Question about Garden
Black and decker VP450 battery garden sprayer. not holding pressure.
  • 294 Answers
Check large rubber "O" ring under pump top and outlet hose. If that is OK then probably their is an internal leak in a hose. It can be fixed if you are handy with vacuum tube or fuel hose purchase from local auto supply house. The internal hoses are 1/4" and 3/8" or metric equivalent. The pump head comes apart by unscrewing Philips head screws and separating the housing halves. Take a photo with your digital camera before working inside unit so you will remeber how it fits back together.
Posted on Jan 25, 2011
Model 030XPEG. Why won't sprayer pressurize?
Roundup 181538 Sprayer Parts Repair Kit : Lawn And Garden
www.amazon.com > ... > Sprayers
Amazon.com, Inc.Amazon.com : Roundup 181538 Sprayer Parts Repair Kit : Lawn And Garden ... Kit with Extension Wand and Adjustable Nozzle(Only for models 1991A, 1992A, .
Oct 08, 2015 | Gilmour Garden
Roundup 2 Gallon Sprayer -- must have exceeded pressure. Now it will not hold ptessure. Gasget seal seems OK is there any "reset"
There is a built in relief valve that is not keeping the pressure in...
these are very cheap plastic valves and so there probably is no fixing it...
I would buy another roundup with the sprayer and then dump the contents from the bad one into the new one ... the stuff does not go bad...
heatman101
Sep 18, 2010 | Garden
Weee killer leaks from my Gilmour sprayer finger
Im pretty sure that is all it is. The pressure is by how many times you pump it up. Its just on or off. Sounds like It needs to be cleaned real good, and put soap in it befor you put it bak together. Also there is a screen if you hold the handle and turn the trigger part and unscrew it.
May 10, 2010 | Gilmour 1 Gallon Lawn & Garden Spray Tank...
Trouble with cleaning solution in my Black & Decker Power Washer
usually you have to lower the pressure at the lane for the detergent to come through as it works on a venturi principle.
can you twist or pull back on the lance to lower the pressure?
if you can take out the lance extension and run the machine you will see if that is tha cse as it should then pull deterrgent into the pump.
alternatively take the high pressure hose off the front off the machine and run it, this should also pull detergent in. if not you have an obstruction in the detergent pipe, blocked filter, regulator not open enough. or a worn injector.
Jul 19, 2009 | Garden
Black & Decker 24 volt battery will not hold a
Click on the link below and you will find replacments
You need to work out if the cost of two batteries is cheaper than a deal on a new drill pack
http://www.svcvacuum.com/black_and_decker/black_and_decker_battery.htm
Jun 01, 2009 | Black & Decker Black And Decker FS24C...
I had the same problem, the batteries are burned out, I know you can replacements at Home Depot but if you can wait try the interenet.
"Google" what you want.
Mar 01, 2009 | Black & Decker Black And Decker FS24C...
Immediate pressure loss
your dip tube inside the tank has come loose or has a leak near the top. instead of fluid being pushed up the dip tube into the wand hose the air in the tank is just escaping. You will have to remove the wand hose and figure out where the leak is and fix the dip tube.
Nov 18, 2008 | H.D. Hudson 2g Yard N Garden Sprayer
How do I remove the battery from my Black and Decker CMM1200 lawn mower? Thanks
I have an older model CMM625, but I suspect that the method is similar. There should be some screws that hold down the upper deck to the lower one. On mine the screws are in the back and there are tabs in the front that holds the upper deck to the lower. Once this is removed, you can see the battery and it's connections and hold down bracketry.
Oct 06, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
141 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
