Question about Peg Perego John Deere Turf Tractor
Lots of noise from r/r wheel sounds like stripped gears real loud sqweeling , had apart gears look fine ,what do you think. e-mail mark.schon@att.net
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Bad gearbox on one or both of the rear wheels, you can order a new one here www.powerwheelsoutlet.com
Posted on Jun 06, 2012
Loud buzzing noise.
IT SOUND LIKE YOUR lamp ballast IS FIXING TO GO OUT ON YOU OR YOU HAVE SOME BAD CAPS IN POWER SUPPLY LOOK OVER TO SEE IF THAT IS YOUR CAPS BUT IAM THINK IT LAMP BALLAST
Dec 24, 2013 | Televison & Video
Kitchen Aid 550 Pro Mixer New Worm Gear and Worm Gear Follower Issue
It would be helpful to get the model number and serial number off of the bottom of the mixer. This will help determine if the gearing has changed at all.
Usually when a mixer is making a lot of noise after replacing the gears we can find a small nick or gouge in the gear. even the smallest damage can cause these mixers to make a lot of noise. Also if you have an older mixer there was a change in the worm gear from 53 teeth to 60 teeth on the gear. If your mixer originally took a 53 tooth gear, and you replaced it with the 60 tooth gear it will make a lot of noise like you are describing.
So first check your serial number, if the first 4 digits are after WL45 your mixer would have a 60 tooth gear, however if it is a WL44 or before you would have originally had a 53 tooth gear and this is what is causing the loud noise.
If your mixer is new enough that it took the 60 tooth gear, then take the mixer apart, clean and remove all gears, clean them off with wd-40 and inspect closely, even the smallest chip can cause a ton of noise.
If you have any questions, or you cannot find the problem feel free to contact us at The Mending Shed.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
We Repair Anything Under the Moon!
Apr 04, 2013 | KitchenAid New Professional 5.5 QT...
2001 Jeep Grand Cherokee makes a lot of noise when selecting Reverse. Forward gear okay. Now, reverse doesn't work and it sounds like the transmission is coming apart.
Your automatic transmission has an internal low and indirect clutch. The indirect clutch is what's used when your vehicle is in reverse. You might have a heavy jerking when you put it into gear that feels like vehicle got hit by another or loud rattling or chattering in gears. It very well may be coming apart as you think and soon, so I'd recommend taking it to your local transmission shop to inspect and test it and they can give you a more detailed idea of what it would take to fix it. good luck
Jan 07, 2011 | 2001 Jeep Grand Cherokee
Loud sqweel noise when start car.
going to be your power steering pump
Feb 01, 2010 | 1999 Volkswagen Passat
Makes a horrible noise. Seems to dry fine but before its done it sound like it going to explode.
The blower wheel may be stripped out or broken.
This will cause a loud rumble noise while operating.
Jan 16, 2010 | Maytag PYE2300AY Electric Dryer
Loud Noise
Craig,
My apologies for just now responding to this message; apparently my fixya mails have been getting caught by a filter and trashed without my seeing them.
I can think of a couple strong possibilities for this issue, and you're right; talking it through would be a good idea.
I will get in touch as you requested.
David
Apr 27, 2008 | HP Officejet 7130 All-In-One InkJet...
Indesit W11 making grinding noise
I think you have a drumbearing problem.:)
Dec 30, 2007 | Indesit W 123 Front Load Washer
Peg Perego John Deere Turf Tractor Logo
140 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
