Question about Mitsubishi HS-U770 S-VHS VCR
Tape goes into machine and starts up but I then get a high pitches squeal and nothing happens and the playback stops.
What causes the starter to make a high pitched squeal on my 1984 Chevy s10
It could be the Bendix inside the starter which engages the
starter drive.
Feb 19, 2015 | Cars & Trucks
I have a high pitch squeal from 1998 buick 3.8, told it was water pump, changed, still same, changed belt due to squeal, but still have same sound. Turned on n off a/c comp but did not change anything....
i have the same problem, changed the alternator, pulley and all that, it happened after i had the intake changed out due to the egr problem, if yours hasn't been changed id look into it before it goes, better sooner than later sorta things...
Feb 15, 2011 | 1998 Buick Park Avenue
Loud squeal when I drive.
You need new brake pads . it has a metal tip that squeals on the rotor when they are worn.
Jun 10, 2010 | 2001 Isuzu Trooper
High pitched squealing noise when i start engine
have Your alternator belt checked for the propper tension:]
Jun 17, 2009 | 2003 Nissan Frontier Crew Cab
High pitched squeal on new brakes
Break squeal can be stopped by applying shims or anti-squeal compound to the pads.
Apr 05, 2009 | 2005 Ford Freestar
NO PIC HIGH PITCH SQUEAL COMING FORM BACK BOTTEM PART OF TV?
Squealing sound means you have something shorted in high voltage area around FBT on Power/deflection board.UED has replacement boards & Misc Parts for these sets if in stock call them1- 800-648-6657
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
ILO DVDR05 makes high pitched squeal during recording
Usually a problem like this has to do with d.c. power sypply problems. Because "record" uses a different supply voltage and maybe "subcirckit" [not the same dc voltage that you use for playback, etc] If you know HOW to look inside and if you know how to take voltage\current readings...check ALL capitors,the diodes(misspelled?)Replace any that are "swolened", they are bad Other then that, take it to tech who if he is a crock he will overcharge, and if he is honest will repair for a fair price..... " Rotosa Ruck " [lots of luck]
Aug 19, 2007 | iLO DVDR05 DVD Recorder
High Pitched Sound
I am to believe that your static sensor on the playing head is touching the the head and it sould not. just bend it up "slightly" and the noise should disappear
Dec 14, 2006 | JVC HR-S5902U / HR-S5912U VHS/S-VHS...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
