Question about JVC Cybercam GR-DVP9 Mini DV Digital Camcorder
I am not able to transfer the mini video tapes to a cd or store it on my lap top. JVC distributor at Dubai informed I will need a DV to DV cable connection which they dont have in stock. I am unable to get this cable even in Bangalore in India. I am forced to buy new tapes to keep using this camcorder. I have Windows Vista on my computer - will I need a special software for this. I bought this tape around the year 2001. Can the experts help solve my problem??
TTM77
  • 19 Answers
SOURCE: How to transfer the video in Mini DV to my computer
I suggest getting the PCI IEEE 1394 also known as FireWire card. Most of the time these Firewire card comes with a Video editing software but verify because you will need some form of video editing s/w to record the video. After recording then you can edit it however you like and transfer to DVD/etc. Always a pain in the as to edit video. I've done it a couple of times. So have fun. I still have not manage to find a Video editing s/w that will do a 5.1 audio or multiple audio tracks (similar to switching between languages)
Posted on Sep 06, 2006
  • 152 Answers
SOURCE: transfer movie from mini tape to computer - JVC GR-D770U
install first the bundled software with your camera turned on and plugged in to your pc and then restart your pc if its necessary..
Posted on Dec 27, 2007
kala
  • 156 Answers
SOURCE: JVC GR-D250 Mini DV Digital Camcorder Authorised service center in pune india
This model is not supporting with pc when you play cassette only it is supporting with memory stick
Posted on Feb 28, 2008
All you have to do, is make sure your computer has a FireWire card in it, and get a cable and hook it up it will automaticalty reconize the device and open up windows movie maker.
Posted on Oct 23, 2008
vortash
  • 431 Answers
SOURCE: I need to transfer video from JVC GR-770U Camcorder to my compute
Hi I am Vortash according to the manual for this unit available on http://www.safemanuals.com the unit is quite capable of downloading to a computer but yes it does require the correct software to do so .. you may find this is available from JVC support as a download .. it says that you can download to a usb terminal or a Rs socket with a compatible retail software .. hope this helps Regards Vortash
Posted on May 20, 2009
I can't figure out how to download video from my JVC GR-D90U Camcorder to my computer through it's usb cable. It is a mini DV camcorder that uses mini video tapes.
From the JVC manual "This camcorder can transfer still images to a PC via USB". There is no mention of video transfer via USB so it seems it is not supported.
Sep 25, 2011 | JVC GR-D90U Camcorder
I am trying to find that what type of cable I
depending on what connection you have on your computer. You can use usb to usb or dv to dv. If you use usb to usb it's pretty straightforward but if you go dv to dv just make sure which dv connector you have on your computer 4 or 6 pin. If you don't have a manual for your jvc , go to their website and download one. All of the info will be in there, usually towards the back of the manual. My suggestion would be if you have a dv connector on your pc you should use that setup because it is faster than usb. But if you don't have a dv connector, usb to usb is fine. Have fun.
Jun 29, 2009 | JVC GR-D270US Mini DV Digital Camcorder
JVC GR-D870 digital camera, how to transfer Min Div tape to PC
Hi, You need to use 4 pin firewire cable to connect to the PC. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | JVC Cybercam GR-D200US Mini DV Digital...
Transfer movie from mini tape to computer - JVC GR-D770U
May 31, 2008 | JVC GR-D770 Camcorder
JVC DIGITAL VIDEO CAMERA MODEL NO. GR-D370U
Hi Heidi.
Be sure your camera is on when you have connected it to your PC. Then you have to put it in Play mode and rewind the tape if it's a USB cable you connect with. Start Windows Movie Maker and test.
The following link could be useful http://www.microsoft.com/windowsxp/using/moviemaker/getstarted/default.mspx
Best regards
Estanislao
Apr 21, 2008 | JVC GR-D370 Mini DV Digital Camcorder
How do i put a tape recording onto the pc?
Unless the video is stored on the memory card you cant transfer it directly, you need a video capture device, it is an attachment to your Computer that manages the transfer of taped video copies to digital...
Dec 09, 2007 | JVC GR-D60 Mini DV Digital Camcorder
Product called EasyCap, for about 15 bucks, "can be found online" Has USB plug. Use your cable that has the 3.5 pin that goes out to rca cable, yellow, white and red. EasyCap has the RCA to USB then to computer. Use Windows Movie Maker, comes with XP & Vista, capture while playing from there. I just converted about 20 full tapes from one cannon mini 8 and 15 from a jvc dv onto a TB drive.
Nov 22, 2007 | JVC Cybercam GR-D200US Mini DV Digital...
Jvc GR-D290
Hi, Since videos are taped in DV format, you need a firewire card (IEEE-1394) and cable. These are cheap. May be your PC already has a firewire card. Just check. Windows XP recognises automatically the camcorder. Moreover, its integrated video capture/editing module, Windows Movie Maker, is very userfriendly. USB connection is only good for downloading still images (photos) to your PC. For more information, go to http://www.videohelp.com/. good luck
Mar 14, 2007 | JVC GR-D290 Mini DV Digital Camcorder
JVC Cybercam GR-DVP9 Mini DV Digital Camcorder Logo
53 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
