Question about Wacom Intuos3 Graphic Tablet
OS X 10.6.4 Mac Pro and Intuos 3. Pen and Mouse works in small increments. Can cover the whole tablet, but takes 3 drag and moves side-to-side. System Prefs does not open the Tablet. (Does not see it!) Cannot change the Wacom Tablet configs. Restarted ... same. Installed latest (?) driver 6.1.5-2 and rebooted - same as before-does not recognize. USB poet is good swapped ports with known good. Turned off Mac and rebooted - same problem!
SOURCE: serial to usb wacom tablet problem
I just got Vista and it killed my Intuos2 w/serial to usb also, but here's a half solution:
Download Wacom driver 4.78-6 http://www.wacom-europe.com/int/downloads/driver/driver.asp?lang=en. Make sure you remove any other Wacom drivers, tablet, and reboot. Install 4.78-6 driver and select serial port when the choice pops up. Plug in your tablet with the serial to usb adapter, wait a few seconds and click retry. Complete the install and reboot.
Your Wacom tracking should work now, but certain things might not work like pressure sensitivity and you'll get annoying error "reinstall driver" pop-ups.
I think you can aslo buy a PCI-serial card for your computer and skip the serial-usb adapter since Vista doesn't support the adapter for Wacom tablets.. but I'm not sure if there's a working Vista serial Wacom driver either.. or ever will be. The age of XP and Legacy support is at an end my friends.
Posted on Apr 03, 2008
SOURCE: My Wacom Intuos3 tablet won't switch into pen mode
I had the same problem with my Intuos3 on Vista. Tech support suggested the following.
Do this.....Go to Start--->control panel---->system(in classic view)---->device manager--->click on "human interface devices"--->then click on "Wacom virtual HID driver" and right click on that and disable it. Your computer will ask you to restart and you will want to do that.
Everything works fine now.
Posted on Aug 14, 2008
SOURCE: Wacom Tablet overly sensitive
I also had this problem. Then I tried changing the frimness of the pen, and now it works perfectly fine.
Go to Pen Tablet preferences, then in the Pen tab, change the softness scale to "Firm" then it should be fine.
Posted on Nov 02, 2008
  • 46 Answers
SOURCE: Wacom pen not working - on the pen side
check the battery of the pen
Posted on Feb 24, 2009
The winning answer came courtesy of Mr Benedikt Schmitt of Wacom Europe, who offered the following solution: from the Windows Device Manager, disable the “Wacom Virtual Hid Driver” device. (Go to Control Panel > System and Maintenance > Device Manager, find the driver, right-click it and choose “Disable”.) One reboot later (welcome to Windows-land, circa 2008?), everything works as desired. Pressure and tilt sensitivity inside Photoshop still work, and the pen functions just fine in the rest of the Windows desktop. The absolute mapping makes it an absolute pleasure to point quickly and precisely. It makes my laser mouse feel rather clumsy navigating a large 24′ screen!
Posted on Mar 22, 2009
Intuos 4 pen clicking while hovering
You may have an issue with the drivers. If you're using the drivers on the CD, try updating to the latest drivers:
http://cdn.wacom.com/U/drivers/IBMPC/pro/WacomTablet_635w3.exe
If you're using the latest drivers and the issue persists, try rolling back your drivers to the previous release:
http://cdn.wacom.com/U/drivers/IBMPC/pro/WacomTablet_634-3.exe
Feb 16, 2013 | Wacom Intuos 4 (PTK1240) Graphic Tablet
Pen and mouse have constant constant cursor jitter Intuos 3 mac
I had a similar problem on my laptop
I plugged the tablet directly into the laptop rather than the USB hub I'd been using until then, The issue disappeared.
Possibly it's a power issue, and going direct cured it?
Jul 29, 2009 | Wacom Intuos3 Graphic Tablet
Intuos 3 Pen/Stylus suddenly stopped working (as in dead).
Will the tablet work with the mouse? If it does not, is not working is the blue LED light on. If the LED is not working try another usb port. If the mouse works go into the Wacom tablet properties from the start menu. Select the grip pen from the tools. Click on the default button to restore the stylus to factory settings. When you press the pen you should see the pressure scale rise. You can also test the eraser pressure. You could also replace the stylus tip to see if that works. From the Wacom site you can order a new stylus or tips if it is found defective.
Apr 14, 2009 | Computers & Internet
The mouse on my Wacom Intuos tablet is not working.
I know this question was asked a long time ago, but I just had this similar problem and found a solution to it.
1. Install the latest Wacom drivers for your device
2. Open the Wacom Tablet Properties from the Start menu.
3. Click on the Mouse tool
4. Click on the Mapping tab halfway down the screen
5. Change the mode from Mouse to Pen
Dec 26, 2008 | Wacom intuos2 12x18 USB Tablet (507074)
Wacom tablet won't recognize pen
Hmm. I've had a similar thing happen with my tablet. Have you tried removing the tablet pen from the list of tools in tablet preferences and then adding it to the list again before checking the 'About' section of the tablet pen set-up and clicking the 'diagnose' button there in? As that worked for me when my tablet pen was not working. The pen was recognized by the tablet after that.
Aug 20, 2008 | Wacom Intuos3 Graphic Tablet
Pen pressure and scale problems
I also use Intuos 3 tablet, did you already try replacing the tip and reconfiguring the pen to the screen? You can find this in the driver software, it synchronizes the pen and tablet.
If you already tried that, does the problem only occur in Photoshop? Also, check your brush preferences, you can go back to your default settings and see. If talking to Wacom fails, you might have a bad pen or tablet.
Jul 07, 2008 | Wacom Intuos3 4x5
Initial Delay of tablet pen
I had a similar problem with Vista which made the pen/cursor freeze just as the tip was placed on the tablet face.
The problem turned out to be a Vista setting.
I went to Start > Control Panel > Pen and Input Devices.
Then in the Pen Options tab highlight the "Press and Hold" pen action and then press the "Settings..." button. In the dialog box that opens uncheck the "Enable press and hold for right-clicking" check box. Hit "OK".
Worked for me.
Feb 02, 2008 | Wacom Intuos3 Graphic Tablet
Graphire 3 tablet pen troubles
scrap the graphire and get an intuos....i have the same problem....I think the pens are cheap...you might need a new pen. try borrowing someone with an intuos pen.
Sep 12, 2006 | Wacom (EP130E0W01) Digital Pen
Wacom Intuos3 Graphic Tablet Logo
199 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
