Question about Hitachi 53UDX10B 53" Rear Projection Television
No Picture good afternoon, I can see the closed caption words, and the channel information. I can also hear everything that is happening on that channel, yet there is no picture coming through
  • Hitachi Master
  • 8,617 Answers
Try resoldering the vertical output IC. thats a common fault when the on screen display works but no pic.
Posted on May 13, 2008
Text is coming up on screen on all free to air channels. How do I get rid of it? Thank you
Hello, Margaret -
By text on the TV screen, do you mean closed captioning text? Is the text the same wording as what is being heard? If so, that is closed captioning (for the hearing disabled.)
The button for closed captioning on your TV remote was probably pressed inadvertantly. Locate the closed captioning button on the remote, and while the TV is on, press it to see if the text disappears.
Dec 21, 2017 | Televison & Video
How to turn off closed captioning without original remote
You must have its remote control to close the closed captioning function.
Dec 24, 2012 | Memorex MT2274 27" TV
Okay, have Hitachi 1080 HD. Called several times to Customer Service but they couldnt help. Cannot get the words in English to appear on screen for hard of hearing.
Look in the tv menu for SET UP or AUDIO options.
Look for CAPTION VISION and set to CC1.
Now exit the menu screen.
Now use the INFO or DISPLAY button on the remote to activate the closed captioning.
It should say something like CC1 ON once you get it right.
That should be about it.
Note that not every single channel has closed captioning for every single show and that the words usually take a few seconds to show up on the screen when you change to a new channel.
Good luck, hope this helps. Keep us updated on your progress.
Jan 21, 2011 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
How do I get closed captioning on a Samsung TV model TXJ2754?
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
 Different channels and fields display different information, such as additional
languages or supplemental information
Nov 23, 2010 | Samsung TXJ2754 27" TV
Cannot turn CC off.
Features preferences
Caption service
This allows you to select the Closed Captions service levels of analog
broadcasting to be displayed.
Closed Captioning allows you to read the voice content of television
programs on the TV screen. Designed to help the hearing impaired, this
feature uses on-screen ‘text boxes’ to show dialogue and conversations
while the TV program is in progress. Captions will appear on the screen
during captioned broadcasts.
& Select Captions service.
é Press the cursor right.
“ Select the desired Caption service:
• CC 1, 2, 3 or 4
Dialogue (and descriptions) for the action on the captioned TV program
shows on screen.
Usually CC 1 is the most used. CC 2 may be used for alternate languages
if they are being transmitted.
• T 1, 2, 3 or 4
Often used for channel guide, schedules, bulletin board information for
Closed Captions programs, news, weather informations or stock market
Not all Caption services are necessarily being used by a TV channel during
the transmission of a Closed Caption program.
Features menu
& Select Features in the TV Settings menu.
é Press the cursor right to enter the Features menu.
“ Select the menu items with the cursor up/down and adjust the settings
with the cursor left/right.
Closed captions
This displays the transmitted CC- or CS-text on the screen according to
your chosen CC or CS service in the Setup, Features preferences menu,
This text can either be permanently displayed (assuming that the
service is available in the broadcast) or only when mute is active.
& Press the cursor right after having selected Closed captions.
é Select On, Off or On during mute.
Oct 28, 2009 | Televison & Video
I get a black square on my screen after about 30 seconds when I tune to some channels. Does not do it on every channel. If I tune to another and then back it will be gone but soon reappears. jd
This sounds like your closed caption has been activated. There are several closed caption options that aren't used for anything, and if you select one by pressing the cc button on your remote by mistake, it will cause the problem you're having. To fix the issue, locate the cc, ccd, or closed caption button on your remote. Press it until you the option "off" appear on the screen. Once you see "off," simply stop pressing the button and the word "off" will disappear.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 13, 2009 | RCA F27442 27" TV
Misspelling on Closed Caption
Yes - perhaps yoga, or a nice massage. You have some seriously uptight members!! It is either a computer error in translating a word from speech, or a human mistyping a word.... but it's all at the broadcast end, you really have no control over it. Try looking up "closed captioning" on Wikipedia.... and relax, the world is not perfect :)
Mar 04, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Black square picture in the middle of the regular picture
Make sure your closed-captioning is set to "off" or to "caption 1" in the setup. You have it set to one of its "text" modes right now, and what's happening is the caption decoder is blanking the screen where the text would go if there was any. You're probably noticing this on some channels but not all - it will only show up when the channel has closed-captioning being broadcast.
The v-chip locking is a separate problem. If you can provide the make and model of TV, I'll see if I can find how to reset the lock code.
Nov 16, 2008 | Televison & Video
Picture blacked out
Your Close Caption is turned on. Search in your menu for Captions, and turn it off.
Nov 14, 2008 | Televison & Video
Black screen but have sound
If it is not a hardware problem, it is most likely the Closed Captioning system.
If you can still see the on-screen menu, go into your TV's menus and disable Closed Captioning.
May 14, 2008 | Toshiba 36AX60 36" TV
Hitachi 53UDX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
