Question about Sport & Outdoor - Others
I need a workshop manual for my victa hurricane mower with v35 2 stroke engine
  • 16 Answers
SOURCE: i am after a victa mower 2 stroke repair manual
I have a victa workshop manual covering some of the older models which i would be willing to copy the relevent pagesfor you. or might be able to give you soom tips, what model do you have and can you discribe the carburettor, soom victa's use a very odd carb made of plastic
Posted on Nov 28, 2009
SOURCE: Victa 2 stroke mower will not start
Hi ...i have a Victa 2 stroke mower, just replaced plug and replaced aircleaner, engin still won't start. Can you help me
Thank You
Ivan
Posted on Sep 14, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I've inherited an older Victa 2 stroke 80 mower.
Hi anastasialou...
Sounds like you have dirt/debris in your carburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 19, 2011
  • 316 Answers
SOURCE: manual for victa TRX ride on mower
hello, to get your victa manual you are going to have to contact the dealer in your area,they just don't post manuals,hope this helps,,
Posted on Feb 20, 2012
  • 3828 Answers
SOURCE: What is the victa lawn mower 35 classic a two stroke or a four stroke please.
search on a victa 35 classic makes it 4 stroke
its a brigs and stratton 3.5 engine on aluminum frame + plastic rear catcher
Posted on Sep 03, 2016
Need a engine manual on victa RM-40P lawn mower
looks closest to an early sanli /honda clone motor
cant find its user manual
coil failure common
spark plug lead caps crack and arc
metal carb easy to clean and maintain
round air filter
valve clearance
piston to top of compression
valve clearance gap is like 3 -4 thou
Nov 22, 2016 | Garden
Sep 03, 2016 | Garden
Need a user manual and product parts list please
These are available on the internet. Look up Briggs and Stratton motors, you will find the info you need. Sorry , but I am a bit strapped for time to go looking for you.
Mar 13, 2016 | Garden
Victa.two.stroke.wont.start
www.victa.com/au/support-centre/owner-guides
check spark.
If ok. chec for fuel inside on plug. If ok
check compression of engine.
Oct 12, 2014 | Garden
Is a Victa Sunbeam 160 Special a 2 stroke or 4 stroke? Wondering what additive to use with fuel. Thanks so much for your help.
hi there tanyajames88
your victa is a 2 stroke vc160 these units sare stated to run 25:1 fuel / oil ratio
that is 40 mils of 2 stroke for every 1.0 litre of petrol that mix
so if mixing 2 litres - 1st put in 80 mils of good quality 2 stroke oil then put in 2 litres of petrol , give good shake and fill up your mower tank
2 stroke oil that you would use for sthil chainsaw would be ok its hi quality
you could use some fuel stabilizer additive to hekp stop mix from going stale too soon
if wish but most times just mix enoyugh mix to het job done , then mix more if need it
that way mix is always fresh
vheers pauly46
May 29, 2011 | Garden
How do i tell a victa 2 stroke from a 4 stroke?
two stroke mowers will have a picture of a oil can on the fuel cap,if it doesn't it is most likely a four stroke.
four stroke mowers will have a fuel cap and a oil cap as well.
Dec 12, 2010 | Honda Garden
I am after a victa mower 2 stroke repair manual
Nov 21, 2009 | Garden
I have a victa corvette cox made ride on mower
Being cox made I'd go looking for cox manuals for the same era. Victa just rebadged others mowers.
Nov 18, 2009 | Garden
It may have a blown crankcase seal. How did you check the plug for spark?
you can remove the carbi and spray 2 stroke fuel directly into the chamber and try to start it.
If it starts you have a problem with the carbi or the fuel supply.
Take out the air filter as it may be blocked and restricting the air supply.
The float in the carbi may be full of fuel due to a hole in it or the fine fuel filter in the carbi may be blocked
Apr 04, 2009 | Garden
Sport & Outdoor - Others Logo
163 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
