Question about Philips 36PW9525C 36" TV
We have dish network and we had houseguests who didn't know how to use that remote so they tried to use the other one. now our tv won't change channels either at the tv or the remote, but it will change outputs... how can i fix it so we can watch dish again?
  • 246 Answers
Hi my nameis Mike Houston of DISH Network and I see you had a house guest and they usedthe wrong remote. You will want to check the connections from the TV to thereceiver, if the cable connecting the TV to the receiver screws on you willwant the TV on channel 3 or 4. If the cable is Red, Yellow and White (RCACable) you will want the TV on one of the inputs of the set. I will send a linkto help with these steps, http://www.dishnetwork.com/SupportSection/bbs-screen.
Posted on May 23, 2011
TV remote won't work after changing batteries
When battery is changed, all the previous settings will be lost from the remote control. You should once again set it to your device, using codes.
Jan 10, 2013 | DISH Network Televison & Video
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
My dish remote does not work all the time on Sat..like Guide ..etc... after i turn tv and dishbox off it works sometimes?please help
fritzglas,
It sounds like a interference issue. Sometimes a TV (Usually LCD) or other equipment can generate enough heat to interfere with the IR sensor.
If function returns when you go right up next to the receiver then there is most likely something causing that interference. If that's the case remove possibly sources or turn equipment off and power on 1 by 1 until you isolate the problem.
Another solution if you have a spare remote, or order one, is change it from IR to UHF and bypass the possible. This can be done with remote model's that say IR/UHF Pro on the back at the top.
If you can provide more information about your setup, or if those steps didn't work let me know here or at thomas.faust@dishnetwork.com and I would be happy to check it out further with you.
Tommy Faust
DISH Network
Sep 04, 2011 | DISH Network IR Remote Control
Can't get "no signal" off
Hey cthaemar, it sounds like it may have been switched off the correct channel. If it is hooked up with a Coaxial cable it will be on channel 3 or 4, and if it is hooked up with an AV cable then it would be on one of the inputs.
If it's channel 3 or 4 try pressing the gray TV button on the remote and changing the channel. If that doesn't work you may need to use the TV's remote or the TV itself.
If it's on an input press the same gray TV button and then try pressing Input. With this you can also try the TV remote or the TV itself to change those if our remote doesn't change it.
Let me know if you have any other questions or concerns!
Tommy Faust
DISH Network
Jul 12, 2011 | DISH Network 322 DTV Receiver
Cannot program Dish IR remote l03602
adeline_roll
You didn't specify if you are trying to program the remote to your TV or receiver. Is it a replacement remote or did it just quit working? I have provided instructions on how to program to your TV or receiver.
Address to receiver:
Remote: All Other Remotes
  1. Go to System Info screen (depending on receiver - press System Info button on receiver panel or pull smart card out till System Info screen appears on TV screen).
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button.
  5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Remote: Basic Remote (Television Only)
  1. Turn the Television On.
  2. Press and hold the TV Power button for three seconds until the LED flashes.
  3. Press and release the TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off.
  5. After the television turns off, press and release the OK button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Please let me know if you have any other questions or problems. Thanks.
Ray Calo
DISH Internet Response Team
Jun 23, 2011 | DISH Network IR Remote Control
I have a haier tv a 722k receiver. my black dish network remote won't change inputs so i can use my ps3 etc.
allday70, we don't have any current codes for a Haier TV, but we can definitely check it out and help you get that programming.
As there are no codes for that TV, I would recommend trying a power scan. I have posted the steps below, though you can view this link: http://www.dishnetwork.com/SupportSection/remote-setup for general information on setting up remotes.
Power Scan to TV:
1.) With the TV on, press and hold the TV button (about six seconds) on top of the remote until all mode button backlights come on, then release.
2.) Press and release the red power button, then press the Up button once a second while pointing the remote at the TV. If the code for the TV comes up, it will power off.
3.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works try several different functions for that equipment.
Let me know if you have any questions or need further assistance!
Tommy Faust
DISH Network
Jun 18, 2011 | DISH Network IR Remote Control
Dish network changed to snow when I tried to change station to channel 13. I pressed "power" for 5 seconds with no change.
Hi, Mary with Dish Network Customer Service here. It sounds like when you try to change channels with your remote, it is changing the channels on your TV and not your Satellite Receiver. In the top left corner of the Dish Network remote is an SAT button. When you try to change channels on the Satellite receiver this button should be lighting up. If the TV button lights up, it means the remote is working the TV. Press and release the "SAT" button after you have the picture back on the TV and it should work normally. I hope this resolves your remote issue!
Jan 12, 2011 | Toshiba Televison & Video
Dish remote won,t work if Visio E550Vl is in operation.
Hey there! Becki Barned with Dish Network here! The problem that you are having is interference with your tv. You can try to move your receiver away from your tv a little, just a few feet, so that the LCD tv is not affecting the signal from the remote.
Dec 23, 2010 | DISH Network IR Remote Control
Have 8 yr old Orion tv-new remote control for satilite Dish network wont turn tv on--need to know what orion tv codes are.we tried everything tech said to do ,need to know what orion tv codes are..lost the...
We would be happy to help you with getting your new DISH Network remote to control your TV. We're going to start by pressing and holding the TV button located on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your Orion TV; here are some of the codes we currently have for it: 720, 748, 748, and 748. Press the pound (#) button. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your Orion TV until you find one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Feb 11, 2010 | Orion1934 19" TV
Philips 36PW9525C 36" TV Logo
411 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
