Question about Singer 7436 - INGENUITY
Singer ingenuity stitch selector stuck
Seems the stitch selector beeps and stiticing will not occur, I can thread a bobbin and the needed goes up and down then.
  • SUNNYFL May 22, 2008
    IT SOUNDS AS IF THE BOBBIN IS HITTING SOMETHING AND THE NEEDLE SEEMS TO BE STRIKING SOMETHING, IT WILL NOT SEW
  • 323 Answers
Pull the button hole lever all the way down, then push it all the way back up. Select your pattern and it should work.
Sewman7
Posted on May 13, 2008
When sewing, mechanism sometimes binds. Bigger problem is when finished stitching, the hand wheel binds completely. Is there a mechanical problem or someplace to insert oil?
Hello Griff
Very likely the thread is kind of bound up in the bobbin area. Just turn the hand wheel a bit forward and backward several times -after you lift the foot. Apply a gentle pull on the fabric and it should "break" loose. Often teh thread is still stretched around teh bobbin and this releases it.
Feel free to reply to this post if this does not do it.
Moses
Dec 07, 2014 | Singer 7436 - INGENUITY
The bobbin case on my singer feaherweight is stuck
Sounds like thread or lint has got on the centre spindle of the hook. and jammed bobbin inside case. unclip race and remove hook and bobbin assembly. remove feed dogs and all tangled thread. machine should then be freed up
Feb 05, 2014 | Sewing Machines
Sews about 5 stitches then stops and beeps. stitches look fine, just will not keep sewing
count the beeps and refer to the owners manaul as for troublshooting tips
Dec 03, 2013 | Singer 8780 Sewing Machine
Hello. I own a Singer 4423 Heavy Duty sewing machine. It has been working fine overall, but today it is giving me problems with jamming. At first it jammed underneath the plate and created a huge ball of...
Make sure thread is not laying across the bobbin when you look down into the plastic slider that covers the top loading bobbin case. The bobbin on mine I observed was loose in the case so that as the machine ran, eventually the bobbin thread would jump out of the stitch finger (the silver piece to the far left of the bobbin case, past the tension slots). I solved this problem and so can you! Take the extra felt spool pin felt in your accessories kit that came with the machine, remove bobbin from case and drop this small felt circle into the bobbin case. Replace bobbin. On the 4423, the bobbin thread goes counter-clockwise and drops into the tension discs, and goes all the back until it falls into the space left of the silver stitch finger. Make sure take up level raised all the way up! Then pull the needle thread toward you until bobbin thread comes all the way up. If you start sewing and you actually can SEE the bobbin thread laying across the bobbin, STOP and tethered because that would mean your thread did not slide all the back behind the silver stitch finger--however, I assure you, if you go one step at a time, you did it correctly! You will be smiling in no time! Why? The felt helps to make the bobbin rest in the correct position to keep it from jumping out of the groove. I hope this helps you.
Jimmy
Jul 29, 2011 | Singer 4423 Sewing Machine
My wife is frustrated with her sewing machine and just threw the material down in disgust...there seems to be a problem with the tension or something like that. She cant get a simple stitch without the...
I have a simple and I have better luck when I use a SA156 metal bobbin. Another thing, has she watched the cd that came with the machine? This machine is a little touchy as far as threading goes, I have been sewing 50+ years. Usually, it is in the top threading that causes the problem. If, she has a question, she should call Singer at 1-800-4singer and they will walk her through all of the threading and other troubleshooting strategies. Good luck. Hope this helps you.
Oct 04, 2010 | Singer 3116 Simple
When I do a reverse stitch, the bobbin thread bunches up and makes a mess. Any ideas as to why or how to fix this?
Call Singer for customer service at 1-800-4singer, Sounds like your reverse lever is stuck or you have it set on a zero length stitch. I did that once and couldn't figure it out right away, so hopefully that is the problem. Good luck to you
Sep 12, 2010 | Singer 7436 - INGENUITY
Singer futura beeping every 8 stitches can you solve this .i have changed needles bobbin cases but still doing it but is sewing ok just stops to beep
Make sure your thread goes under the plate of the carrousel. If not the machine think is not threaded and it beeps. Thread the machine with your left hand and Pull the thread with your other hand to make sure it "clicks" to every part of the machine.
Another important detail is to add thread nets to your spool. After some used the tension of the machine is affected and the nets help the slippery thread to be pulled by the machine correctly and avoiding the beeping.
Feb 07, 2010 | Singer CE-200 Quantum Futura Computerized...
Topand bottom stitches are not even
Could be a tension issue.
Try this to see if it helps:
Remove top thread.
ALWAYS RAISE the presser foot and rethread from the beginning.
Start the top tension set at the midway point and then adjust.
Check that the bobbin is threaded and installed correctly.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Apr 22, 2017 | Singer 7436 - INGENUITY
Singer advance 7422
My Singer 7422 seems to be jammed. When I start to make a stitch, the thread from the needle gets caught on something on the bottom and the thread goes over the bobbin.
Jul 16, 2008 | Singer 7442 Mechanical Sewing Machine
Warning tone?
I have the same problem! help!
Jun 30, 2008 | Singer 7436 - INGENUITY
Singer 7436 - INGENUITY Logo
129 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
