Question about Magic Chef MCD1311ST Microwave Oven
I need to replace my glass turn table as I chipped it in 2 places.
  • Magic Chef Master
  • 9,047 Answers
You can order it here:
https://www.mcappliance.com/partorder.aspx
Posted on Sep 08, 2010
Do you have a glass turning table for daewoo microwave oven of the attached model in the photo
Just one recommendation. When it come to microwave, sometimes the glass turning table could be compatible with other brands. So I recommend that you edit this post and add a picture of the glass table that you want. That way you may have a better chance on getting help.
Jun 08, 2016 | Daewoo Microwave Ovens
Where can I find a replacement glass turn table, or at least one that is compatible? What are the dimension of this model cooking tray?
Scotty, one place you can try would be to contact the manufacturer of the unit, but they sometimes tend to be a little or a lot pricey. A couple of other places you might try are some websites that I have found to be helpful.
www.repairclinic.com
www.ereplacementparts.com
Hope one of these will be of help. You will need the make and model number of your microwave to make sure you get the right plate.
Oct 20, 2014 | Microwave Ovens
Need part # for glass turn table
Try www.ebay.com type make and model of microwave oven, refine search to plate.
Jun 13, 2012 | GE Microwave Ovens
Turn table does not move anymore.
Hi and welcome to FixYa, I am Kelly.
This is caused by a bad turn table motor winding or gear failure. You can go to this link:
http://mcappliance.com/partorder.aspx (Click on customer order) or call 888-775-0202 for the part.
Use the drop down menu and find your model number. The part will be Turntable Motor.
The linkabove should work. If not respond with your model number and I will look it up and find you more than one source for the part.
The motor is on the very bottom of the microwave. You can usually access it by removing the the glass turntable tray / plate and tipping the unit 90 deg. It is held in place with 2 mounting screws.
Thanks for choosing FixYa,
Kelly
Sep 12, 2011 | Magic Chef Microwave Ovens
The glass turn table wont spin??
Hi, Your problem lies with one or both areas. If you remove the glass turn table, you'll see a plastic grooved driver that goes thru the floor. See if you can lift up and remove it. Does it look broken? If not, there is a drive motor underneath that drives this plastic piece which turns the turntable. You'll need the model number to take to your local parts house for replacements. Hope this helps.
Jan 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Own Whirlpool Microwave oven Model MH6141XKQ. How does one clean the "inside" glass of the door. By inside, I mean between the two glasses on the door.
You will need to remove the door and take the door apart to clean between the glass. This process is not that difficult. Just follow these steps:
1. Open the door all the way and lift straight up at the hinges to remove from oven.
2. Place the door, face down on a soft surface to protect the door and glass. A layer of towels on a countertop or table is recommended.
3. Remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel. Work your way slowly around the perimeter of the glass to release the clips that hold it in place so you can pry the plastic up and pop the panel loose. Use care not to pry against the glass.
4. With the inner panel removed, the glass should be easily accessible and can be carefully lifted out and cleaned. Clean with a good non-streaking glass cleaner.
Make sure you remember how the door is assembled as you take it apart. If you forget, the following webistes have illustrated parts listings to show how your door is assembled:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
If you have any questions, please post back and let me know. I hope this helps you.
Aug 12, 2010 | Whirlpool Microwave Ovens
The turn table does not turn
Since you didn't state the brand and model, I can only speculate that the spindle /turntable drive may be bound up or worn. Depending on the brand, you may be able to get replacemant parts to fix it but you will need to provide brand/model info on a repost.. If yoy remove the glass turnatble and the roller set... can you place a glass of water on top of the center spindle and run the micro for 20-30 seconds? While it is running.. does the glass rotate? If not... you may have a turntable drive motor failure... Need more info next time you post to assist you more accurately..
Good Luck
Jan 31, 2010 | Microwave Ovens
Where to get a new turn table for microwave
If you are referring to the glass carousel tray, the part number for a replacement is 46-1712454-3. You can find it listed at searspartsdirect,com. I hope this helps you.
Jan 21, 2010 | Sharp R-1850A Convection/Microwave Oven
Turntable wheel under glass tray broken
If the microwave comes with a roller ring to rotate the glass turntable then I would recommend that it needs to be used when the microwave is operating, as the turntable rotates the food so it can be heated evenly.
I would recommend checking with your local Panasonic repairer he may have access to a new roller or even a second hand one to tide you over.
Mar 20, 2009 | Panasonic Microwave Ovens
I have a JVM1603BJ03 space saver micro wave. The turn table cracked in two, the plastic support device to turn the glass table has desenigrated into several small pieces. It appears the micro wave is...
Do you cook a lot of popcorn?
Do you place your food items in the center of the turntable as opposed to placing them off-center?
Both can cause repeated heating of the same spot on the turntable, which can stress it and allow it to crack.
You can buy replacement parts here.
I suggest that when you cook popcorn, place a paper plate or two upside-down under the bag and always place your food items off-center on the turntable tray.
Once you have the new parts, I would suggest at least a quick heat test. That is to heat one cup of water on high and it should boil in about 2 to 2-1/2 minutes.
If you would like to perform a more standard heat test, please see my Ask Mr. Microwave page.
If your magnetron is indeed running too hot, then it is probably dying. Sometimes - like a star - they can burn hotter right before they die.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 04, 2008 | GE Microwave Ovens
Magic Chef MCD1311ST Microwave Oven Logo
24 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
charles
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
