Question about Aiwa Audio Players & Recorders
I can;t get any sounds from my headphones. The HP-X223 pretty old, I just want to know if I can open them up and fix anything
2 Suggested Answers
  • 11800 Answers
SOURCE: I have no sound from the speakers on my hp dv9000
The bottom case must be removed to access the jack and only then you can know what exactly was broken and how, or if , it can be fixed. But , most likely, is a bended jack, all it might need is some straightening of its contacts.
Posted on Jan 05, 2010
The erpads on my Aiwa XV304Headphones are wearing out.
If you click my user name you will find a tip about headphones. At the bottom of it is a link to a place that might be able to help you.
Apr 10, 2011 | Aiwa HP-X223 Consumer Headphones
Front headphone jack does not work, do not get sound. I have an a1450n HP Pavilion running windows 7 ultimate. Running Realtek High Definition audio drivers. This problem is quite common on the internet....
If you face issue with only front jack then you need to check the connection of front jack to motherboard. For that open cpu cabinet cover.Then find the cable from front sound jack to motherboard. Connect it into right position .You can find diagram on motherboard or in manual.There is some pins on the corner of motherboard. Let me know if you need further assistance. Thanks for using FixYa.
Feb 28, 2011 | HP Pavilion a1450n PC Desktop
Wire inside is torn
Hello
This tends to happen eventually with headphones, mostly by accident. I know.....
Things that you will need are a soldering iron, screw drivers and such.
You will have to disassemble the headphones, begin by removing any visible screws, you may have to carefully remove the soft pads around the ears to expose screws.
eventually you will get it open.
It is pretty simple repair. You have to cut the old wired out, possibly expose some new wire and then solder on its place.
When you got the wires in properly again, plug the headphones in and listen if you get sound from both, if these include a microphone also test it.
Then reassemble the headphones.
Let me know if you require further assistance.
Thanks,
Ekse
Feb 27, 2010 | Sentry HO900 Headphones
I have no sound from the speakers on my hp dv9000 laptop and very little in my headphones. I used my headphones quite a bit and im pretty sure that theres a problem with the headphone jack. maybe pushed in...
Dec 17, 2009 | HP Pavilion dv9000z Notebook
The headphone jack on my samung nc-10 does not work. how can i fix this problem? the laptop is only about 4 months old, so this is a huge bummer for me. (Especially since the sound is typically pretty weak...
As the sound is avaliabe with your laptop only chances are your headphone lid might not be of proper configuration try a new headphone with proper jacks
Aug 21, 2009 | Samsung NC10-14GW Notebook
My speakers and headphone jack
you need to go to http://www.hp.com and choose your computer from the laptop list clcik on help and support, next put your computer modle into the search box or have it auto detect your system, then download the drivers you need and this will fix your problem, do not remove drivers to make more space..
Jun 02, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Headphone jack not working
i just had it solved once for my frend. . wat to do is uninstall everything realted to yur sound hardware .. and get the latest updates ... from ..their site ... and install it .. it will work .. before .. doin this just try ....
1 conect the headphone
2 open the mixer .. in that there will selection of device. .. from that select headphone if it is available. ..
thnx
Nov 04, 2008 | Compaq Presario 700 470024-192 Notebook
Headphone Speaker Jack Needs Replacement
That honestly sounds more like a headphone wire problem than anything else. If you have another headset, headphones or speaker system that you can hook up, I would test it on those to try to rule that out as a problem.
If that isnt it, I can try to find the disassembly instructions for your laptop. (Unless your warranty is still good, in which case I would tell you to send it in and get it fixed professionally.)
May 16, 2008 | HP Pavilion ze4125 Notebook
Audio problem
nope it never hurts to ask as in this case it seams theres a common problem where the headphone jack has a cold solder connection on the pc board or its broken loose from the pc board itself. Now unless you get instuctions on how to open this unit do not attemt to try!! as its all plastic locking tabs and you need to know where to press to realease these tabs .. I would contact www.samsung.com or call them and see what they have to say as there is probably a flat rate they charge to fix these units
Apr 01, 2006 | Samsung YP-T8 Digital Media Player
20 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
