Question about HP Officejet 7210 All-In-One InkJet Printer
My HP officejet all-in-one printer has been displaying the message: Remove and check right cartridge. I have checked it and cannot get it to print, scan or remove that message.
  • 67 Answers
Remove all the ink cartridges, and then unplug the power cord from the back of the printer.
Now, hold down # and number 6 button together, and while holding them down, plug the power back in.
release the hold after about 30 seconds, or the display saying nvram reset .. something like that .. If the printer turns off , then you will have to turn it ON again .. and then insert the ink cartridges ,
this will reset the machine.. and should resolve the issue. Also check if yu have any old cartridge and first insert that and see. if no error on inserting the old cartridge and that if it come by inserting the new on, then it could be the cartridge problem. Will have to try with new ink cartridge.
Posted on Sep 07, 2010
How to remove and insert catridge on right
Switch on printer, wait up to initialize, lift cartridge access door located at right side of the printer(check snap shot)wait till cartridges stayed at right side,gently push cartridge down wards to un lock, take out cartridge, replace desired cartridge..close the door & check display for ready mode...Note: Used cartridges & refilled cartridges may give error message to replace it.. If you are replacing with new one, printer will print align page to align cartridge.. For aligning the cartridge put printed paper in face down condition in scanner & scan it.. 5_25_2012_7_00_52_pm.jpg
May 25, 2012 | HP Officejet 4355 All-In-One InkJet...
HP officejet 6210 all in one...message is"remove
Hi Jim,
When you install a new cartridge, be sure not to touch the contacts, and make sure the contacts on the cartridge align with the contacts on the printer, and all packing tape has been removed. If the contacts on the printter are coated with dry ink, you should clean them with a cotton swab and distilled water. Dampen the swab and wipe off the dry ink on the contacts and let it dryt. Also, run the cartridge alignment on the new cartridge.
I hope this helps. Let me know if you need further assistance.
Randy
Feb 09, 2012 | HP OfficeJet 6210 All-In-One InkJet...
My hp officejet is displaying a message "remove
Your printer is in Error mode.. Specially with black ink empty message. HP Printer is designed in such manner that it will not allow you do to anything if it gives cartridge error message on printer screen.
you will have to replace the cartridge and align the printer to get it working.
Regards,
Ron
Jun 12, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I am getting an error message remove and check right cartridge?
Replace the right cartridge with a new genuine HP cartridge.(not a re-fill)
If still does it check that the contacts are clean where the cartridge seats.(wipe with a q-tip)
Aug 31, 2010 | HP Officejet 7210 All-In-One InkJet...
Error message HP Officejet 7310 "remove and check cartridge on right. Removed cartridge, checked it (nothing), installed it back - still same message. Installed new original HP cartridge - still same...
Can you find a friend with a similar HP printer, i.e., one that accepts the same model-number of ink-cartridge? If the cartridge gives the same error-message in the other printer, it's time to responsibly recycle your "dead" cartridge, and give the brand-new cartridge to your friend, for his/her usage.
Nov 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Keep getting Remove and Check Cartridge message even when I replace the black cartridge with a new HP one. How can this be fixed?
I believe you have to press the "select" button or the "options" button. Both are located right under the LCD display
Sep 07, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP 7410 printer displays error ''remove and check colour cartridge
I think that spring must have gotten loose that holds the cartridge in place, right hand side, put it back where it belongs, might want to compare with the other, black cartridge side.  Good Luck!
May 13, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Remove and ck right cartridge
Once remove both the cartridges from the all-in-one and then clean the copper contacts of the cartridges and then put only black cartridge and check for the message displayed on the all-in-one if it even reads check right cartridge then the issue is with the all-in-one hardware. If it reads insert right or color cartridge then the issue seems to be with the cartridge.
Remove the cartridges from the all-in-one and power cycle the all-in-one and then reset.
Now insert the cartridge and check for the result. If the issue still persists then check the expiry date on the cartridge and once replace the cartridge and check for the result.
May 27, 2008 | HP Officejet 7210 All-In-One InkJet...
Remove & Check Cartridge message
Hi Scallag,
Please check with the ink cartridge numbers given below.
HP Officejet 6100 series All-in-One model Black cartridge Color cartridge Photo cartridge HP Officejet 6110, HP Officejet 6110xi, HP Officejet 6110v HP 56 HP 57 HP 58
Click on the web link given below and perform the steps carefully.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01299067&cc=us&lc=en&dlc=en&product=79477
Here is the other web link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01300415&cc=us&lc=en&dlc=en&product=79477
Have a great day!
Mar 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 7210 All-In-One InkJet Printer Logo
353 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
