Question about Norelco Health & Beauty
I need to remove the saving rotating heads for cleaning, how do i go about this ? I have the norelco arcitec - Thank you
  • Norelco Master
  • 1,610 Answers
The blades on Arcitec models can not be removed from their holders. This type shaver is the only model type that Norelco has made with this very poor design.
The only way to clean them is to run the shaver heads in shaver cleaner or under very hot water or in a solution like rubbing alcohol. If that doesnt do it, you will have to replace them. Replacements can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Posted on Sep 09, 2010
I need a users manual for my philips norelco arcitec razor users manual so I can remove the cutter blades for cleaning
The user manual will not help you with this because the Arcitec models were designed so that the cutters could NOT be removed to be cleaned. This is a major disadvantage with the Arcitec models as you can not disassemble the heads to thoroughly clean them. This causes you to have to replace them more frequently.
You can try running the shaver head in a dish of rubbing alcohol to try to loosen the build-up and rinse it out but that's about all you can do.
If you need to replace them, you will find at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Oct 30, 2011 | Norelco Arcitec Electric Shaver -...
How do i clean the blades. I don't know how to unfasten them so i can clean them
The Arcitec series shavers have a very poor design and shaver heads can not be disassembled like the older model that you had. The blades can not be removed from the assembly that contains them. The only way to clean them is to run them under hot water or rense them in an alcohol solution. Unfortunately, this method still leaves much to be desired.
Many users of the Arcitec models report having to change the heads twice as often because of this.
Complains can be made to Norelco customer service at 1-800-243-3050
If replacements are needed, you will find then at shaveroutlet.com. See link below
May 14, 2011 | Norelco Arcitec Electric Shaver -...
How do you remove the shaving heads on the Arcitec for cleaning or replacement?
The Arcitec series shavers have a very poor design and shaver heads can not be disassembled like the older model that you had. The blades can not be removed from the assembly that contains them. The only way to clean them is to run thm under hot water or ren them in an alcohol solution. Unfortunately, this method still leaves much to be desired.
May 09, 2011 | Philips arcitec 1060 Electric Shaver
How do you get the rotary heads off the shaver to clean or change them?
The blades can not be individually removed on the Arcitec model shavers. Instead, you must replace the entire head assembly. It simply pulls straight off. See diagram at the link below
http://shaveroutlet.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/f/i/file_34_1.jpg
This is a very poor design because you can not remove the individual blades for thorough cleaning. This makes replacement necessary more frequently than older Norelco shavers. If you need replacements, you will find them at shaveroutlet.com. See link below
Apr 25, 2011 | Norelco Arcitec Electric Shaver -...
How do I clean the rotating cutter heads? On the old one I had, I simply unscrewed the center post and removed all of the parts and cleaned them. I cannot figure out how to take the heads out of my new...
Apr 23, 2011 | Norelco Arcitec Electric Shaver -...
Need instructions for changing Arcitec razor head
You look at Manual Norelco Arcitec Electric Shaver.
http://download.p4c.philips.com/files/1/1050x_22/1050x_22_dfu_aen.pdf
And you need to Norelco Arcitec Electric Shaver replacement heads is Norelco RQ10 shaving heads.
Nov 20, 2010 | Norelco Arcitec Electric Shaver -...
How to remove the blades on a norelco arcitec razor
On Arcitec shavers, the blades can not be removed from the head assembly. This makes it difficult to thoroughly clean them and they must be replaced reqularly because of this.
If needed, you will find replacements at shaveroutlet.com.. See link below
Nov 18, 2010 | Norelco Arcitec Electric Shaver -...
Can not get blades out of head to clean blades & foils
The blades can not be removed from the head assembly on Arcitec models. This is the way they were designed from the manufacturer.
The only way to clean them is to rinse them with HOT water or soak them in mild liquid like rubbing alcohol.
If that doesn'tget them clean, you will need to replace them. You will fin replacements at shaveroutlet.com. See link below
Oct 12, 2010 | Norelco Arcitec Electric Shaver -...
How long should heads last on Norelco Arcitec razor
Norelco suggests changing the shaver heads every 12 months for best performance. If you need to buy some, you will find them at shaveroutlet.com. See link below
Aug 20, 2010 | Norelco Arcitec Electric Shaver -...
My razor blade heads no longer rotate but when removed the mechanism underneath is spinning normally - the razor is clean and fully charged.
It sounds like your heads are damaged and need replaced. You can not repair theheads if damaged. You will find replacements for Arcitec shavers at shaveroutlet.com. See link below
May 06, 2010 | Norelco Arcitec Electric Shaver with Jet...
Health & Beauty Logo
171 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
