Water fills very slowly down to a small trickle
  • Gary Zapotoczny Sep 07, 2010
    Thanks for your response. It is a Kenmore Heavy DutyUltra Fabric Care,
    Model 110.92281100. Let me know if you need more info.
  • Washing Mach... Master
  • 3,463 Answers
This would suggest a couple of possibilities.
Check the following.
1- ensure that the water pressure is o/k, and that there is a good pressure at the inlet valve/s
2- Turn off supply to valve/s, and remove inlet hose/s, check to see if there is a filter in side the opening of the valve/s, clean if req'd.
If everything checks out o/k, then I would say that you need to replace the inlet valve/s.
Good luck
Posted on Sep 07, 2010
    President:
  • 1,554 Answers
The problem is in the water inlet valves assembly. Either the inlet screens are blocked or the inlet valves are stuck and not opening completely. Replacing the inlet valve assembly is the best thing to do to address this issue.
Please indicate the make and exact model of the machine should you require further advice. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions should you need further assistance. But accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
  • Jahn27
    Jahn27 Sep 07, 2010
    The water inlet valve assembly is part number 285805. Here's how to replace it:
    Disconnect power then remove the fill hoses. Release the console from the top of the cabinet by removing the screws shown below then pull forward and up on the
    console and lay it back on the hinges.
    Disconnect the lid switch harness connector by pressing on the tab
    located in the middle and pulling it up.
    The cabinet is attached
    to the rear of the washer by
    two brass-colored
    retaining clips. Insert a flat blade screwdriver into the turned-up edge
    of the clip, located on both sides, and then pry back to release the
    clip from the slot in the cabinet.
    Open and hold the lid while grabbing
    the cabinet front opening then tilt the top of the cabinet toward you by
    pulling the cabinet away from the base. This releases the front and
    back slots of the cabinet from the tabs in the front and back of the
    base. Using the side of your leg and/or body as a support for the front
    of the cabinet, carefully lift up and set the cabinet aside.
    You now have access to the water inlet valve assembly. Remove the valve assembly from the rear panel and transfer the outlet hose to the new assembly. Secure the new valve assembly into position and transfer the wire harnesses to the appropriate solenoid coil terminals.
    Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the
    base
    of the machine then lay down the cabinet into position. Make sure the
    slots in the cabinet sit into the tabs at the base of machine.
    Reconnect
    the lid switch harness then push the retaining clips back down into position
    to secure the cabinet to the rear of the machine. Reinstall and secure
    the console to the top of the cabinet then reconnect the fill hoses to complete the repair.
Can I adjust the water level in the bowl?
Hi Jeff:
Two things affect the water level in the bowl:
1) - The maximum height is determined by the siphon. To see if that is where you are, slowly pour water into the bowl. If the level stays the same, that's the maximum height. If it increases, you may be able to "tweak" the trickle tube. (next step)
2) - "Trickle tube" - My term as that's a good description. Lift the lid off the storage tank. If you look into it you will see a vertical tube, open at the top. A small tube should be clipped on to it so that when you flush it, water from the small tube flows into the big tube. That will be "trickling" into the bowl to fill it to the top of the siphon level. Sometimes this small tube can be installed so that it misses the big tube so the bowl does not get filled to the maximum.
- Hope this helps.
Cheers..
Dec 04, 2015 | Home
Jennair jcb2058geb - ice maker continues to make ice but is dripping water into the collection bin and alll the ice cubes freeze together
The reason the fill tube is freezing is because the tube that connects to it and connects to the water inlet valve is seeping water slowly. It's just enough water to trickle into that tube at the top and since its so cold that little trickle freezes,then the next trickle freezes and so on and so on. After enough small drops of water freeze the entire tube is frozen. To stop that replace the water inlet valve the small diameter tube connects to. The part number for that is 12002193 you could purchase it at your local applianve parts store. Or online at
repairclinic.com
searspartsdirect.com
apdepot.com
apwagner.com
partselect.com
Thank you for using Fixya.com,
Gene
Sep 05, 2011 | Jenn-Air Refrigerators
My ice maker has a slow leak so it eventually turns the cubes into one giant cube. Do you know how I could fix this??
Reply back with model# and i will give you the part #
Gene
Aug 21, 2011 | Admiral 26 cu. ft. Side-By-Side...
Have a fluidmaster 400A. After the tank refills and turns off, some water continues to trickle through the hose into the overflow tube causing a trickle into the tank. If I pull the hose off the 400A, I...
make sure you have the overflow tube, ( the small black one) attached to the clip so it doesn't go too far down the fill tube,, otherwise it causes a siphon and you will hear a trickle, you can also turn off the water, and grab the top of the valve, turn it 1/8 of a turn, and check for any debris inside that cavity, clean and reassemble
Jul 10, 2011 | Home
Switched timer to 53 mins. Machine runs with water trickling instead of gushing. It runs down slowly to 40 mins and then shows 4W (which is Error)
sounds like a bad inlet valve or screens inside the inlet valve are dirty, the valve is located wher the fill hoses hook up at
Nov 18, 2010 | Samsung Washing Machines
My washer seems is filling very slowly, and doesn't empty all the water out of the tub. I tried both temperature settings and it doesn't seem to matter. It will fluctuate back and forth on how fast it...
regarding your filling problem , most washers have small screen filters at the water intake, take your hot and cold hoses of of your machine and observe the fittings on the machine you will likely find the filters there they are just a mesh screen, remove them and clean , then reassemble this should solve your slow filling problem
May 08, 2010 | GE WPRB8050D Top Load Washer
LG wm1832cw filling slowly
The water valves might be going bad, or there is a clog in the hoses. Also check the water pressure going into the washer.
Dec 03, 2009 | LG Washing Machines
Water trickles slowly into the machine.
Turn off the water.
Switch on the machine and let it try to start filling, that will take the mains pressure off the hose, switch off the machine
Take off the hose at the washer end and check to see how much dirt there is in the small filter inside the inlet solenoid
Most of them pull out for cleaning , be gentle they are nearly all made of plastc and can crack
May 27, 2009 | Roper RAS6233KQ Top Load Washer
Kenmore washer. At rinse cycle only, water fills very slowly.
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 06, 2009 | Kenmore Washing Machines
Water is filling slowly
8. re-try.
Mar 24, 2009 | Kenmore Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
