Question about Texas Instruments TI-84 Plus Calculator
My TI-84 will not turn on, even after changing batteries.
  • 3,083 Answers
This site might have your answer:
http://talk.collegeconfidential.com/high-school-life/522364-ti-84-plus-silver-wont-turn.html
This problem could also be caused by one of two problems. First of all, the calculator's battery contacts should be cleaned with a qtip and isopropyl alcohol. If that doesn't help, the on/off switch or copper contacts could be slightly worn or oxidized, if left setting for periods of time. It's possible to take it apart, and spray the contacts with electrical contact cleaner.
Aside from that, the unit will have to be methodically troubleshot, which is beyond most consumer's capabilities.
As a last thought, if you google TI-84 won't turn on" you will get more blogs to read, which might work.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 07, 2010
SOURCE: TI-84 plus DEAD
There is a chance there is a battery leakage and the contact is spoilt. That's what I'm facing now as well
Posted on Oct 11, 2007
  • 21 Answers
SOURCE: TI-84 Plus Calculator will not turn on, says ram is cleared
Thats because the OS is corrupt. Follow the manual and reload the OS, try the 2.43 OS
Posted on Mar 02, 2009
  • 88 Answers
SOURCE: my TI-84 plus won't turn on... even with new batteries
Could be the screen has been dimmed so much that you can't tell that it's coming on. Press on and then 2nd button and the up arrow key. You may need to keep pressing 2nd and up arrow key. This is how you darken the screen. You can also lighten the screen which may be the problem you have by pressing 2nd and then the down arrow key. This is how the contrast is controlled on your calculator
If this doesn't work, take out the internal battery that is located in a tiny door with a screw right above the 4 AAA batteries. Leave this out for about 8 hours and put it back in. Put in the AAA batteries and the calculator will be reset and may work.
Posted on Aug 06, 2009
  • 88 Answers
SOURCE: TI-84 Plus Silver Edition turns off immediately, all batteries have been replaced, but unit still turns off. I even replaced the memory battery.
You may need to reset calculator. Take ou the batteries and the backup battery. Leave them out for about 8 hours. Then put everything back in. Hopefully this will work.
  • 102366 Answers
SOURCE: My TI-84 won't turn on. If I replace the
Remove all four AAA batteries. Press and hold down the ON key for at least ten seconds. Replace the batteries. Turn the calculator on.
Posted on May 17, 2010
Repair ti 84 plus silver edition
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. Does it?
Feb 13, 2014 | Office Equipment & Supplies
Ti 84 water damage
Nov 11, 2013 | Texas Instruments TI-84 Plus Calculator
My TI-84 plus wont turn on even though I changed the batteries!
TI calculators have an annoying habit of dimming the screen, especially when the batteries are changed, so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go on from there.
Mar 06, 2012 | Texas Instruments TI-84 Plus Silver...
My ti 84 calculator doesn't work
Having received no response in over a month, I assume this is no longer a problem.
Jun 22, 2010 | Texas Instruments TI-84 Plus Calculator
I can't turn on my TI-84 plus calculator, even after changing both type of the battery
Having gone over a month with no response, I assume this is no longer a problem.
Jun 07, 2010 | Texas Instruments TI-84 Plus Calculator
May 15, 2010 | Texas Instruments TI-84 Plus Silver...
I have a TI 84 plus silver edition. Won't turn
The problem may be due a screen that is too light to see anything on it. Adjust the screen darkness.
  1. Press [2nd] key and release it.
  2. Press and HOLD the [UpArrow] to draken screen.
  3. Release the [UpArrow] when screen is dark enough.
You can also connect it to the computer to see if TI Connect finds it. If it does, update the OS to version 2.53MP.
You change the backup battery if the calculator tells you RAM CLEARED each time you turn it ON.
Dec 16, 2009 | Texas Instruments TI-84 Plus Silver...
TI-nspire will not turn on
Yes we changed out the batteries on now the TI-84 will not turn on HELP
Nov 23, 2009 | Texas Instruments TI-Nspire Graphic...
Texas Instruments TI-84 Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
