Question about Olympus FE-200 Digital Camera
How to speed up shutter speed - Olympus FE-200 Digital Camera
  • 152 Answers
Shutter speed
Like most point&shoot cameras, the A3100 does not give you direct control over the shutter speed. You're expected to just point the camera and shoot, without worrying about such niggling details.
You can gain some control over the shutter speed by changing the scene mode. For example, portrait mode attempts to reduce the depth of field by opening the aperture, which results in a faster shutter speed. Conversely, landscape mode attempts to increase the depth of field by closing the aperture, which results in a slower shutter speed.
Dec 20, 2013 | Canon PowerShot A3100 IS Digital Camera
Changing shutter speed
Like many point&shoot cameras the JZ300 doesn't give you direct control over the shutter speed; you're expected to just point and shoot.
You can indirectly affect the shutter speed by changing scene modes. For example the sports mode will try to use faster shutter speeds while the landscape mode will narrow the aperture for greater depth of field resulting in a slower shutter speed.
Mar 03, 2013 | FUJIFILM FinePix JZ300 Digital Camera
I have a D60 and when using my new lighting kit if the aperture is faster than1/200 it creates a blackout across part of the image due to the mirror. Any solutions?
It's not the aperture, it's the shutter speed. It's also not the mirror, but the shutter.
The camera's fastest shutter sync speed is 1/200. You must use a shutter speed no faster than that. Due to the construction of the shutter, the frame is not fully exposed simultaneously at faster speeds and thus part of the image is blacked out.
Using a flash, the amount of light is controlled almost exclusively by the flash; the exposure is controlled by the aperture and the shutter speed is all but irrelevant.
Feb 15, 2013 | Nikon D60 Digital Camera
How to set shutter speed in fuji fine pix S2940
That depends on the exposure mode. In any of the automatic point&shoot modes you have no control over the shutter speed, the camera sets what it thinks is the proper shutter speed. In the P (Program AE) mode you can adjust the shutter speed by pressing the +/- button. In the S (Shutter Priority) and M (Manual) modes you control the shutter speed by pressing the +/- button and then using the cursor-up/down buttons.
Apr 25, 2012 | FUJIFILM S2940 Digital Camera
How do I change the shutter speed on the Fuji S8000fd
Set the camera to Shutter Priority AE by turning the mode dial to S. Press the +/- button to open the setting screen, then press up/down to select the shutter speed.
You control the shutter speed the same way in Manual mode. You also select different shutter speed/aperture combinations the same way in Program mode.
You can indirectly control the shutter speed in Aperture Priority AE by changing the aperture and letting the camera set the appropriate shutter speed.
May 27, 2010 | Fuji FinePix S8000fd Digital Camera
Adjust shutter speed
On most indoor shots the shutter speed will normally be 1/30 if you need or want it to be faster than that the only way to do that with this camera is to set the ISO to a higher value. Page 29 of your user manual explains how to set the ISO value for the camera to allow for faster shutter speeds.
May 01, 2009 | Olympus Stylus / mju 1050 SW Digital...
Shutter speed
When you set the camera to "Full Manual" mode, you should be able to dial in your shutter speeds, for most film cameras, including the N55 30 Seconds is the slowest shutter speed. If your camera features a "Bulb" mode, then the shutter stays open as long as you are holding down the shutter release button.
Apr 12, 2009 | Nikon N55 35mm SLR Camera
Shutter Speed
If your shutter speeds are off you can compensate by changing the film speed setting,
quicker ( than should be ) shutter speeds require you to set the film speed to slower ASA .. KC
Sep 01, 2008 | Canon EOS-AE-1 35mm SLR Camera
Shutter speed
shutter speed has nothing to do with battery power. If you have a SLR camera you use the shutter speed option when you want to have control of the shutter speed, slow shutter speed means if your taking a picture of a waterfall and you want to see the actual droplets you set a slow shutter speed, if you want it to look more smooth/flowing you set a faster shutter speed, if you do not have a SLR camera you probably dont have much say so in shutter speed...
May 28, 2008 | Nikon FE 35mm SLR Camera
Slow shutter speed
from the manual: Using Shutter-Priority Mode 1. Set the mode dial to S (shutter-priority) and a yellow arrowhead on the screen points to the current shutter speed. Press the jog dial and the current shutter speed turns yellow. 2. With the current shutter speed displayed in yellow, rotate the jog dial to select the speed you want to use. 3. Take the picture. If a workable aperture isn?t available for the shutter speed you?ve selected, the shutter speed indicator on the screen flashes when you press the shutter button halfway down. You can use the setting as is, or press the jog dial down to select the shutter speed again and rotate it to select a new shutter speed.
Jun 03, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Olympus FE-200 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
