Question about GE GSS25SGPSS Side by Side Refrigerator
I have a ge fridge model GSS25SGPASS, the ice dispensor, after getting ice kept running trying to dispense ice, when i would push the light switch in (door closed) it would run, door open stopped. also the freezer motor is running but not keeping the food frozen. After taking the door switch out and putting it back in (light works connection is good) the dispensor stoped trying to put ice out the door but now it won't dispense water or ice and the food is thawing out. Any help is greatly appreciated thank you.
  • 1 more comment
  • tayredd Sep 07, 2010
    thank you for the reply, however, i don't understand why the ice maker would keep trying to dispense ice out the chute when the door was closed then by pulling the light swith out an puttting back in it stop but now it won't dispense ice or water? Seemed as if it stoped keeping the food frozen shortly after this began?
    i have a ge fridge model GSS25SGPASS, the ice dispensor, after getting ice kept running trying to dispense ice, when i would push the light switch in (door closed) it would run, door open stopped. also the freezer motor is running but not keeping the food frozen. After taking the door switch out and putting it back in (light works connection is good) the dispensor stopped trying to put ice out the door but now it won't dispense water or ice and the food is thawing out. i don't understand why the ice maker would keep trying to dispense ice out the chute when the door was closed then by pulling the light swith out an puttting back in it stopped, but now it won't dispense ice or water? Seemed as if it stopped keeping the food frozen shortly after this began?
  • tayredd Sep 08, 2010
    thank you for the response, however it was not the ice maker, it was the main control board. there isn't any doubt the board was fried for there wasmelted pieces and scorch marks on it also i watched as the repairman pulled off the cover and we both saw it at the same time. I think both experts were hung up on the ice maker and just couldn't get past that. regardless thank you for the responses.
    President:
  • 1,796 Answers
Hi!!
Click on the following link to get videos on how to identify and troubleshoot GE Refrigerator's Ice Dispenser problems.
http://www.geappliances.com/videos-media/?vuuid=hcs72kzj&categoryid=13814
If you need further assistance, just post a comment.
Gppd Luck!! Don't forget to rate this post!!
Posted on Sep 07, 2010
  • Rene J Solis Sep 08, 2010
    Thank you for the feedback, I would like to mention that when you request an opinion from another expert, we do not get to see previous responses, only your original question, so we got to start from the bottom. Furthermore, we advice and encourage our customers to perform small repairs that do not require specialized technical knowledge. For major repairs, we always recommend to be performed by a professional.
    Thank you for using FixYa. Have a good day!!
  • 3,083 Answers
Here is information about the ice problem:
http://www.geappliances.com/search/fast/infobase/10000594.htm
This website lists the possible things that will keep it from getting cold enough:
http://www.repairclinic.com/Refrigerator-Troubleshooting#Coolingispoor
It can be many things, since there are many operational parts working together, but I would check your condenser coils, and make sure the fan is running first, then troubleshoot the problem.
Good luck, hope this helps, and thanks for using FixYa.
I have a Kitched Aid SxS fridge,model KSBS25TNBL02. I changed the water filter, cleaned everythng, etc. It makes water and ice jst fine, but when I press the Ice dispenser, no ice comes out. I can look...
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
Aug 21, 2012 | KitchenAid Refrigerators
The water dispenser on my GE fridge, model bss25jsrss, doesn't work. There is water in the lines, and the lights in the front work, but when I try to get water or ice nothing comes out.
There is a simple switch behind the push lever which activates the water/ice dispenser circuit. Sometimes these switches are poorly engineered to the lever with an adhesive or plastic rod which will break away. This is the first place I would look for a culprit.
Sep 25, 2011 | GE Refrigerators
GE REFRIGERATOR'S ICE DISPENSOR PROBLEM
CAN U TELL ME WHAT YOU DID TO FIX THIS PROBLEM. I AM NOW EXPERIENCING THAT EXACT PROB!
Nov 09, 2009 | GE Refrigerators
GE fridge fan clicks, ice dispenser not working
Main control board problem . Pt # WR55X10656 . The freezer fan motor , works off DC voltage . The board is not giving it enough voltage . The main board , also controls the dispensor board .
Sep 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25QSTSS no lights working on the water and ice dispenser. No light working, no ice dispenses or water. Tried unpluggin no luck
I would remove the bottom kick panel ( 1 screw on each side ) and follow the wires to the receptical ( about 5 inches from bottom of door ) . Wiggle the receptical , to see if any of the dispensor lights come on . Also try pushing the wires into the receptical farther . If still no lights , then the main control board behind the refrig ( behind 8" X 10 " panel ) is probably bad . No communication between the main board and dispensor board . Part number WR55X10942 . I have yet to come across a bad dispensor board , so , replace the main board first . If the receptical process doesn't work .
Sep 18, 2009 | GE GSS25QSTSS Stainless Steel
Hotpoint fridge dispenser works on water but not ice
If the little green lites show up , you do not need a circuit board . If you get a hum or buzzing noise when pushing for CRUSHED ice , then the auger motor is frozen up . Remove the ice bin and use a hair dryer directly on the forks which turn the dispensor . The heat will transfer into the motor , defrosting the armature . Try closing the freezer door ocassionally and pushing the arm to test if forks turn .
Aug 09, 2009 | GE Refrigerators
GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE Fridge Not Dispensing water
First place to start is in the fridge. Look behind the crisper drawers for the water tank. It may have frozen at the outlet line. Try thawing it out with a hair dryer or a heat gun, being careful of course not to melt anything.
Dec 13, 2008 | Refrigerators
GE GSS25SGPSS Side by Side Refrigerator Logo
175 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
