Question about ASUS M4A785M Motherboard
My left audio channel keeps going out on my computer after a few hours of use, and I can't figure out why. The speakers themselves are not at fault because I can then plug them into my ipod and both channels work fine. I have an Asus motherboard with onboard sound, and have installed the latest audio driver. The channel always comes back to normal when I restart the computer.
I have the same problem, haven't solved it yet. I'm thinking about buying a dedicated sound card and disabling onboard sound.
Posted on Jan 01, 2011
Yamaha ax440 left channel down
Check both your input(rca) and output connections on the inside of the amp for any looseness or damage, solder connections and so forth.. However I think your power/output transistor(s) are burnt in the left channel
Apr 08, 2013 | Audio Players & Recorders
Creative SBS 370 2.1 - left audio channel is not working
This is coz of one carbon track of dual potmeter gone bad due to prolonged use.
Jan 28, 2013 | Creative Labs SBS 370 Computer Speakers
One of my speaker channels has no sound
reinstall the speakers driver or your sound card driver. doing that select what kinda speakers do you have (5.1 , 2.1, 2).
Apr 06, 2010 | Cyber Acoustics A5640 Computer Speakers
Left channel will not play
Firstly try swopping over the left speaker to the right channel . If still no sound then either the speaker cable will have a break in it & need replaced or the actual speaker will be open circuit. If you get sound from the speaker on this channel then the the speaker is ok. Check your PC's audio set up... Go to Control Panel/ Sounds & Audio devices/ In volume Tab, click in Device volume area... Advanced & then check the Balance settings are not set to one end.
Jul 22, 2009 | Dell A525 Computer Speakers
Only one speaker working on my str-de675 receiver
If the speakers themselves work fine, then the problem lies within the amplifier output. The channels can go bad after hard use, they can be repaired but it may well exceed the cost of the amp if it is not just one channel. Also be sure that you are hooking up speakers that are rated for your amplifier by matching the OHM resistance of the amplifier to compatible speakers.
May 03, 2009 | Sony STR-DE675 Receiver
Yamaha rx-v2200 sound problem
Hi Zanthena - my Yamaha rx v 2200 is doing exactly the same thing - did you manage to track the problem down? I have had my unit in for repair and the fault occurred again 6 hours after I re-installed it.
Any help would really be appreciated!
Jason.
Sep 07, 2008 | Yamaha RX-V2200 Receiver
Kenwood Receiver KR-V127R - left channel not working
Select an input that is not connected, for example select CD with no cables going to the CD input on the backside. Will you then hear equal humming on both channels? If so, the amp stage is ok,
and the problem lies in the signal level circuitry.
Open the cover and use a plastic (insulated) stick to touch suspectible cables and components. When the sound returns, you've found the cause. Resolder or reseat the component/cable/card.
Use the insulated stick, NOT your fingers!
Dec 31, 2007 | Audio Players & Recorders
Speaker problems
Hi, since the speakers themselves are ok, try checking the BABY PHONE PLUG that goes to the music/sound source. It is normally three (3) in 1 stud. The metal topmost would go to one channel, followed by a blak plastic ring then another metal band which goes to the other channel, followed by another black plastic ring and the final metal part which is the ground. With power on to the Z-5300, try touching the ends of the baby phone plug. Touching the top and 2nd metal part should produce a sound on either of the left or right. No sound (but spkrs good) it is possible that the left channel (front and rear) of the amplifier is dead. Hope this helps.Regrads.
Apr 20, 2007 | Logitech Z-5300 Computer Speakers
Left Speakers not working on A or B channel
Have you tryed yet to switch the right speaker where the left one is? If it works then you know the speaker is bad. If you move the left speaker over to the right channel and it works and sound now comes out of the left speaker, you know there is a fault in the amp somehwre. If your not a tech and have not had any solid state equipment repair experience, then your going to have to have the amp serviced by a trained tech.. Good Luck
Oct 30, 2006 | Pioneer VSX-454 Receiver
ASUS M4A785M Motherboard Logo
82 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
