Question about Maytag Kitchen Ranges
The oven seldom lights. Igniter is working, there's usually no smell of gas, burners and broiler are working properly, replaced dual gas safety valve with no help. When it does light, it won't maintain temp. It reaches 350, shuts burner off but doesn't re-light unless I tap on the valve assy. The valve is new. Also, when burner doesn't re-light, the temp continues to read out at 350 even though it's cooling. (Bad temp sensor?) Recently also had a smell of gas but no re-light. It's on propane if that matters.
  • Maytag Master
  • 43,501 Answers
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Sep 07, 2010
My oven suddenly quit working - broiler works and burners, but the oven will not heat and there is the smell of gas whenever I turn the oven controls on. Can light the bottom burner of the oven with a...
More than likely, you have a bad igniter. As the igniters age from repeated use, they can become weak and longer function properly. Just because they glow, does not mean they are good. If you are experiencing ignition problems, the following link explains a little theory about how these igniters work and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
The burner manifolds in the oven each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface burners work, but the oven does not, the problem is usually not a gas related issue. If a single igniter is still working (i.e., the broiler still works), its more than likely NOT a control board issue, either.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need. If the model number is correct, the part number for a replacement igniter is WB2X9154.
NOTE: It is common for the BAKE igniter to require replacement more often than the broiler, due to the frequency of use.
If you have any questions please post back and let me know. I hope this helps you.
Oct 05, 2010 | GE JGBP24 Gas Kitchen Range
Oven does not light. Top ignitor glows red bottom
Since BOTH oven manifolds and surface burners are usually fed from the same source, this is probably the result of failed igniter(s) in the oven. This is assuming that your surface burners are working, or course. If you are trying to light the BAKE manifold, the broiler manifold is used on some model to speed up the pre-heat process. So, you may see the broiler attempt to light as well. If you have tried using only the broiler by itself and it still does not light, you may have a weak igniter on that manifold as well. Double check your symptoms.
If this is a GAS range, as these igniters age from repeated use, they can become weak and longer function. If you are experiencing ignition problems, the following link explains a little theory about how these igniters work and how to replace one:
The burner manifolds in the oven each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface burners work, but the oven does not, the problem is usually not a gas related issue. It can be a control board issue, but is usually a weak or failed oven igniter.
repairclinic.com
If you have any questions please post back with a complete MODEL NUMBER and let me know. I hope this helps you.
Jul 19, 2010 | Tappan TGF657 Gas Kitchen Range
My kenmore gas oven won't heat. I turn to dial to temp i want can smell gas building up in oven and can see a glow in bottom of oven but will not ignite. Sometimes if I turn on a cooking eye I can then...
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils
Oct 22, 2009 | Whirlpool SB160PEE Gas Single Oven
Oven won't light, even with ignitor getting red
If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
May 23, 2009 | Magic Chef 9122 Gas Single Oven
No gas getting to oven or broiler stovetop works glow plugs work on oven and broiler recently move applianc for cleaning took warmer drawer out and vaccuumed in there thought maybe i loosened a wire cannot...
May 17, 2009 | Kitchen Ranges
Where is the pilot on an old Tappan oven? The top burners work and light, but the oven isnt turning on. There is something under there that is glowing .
That thing that is glowing is your oven igniter. Most modern ovens do not have a pilot light. The way the burner assemblies for the oven and broiler work is by an electric igniter with a gas safety valve. When the igniter reaches a certain current potential, it opens the gas safety valve, gas flows and you have ignition. This is a designed safety feature that prevents free flowing gas from entering the oven without ignition. If you can see the igniter glowing and the oven still does not light, more than likely you have a weak igniter. They do wear out with age and require replacement from time to time. There is a separate igniter for bake and broil. Usually, the oven igniter wears out faster than the broiler because of the frequency of use. the following link explains a little theory about igniter types and how they work. It also explains how to replace a defective one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
This is a very simple repair that anyone can do. just make sure you follow al the steps in the link provided. If you have questions, or require additional assistance, please let me know before you rate the solution. If you need assistance in locating a replacement igniter, let me know also. I hope this helps you.
Jan 29, 2009 | Kitchen Ranges
Amana broiler problem
Each burner manifold in the oven has its own igniter. If the igniter is defective, the burner assembly will not light. The igniter has to be functioning properly in order for the gas safety valve to open. This is a designed safety feature that prevents free flowing gas from entering the oven cavity without ignition. This reduces the risk of explosions.
There should be a flame spreader metal plate covering the access over the broiler. You will need to access the broiler so you can view the broiler manifold and igniter. Turn the oven setting to broil and make sure the igniter begins to glow. If the igniter fails to glow, replace it. If the igniter does glow, but you still do not have ignition after 90 seconds, the igniter may be weak and still require replacement. The following link explains oven igniter types, their current potential, and how to replace them:
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 29, 2009 | Amana RanARG7302 Gas Kitchen Range
Oven & broiler not working
you ignitor is going out you will need to replace it the ignitor needs to draw a min of 3.2 amps in order to open the gas valve coil if short of this it will not open at thimes it may just have enough to open
Jun 28, 2008 | Hotpoint RGB528 Gas Kitchen Range
Oven not working, but broiler is...
Very well could be. I'm assuming the bake burner is the problem, right? Does the igniter glow at all? If it is glowing, but the burner does not light, is it usually a symptom of an igniter that has become weak. If it does not draw enough current the gas valve will not open and the burner will not light. This is a safety feature to prevent free flowing gas without ignition. If the broil burner is functioning properly, then more than likely the gas valve and regulator are working fine. In most ranges both burners are fed from the same source. You could try swapping igniters between the broil and bake burners to prove the theory. Or, you could just replace the igniter all together. Current readings are as follows: Round shaped glow igniter: 2.7 to 3.2 amps Square shaped glow igniter: 3.2 to 3.7 amps If you can give me the exact model number off your range (usually located around the oven door or on the back of the range) I can give you the correct part number you will need. Most appliance repair stores carry the igniter. I hope this helps you.
Sep 14, 2007 | KitchenAid KGST307 Gas Kitchen Range
Kitchen Ranges Logo
216 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
