utility" open services tab and chk for windows audio and make sure its running, if not then select it and just enable it.
hope this solves ur problem.
Jun 26, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 monitor display problem
Well it is most likely a issue with the Video driver as you are able to boot to the safe mode.I would suggest going back to the safe mode and deleting the present driver for the video from the device manager.before you restart the system just download the latest version from the support.dell.com so that you can reinstall it.Also check in the graphic properties which screen is set to be the defuat.Incase still not working i would suggest reinstalling the operating system before replacing any hardware.
Jan 03, 2008 | Dell INSPIRON 6000 CENTRINO...
Dell Inspiron 6000 Notebook Logo
49 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
