Question about Bodelin ProScope Microscope
Proscope hr lens stuck
Someone forced a lens onto the hr; subsequently, the lens is stuck and the lens release button is disabled.  Any suggestions?
  • Anonymous Jul 06, 2008
    proscope lens is stuck
  • techaws Oct 21, 2008
    same problem
See:
http://www.bodelin.com/lens_jam/
Best,
Dean
Posted on Apr 18, 2009
Lens become stuck
Do you know what caused the lens to get stuck? Did someone drop it, or was the camera a long time not used?
Most of the time this is a mechanical problem. At least is you still can switch the camera on and get into the menus and when you still can view pictures taken.
In rare occasions, the blockage can be released with a little shock to the camera. Never use force on a camera, or tick something against a camera. you could slap your hand, holding the camera, but not hard. But when the blockage is caused by a broken gear, noting will help. The camera should go to a repair store.
Before you do, be sure the battery is fully charged. An old battery, could cause trouble too. More often than you can think of.
Nov 24, 2013 | Fujifilm Finepix S2980
We installed a lens onto a N2020 that snapped right in and now it won't come off, any suggestions?
There is a lens release button to the right of the lens mount - make sure it is pressed fully before trying to rotate the lens to remove it. When you press the release button, there is a little pin in the lens mount that is retracted to let the lens turn. If you do that and the lens still does not rotate to be removed (and you are rotating it the opposite direction that you mounted it) then the release button assembly is probably broken and the camera will need servicing.
Nov 07, 2010 | Nikon N2020 35mm SLR Camera
Rewind stuck on reverse
Hi Luce n Steve, To quote JC at Photo.Net: "sometimes the rewind function "gets stuck" if the camera thinks a previous rewind did not complete successfully. The solution is to reset it by forcing a rewind operation. Just press the two rewind buttons simultaneously: on the left side of the lens and just behind the shutter release. (They are marked and the manual explains how to force a rewind.) I did exactly this, and my next roll of film loaded without problems." Hope that help you folks.
Aug 22, 2010 | Nikon N75 35mm SLR Camera
Camera stuck with lens out & wont turn on =/
This happens with many cameras, whatever you do, do not force the lens back. You will see this as a suggestion on some blogs. Doing it might further damage the camera lens and other parts.
Here is a repair place that is very reliable: http://www.teleplancamerarepair.com/Olympus_FE_FE-370
WHen sending it in make sure you cushion it so it doesn't get worse when shipping.
Jul 04, 2010 | Olympus FE-370 Digital Camera
D90 and Nikkor 17-55 problem. Lens won't come off
It's obviously in crooked. You will probably have to force it off but there is always the chance of damage.
Jan 12, 2010 | Nikon DSLR D90 Digital Camera
I have a Hasselblad 500c/m with the lens stuck on the body and I not turn the shutter knob. Help!
Get the back off the camera, make sure you can see inside the camera and locate a chrome screw in the middle below the lens.
Turn it right to align the locater slot of lens and body. Be very careful and do not use to much force. If you turn it enougn you can use the release button an unscrew the lens by turning it anti-clockwise.
Sep 19, 2009 | Photography
Not registering
provide me more detail about the microscope & camera.
so i can help you.
indravijay
Jul 31, 2008 | Bodelin ProScope Microscope
JVC HR-XVS44U - DVD tray won't eject
There are several capacitors in the power supply that fail and give this fault.
Sep 26, 2007 | JVC HR-XVC33U DVD Player/VCR
Bodelin ProScope Microscope Logo
178 people viewed this question
Top Bodelin Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Bodelin Science and Laboratory Expert? Answer questions, earn points and help others
