Question about Philips SA5125/37 MP3 Player
Sa51xx go gear
My MP3 player will not turn on. I tried the device manager, that didn't work either.
  • 3 more comments
  • Anonymous May 16, 2008
    how do you put it into recovery mode?
  • slygamer Aug 05, 2008
    My philips Shutdown and wont tern back on. I tried the Philips Device Manager but it wont fix the mp3, what do i do?
  • Anonymous Aug 07, 2008
    my phillips will not turn on its connected to my comp and now it will not go back on..
  • Anonymous Aug 12, 2008
  • David Simpson May 11, 2010
    Did you put the player into recovery mode when connecting, or did you just connect it as normal?
    This can make a difference.
  • 476 Answers
Cleared
Posted on May 28, 2008
  • 8,596 Answers
Recovery mode - disconnect player from computer, turn off player, hold in volume +, reconnect player to computer while holding volume +, continue holding volume + for up to a minute until Found New Hardware Wizard pops up
Posted on May 22, 2008
Hi My Phillips go gear 8gb turns off repeastedly with this message 'File systems error " What do I do???, thanks
Because of you didn"t define the exact type of your player I can give you this link. Please visit here:
http://www.support.philips.com
At first use the "find your product" option and then you can download the device manager program.
Launch it and select the "repair device" possibility and in this way you can fix this problem.
If you got stuck you could get all information, especially in the FAQ, to help you at this page also.
Good luck, good working!
Thanks.
gylacz
Jun 17, 2011 | Philips Audio Players & Recorders
My GO gear Mp3 player wont be detected on any computer. even if you install the hardware, it wont still detect.
if your player don't detect . also don't detect with Philips Device Manager
try to download this driver for it usb 2.0 ADFU Driver .
i worked with 7 and in system device manager show "uknown usb device" but in XP show this "usb 2.0 ADFU Drive" and also the Xp itself install it . if your windows dosent have this so go on to download it manualy . then use philips device manager to repair it . i do it myself and it worked
Dec 13, 2010 | Philips GOGEAR SA6045 MP3 Player
I have a Go-Gear MP3 4GB player,where can I get a user manual/instructions
i can help you with this go gear mp3 4gb phillips pmc7230 SA51XX SA60XX SA93XX just let me know wich one you need help and i will help you and pls rate my help.
Feb 06, 2010 | Philips Audio Players & Recorders
It won't connect to my PC, says driver not found
If the volume + method didn't work, then there is some feature about your PC config that is not going to work with this player. you can try the FAQ method on Philips website for when the PC is not recognizing the player, but I've never seen a case where it was successful.
Jul 28, 2008 | Philips SA5125/37 MP3 Player
Mp3 player
please help my player to work again
Jun 05, 2008 | Philips GoGear HDD6330 MP3 Player
Go gear wont hold charge
There is a program that came with the installation Cd called Philips Device Manager. You can download it from www.usasupport.philips.com if you lost the CD. Use the Philips Device Manager to repair the player. If the device manager will not repair the player, then try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
May 17, 2008 | Philips GoGear HDD6330 MP3 Player
Mps3 sa51xx
If you find that the GoGear will not load the firmware upgrade, then:
1) Backup all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
You will now be able to load the upgrade
Also, if the Philips Device Manager says that your device is already updated with the latest software, then go to: www. usasupport. philips. com,and enter in your model number, SA5125/37, on the next page select SA5125/37 (not "37B"), on the next page click on software and drives, and click on Firmware Upgrade Software - this will ensure that your player really has been given the most current firmware upgrade
-Tha Mp3 Doctor
Mar 24, 2008 | Philips SA5125/37 MP3 Player
Still gay
did you check the side to make sure you didn't have it locked up
Mar 23, 2008 | Philips SA5125/37 MP3 Player
Memory corruption
My mp3 player Philip SA51xx 2gb says "memory corruption please repair it now" can I ask your hepl to fix the problem thank you
Dec 24, 2007 | Philips SA5125/37 MP3 Player
Philips SA5125/37 MP3 Player Logo
298 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
