Question about Cameras
I need a SONY VPLS500U ( VPL-S500U ) Service Manual
How do I reset the lamp timer on the Sony VPL-DS100?
Yes, press RESET, <, >, ENTER keys on remote simultaneously to reset lamp timer. Display of lamp will also change to zero.
Make sure projector is just plugged in and should not power On (in standby mode) to reset lamp timer.
Jun 03, 2010 | Sony VPL-DS100 Multimedia Projector
How to rest lamp timer vpl-es4 - reset < > enter - doesn't seem to work
http://www.kavena.se/fileadmin/uploads/downloads/Sony/Projektorer/VPL-EX4/Protocol%20EX4.pdf
That's the link, to reset this unit, it seems you must hook, up with an RS232C cable, and "Talk" th the Projector, You simply hook up, using any terminal Program. such as, Hyperterminal. I think you need to get a manual.
http://www.nodevice.com/user_manual/sony/projectors1/vpl-es4.html
I looked but could only find, pay for links, for the service manual. You really need this if you own anything it is worth any money, as in it is the information, the the engineers that service them, use to troubleshoot and fix, special codes, and settings the lot. So it is a must have.
Apr 06, 2010 | Sony VPL-ES4 Projector
Tel me plz the default service mode ,of Sony projector vpl-es3
Hi there. To Service Mode in SONY VPL-ES3 is, ENTER-ENTER-LEFT-ENTER. watch out!!!, Don't change anything if You don't know what are You doing.
Nov 25, 2009 | Sony VPL-ES3 Multimedia Projector
How can vpl-cx61 sony projector to get an HD signal?
1080i should need HDMI Or DVI port and check ur manual as ur projector native Resaluton is 1920*1080 !!!
Jun 14, 2009 | Sony VPL-CX61 LCD Projector
Sony
Turn on projector and Press following button on remote in following order for less then 5 seconds..
RESET, <==, ==>, ENTER.
Above procedure is written in user manual page-49
If you need user manual of VPL-HS50, click Sony Support.
Feb 11, 2009 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Service Manual HS51A
Here is the manual...
https://docs.sony.com/release/VPL-HS51A_HS60.pdf
Mar 23, 2017 | Sony VPL-HS51A / VPL-HS60 Multimedia...
VPL FX50 Procector dead
it might be the main power supply box inside that gave up since the fuse aint blown there isint a big issue i recomend you take to a servive center and ask them to see if the power supply is good or went bad
Sep 15, 2008 | Sony VPL FX50 Multimedia Projector
Cameras Logo
46 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
