I have toshiba A 105 S4547.My laptop immediately automatic on even i had shut down it or i plug adaptor jack!What i should do?Thanks
    Guru:
  • 689 Answers
Try holding the power button down for longer for a clean shutdown
Posted on Sep 07, 2010
Power wont turn on..battery led flash orange
Remove battery. Maybe faulty? Try another cord/charger with the EXACT same specs. Reseat the Memory Mods. has the AC jack been damaged by pulling on the cord? Try plug in and at the laptop's AC jack "wiggle" the AC jack plug. Any change?
Jan 04, 2013 | Toshiba Satellite U305-S2804 Laptop
!!!no reaction on plugging the ac adaptor.!!!
Sound like the LCD screen's inverter is causing an short/overload and the power adapter is shutting down (thermal cutout).
Remove the LCD screen and connect an external monitor, power up the external monitor first and the boot up the laptop. The video should automatically on the external monitor. If the display on the external monitor is OK then the fault could be the inverter which is located at the bottom of the LCD screen between the hinges.
LCD screens and Inverters for your laptop maybe available from this WEB site.www.lcdparts.net
Apr 13, 2012 | Toshiba satellite c660
HHello there,\r\n I have a very strange problem
i think the major problem is the "immediate stop", if we properly analyze this symptom we can get the solution. when we plug the AC/DC adapter to the laptop, it shuts down; so there are two major causes:
  1. OVP protection problem (Over voltage protection)
the 19V of the adapter is not properly regulated; we need to replace te AC/AC adaptor
2. OCP protection problem (Over current protection) if the power jack is broken, it cause a bad metal to metal contact, in this case the transient current increase fastly, the power managment IC go to the standby mode; to protect all other device ( cpu, memory, graphic controller etc) , only two voltage are present: 3.3V always on and 5V always on, we can charge the battery. to solve the problem, we need to replace the power jack located on the laptop motherboard. here the picture of the power jack:
Feb 02, 2011 | Toshiba Satellite A305 A355D L200 L305...
Does the toshiba satellite a105-s4547 have a built in mic
Hi, As to my own surprise: no. This laptop doesn't have a built-in microphone, though it does have a microphone connection. You can buy a cheap mic and plug it into the mic jack.
Cheers, Ed
Nov 22, 2009 | HP Pavilion dv1000 Notebook
Shutdown and DVD Player problem
Hi, as this is a new unit I recommend you return it to your point of purchase and have the problem addressed under waranty.
regards mistyman
Aug 14, 2008 | Toshiba Computers & Internet
Toshiba Satellite A105 - S4547, screen goes black when using the battery (not plugged in)
check your control panel/video to ensure device driver is current. use driverguide.net.since when on battery no pic suggests that the battery life span is shortened. Recharge and check how long the battery level lasts when doing normal internet or document reviews. Video playing drains the battery at a high rate, when battery is already low, virtual memory tries to assist.
Jun 28, 2008 | Toshiba Satellite A105 Notebook
Starting up problem
I had the same thing. I was passed down this laptop to checkout for a friend. After overviewing the system turns out the processer board got loose. Pushed it back in and she fired up..
Issue was green power led then 2 short orange flashes that repeated untill I discoved the issue.
Feb 22, 2008 | Toshiba Satellite A135-S4427 Notebook
Laptop doesnt start
there must be a problem with the voltage output of the adaptor... because many modern laptops react by shutting down when they encounter voltage ranges that they r not supposed to...
Feb 01, 2008 | Toshiba Satellite A45-S151 Notebook
Help
sounds like you have an intermittent problem with your AC adaptor or dc input jack. Does the light on the AC adaptor light up when you plug it in? If it does then your dc input jack may be faulty. If the light on the ac adaptor does not light then replace the ac adaptor. Good Luck!
Sep 16, 2007 | Toshiba Satellite M30-S350 Notebook
Computers & Internet Logo
David Payne
David Payne
