Question about Whirlpool Refrigerators
My whirlpool side by side refrigerator is listing a code 6. What does that mean?
Have installed a new ice maker, it still will not work.
Soulds like the your model has a electronic eye that monitors the ice level has failed. Page 6 in the Click Here=> GD5SHAXKQ00 Parts List Location number 38 is the 2198585 Ice Level Control Board
Whirlpool Ice Maker Infrared Electronic Eye Technical Information I am here should you have questions, Thanks Sea Breeze
Apr 15, 2013 | Whirlpool GD5SHAX Side by Side...
Cheats sf
We don't understand what you exactly mean. If it means a eror code, please find below the error codes and its solutions.
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error Er-Ff- Freezer fan fault. Write again if you're not satisfied with this answer.Thanks.
Feb 24, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Electronic display flashes and the compressor turns off
Whenever whirlpool displays start flashing, it typically means replace the board. Im fortunately lucky to have a technician who reprograms the micom ic.(im in S.Africa sorry.)
Jun 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
There is a flashing #6 in a circle above the temperature indicator. What does this mean?
Mine did the same thing today and I just got off the phone with Whirlpool and they said it just means that the 6th Sense technology is activated. If you put a bunch of warm food in the refrigerator or leave the door open for a while, the 6th Sense technology kicks on to return the refrigerator to the set temperature. The flashing 6 should go away once it gets back to the right temperature.
Nov 21, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
My side by side fridge freezer is flashing CF alarm code. What does this mean
Change filter most likely this is the filter for the water.Meaning dirty water and foul tasting ice.Some filters are located in the front easy to reach areas at the bottom near the floor usually left side under freezer.
Nov 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Error codes for Samsung Fridge
you need to check the refrigerator defrost sensor connection thats behid the light bulb in the middle of the refrigerator section
May 24, 2009 | Samsung RS2534 Side by Side Refrigerator
Side by side whirlpool refridgerator GD5SHA is no longer cooling
Your refrigerator has an Adaptive defrost board inside the fresh food compartment that is the number one reason I think your refrigerator is not cooling. Reading your post you mentioned this just suddenly began to happen. Can you hear the compressor running? Is your fans blowing inside the freezer and below the refrigerator? Can you feel warm air coming from back and under refrigerator or cold air blowing inside freezer? Click on link below and enter your model in search feature. You will see 36 similar choices, just make sure you choose one that has refrigerator beside the model number. When you get to the correct page choose photo 10 control parts click it and you will see the Adaptive defrost listed in photo as item 6. Let me know those other things I asked in this message so I will be able to help you better, Thanks Sea Breeze
click be low link enter model GD5SHAXLB01 in search feature
http://servicepartstec.blogspot.com/
May 20, 2009 | Whirlpool GD5SHAX Side by Side...
Ice maker
That means that the solenoid that controls the ice maker is defective and must be replaced with a new one.
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Jul 23, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Loss of cooling in refrigerator / freezer
you may have a bad ptc or cold control. if you hear a buzzing noise followed by a click, you have a bad ptc unplug the machine and call a service company quick
Jun 07, 2008 | Whirlpool ED2NTGXL Side by Side...
WHIRLPOOL CONTROL PANEL
Hi. Your temperature control board display is bad. You may also have a power convertor board located next to the compressor. Normally you would replace the temperature control board first. I have a temperature control board listed on Ebay as item number 250211412492. Good luck, Mack
Dec 31, 2007 | Whirlpool GS6SHEXNL Side by Side...
Refrigerators Logo
137 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
