Question about Leviton (102-5G108-RW5)
I have a problem in crimpring of UTP Cable in one end of the connector I followed 568B while crimping in RJ-45 Connector, and other side I want to punch in I/O Box what should I follow either 568 A or 568B.
  • 565 Answers
For a straight through cable, which is most likely what you need, you can use either standard as long as you use the same standard on both ends. In your case use 568B since that's what you have on one end already.
Posted on Sep 10, 2010
I have wired (2) cat5e connectors using 568B and still seem to be getting collisions and no connectivity. I have re-wired these several times making sure I am the same on both sides. Any ideas?
I would make sure you have the wires pushed all of the way to the end so that it's reaching the metal connector at the tip. Often times there is a wire or two not reaching the very tip and therefor is not fully connected.
Feb 28, 2011 | Leviton Quickport 5G108 Category 5e...
How di I terminate the QVS Cat6 RJ 45 plugs?
terminating a RJ 45 plug means to put a RJ 45 plug on the end of a suitable cable. This is done by making up a si\uitable cable and skinning the tips of the cable and inserting them in the right order to the plug and then using a special RJ 45 crimper mashing a plastic plug down on the wires. You can purchase such an arrangement from an electronics supplier.
Jan 06, 2011 | QVS 100pcs CAT6 RJ45 50u Crimp Connectors...
How we join it with computer which LAN wire is use state or cross and proceser to joine
Your question is a little confusing ... chain saw networks?
I believe you want to know how to build a wired computer network ...
You will need special tools to do this including a RJ-45 crimp tool. You should use the highest quality ethernet, 'Cat 5', Cat 5e', wire available to you. On the ends you will install RJ-45 connectors (8 conductor 'plugs'. Choose and stick with one of the several color codes for placing the conductors into the RJ-45. Color code guide should come with your special tool. Make sure the ends are in proper order, trimed square and inserted fully into the connector before you crimp. Purchase a test tool to verify your work. Expect to pay $50.00 US or more for the testing tool. Cable, connectors, wire, router or switch and other hardware should be available where communications or electrial supplies are sold.
Thank you for your interest in FixYa.com
Aug 10, 2010 | Garden
Plz explain me exactly for which purpose RJ-45 cable used ?
RJ -45 is a type of connector used on cat5, cat5e....etc cables to connect networked devices...the RJ stands for registered jack but there is really not much you really need to know about it....a RJ 45 JACK is a little bigger than a telephone jack, you'll notice the female type of input on your computer or laptop and the male end will be on the end of the cable that goes into this jack....hope this helps
Apr 13, 2009 | Cat5e Cat 5E Modular Plugs - For Round...
Network & Telephone Cabling
Sure you can,
But.... what are you going to use it for? if to connect 1pc to another there will be no connection, as for a telephone line only have 4 lines and the RJ45 connection to PC uses 8
Apr 03, 2009 | PC Connection RJ45 Connector
Ethernet cable end repair
Unless you have a RJ45 crimping tool you are stuck with having to ask someone who does have one to borrow it, honestly if you know someone with a crimping tool then ask them to perform the repair.
If however you have the tool for a straight through cable (most common)
Holding the plug upside down (catch towards the floor) and the pins furthest away from you I use the following layout;
orange white (furthest left hand side)
orange
green white
blue
blue white
green
brown brown white (furthest right hand side)
slide the cables into the plug held in the position describe above, then check the order of each wire once more using the crimping tool to "crimp the new RJ45 connection in place.
Basically as long as you hold the rj45 connector in the same position the wires should go into the same corresponding position at each end.
Nov 08, 2008 | Belden 1000 ft. UTP Network Cable
ADSL Modem Huawei SmartAX MT841 USB driver not supporting Window Vista Name update of Vista
Hi!
Do not use the usb port or cable. use the RJ 45 port instead. and configure PPPoE and connect using UTP / STP cable with RJ 45 connector straight crimped.
Jul 27, 2008 | Computers & Internet
I have a cat5e network cable i am hooking to rj45 flush mounted wall jack the wire color is not the same?
Either your wallmount is not correctly crimmped according to the standards or your cable is not correctly crimmped according to the standards. So its better you crimp the cable and fix the R.J 45 connector in the sequence given herewith.colour coding of the cable:-
1-oranage white
2-orange
3-White green
4-Blue
5- White blue
6-Green
7-White brown
8-Brown
The same Sequence should be at the wallmount and at the R.J 45 connector.
Apr 26, 2008 | Computers & Internet
Cat5e
Some testers do not test ALL the wires. Some will only test pair 1 and 2. You may want to use a DVM (Digital Voltmeter) set on the ohms function and check continuity on each of the eight wires from RJ-45 to RJ-45 connector or use a cable tester that will check all the wires. If you use a DVM check 1 to 1, 2 to 2 etc. for continuity. Good will read 0 ohms, open will read infinity or OL on some meters. 90% of all cable problems are poorly crimped or broken wires at the RJ-45 connector. It is difficult to be sure which end has the bad connection so you may need to change BOTH RJ-45 connectors. Do one, then check the cable, if it doesn't work, do the other one. It is a 50-50 shot. I prefer and encourage the rewiring color code using the EIA 568A standard. Starting at pin 1 the color code would be orange-white, orange, green-white, blue, blue-white, green, brown-white, brown. You don't have to do it that way, but you must make sure that the same color wire is on the same pin on each connector. If all else fails, you can go to you neighborhood computer shop for help in installing connectors. It takes a lot of practice to do it right. Hope this helps
Nov 30, 2005 | Honeywell Multimedia, Cat5e X2, RG6/U...
Leviton (102-5G108-RW5) Logo
Top Leviton Computers & Internet Experts
vimal
vimal
ashburton
Michael Galve
Michael Galve
Are you a Leviton Computer and Internet Expert? Answer questions, earn points and help others
