Back to:
Tags:
Lexmark Wheelwriter 10 Series II Typewriter
posted by Wheelwriter on May 13, 2008
Our IBM Wheelwriter 10 Series II types along fine for two or three lines, then after a carriage return (either manual or automatic) it will move both margins a little to the right, and after typing for a couple of more lines it will move both margins a little further to the right. I've tried clearing all the features and re-setting the margins, but the problem persists.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 16, 2008
Not Rated (0)
DickyO
Rank:Guru Guru
Rating: 88%, 203 votes
Try a little light oil on the printer shaft. WD40 works well.
DickyO
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Wheelwriter 10 Series II:
I don't want to Accept this solution
Can you Help with these Typewriters problems?
Typewriters
The ribbon on my IBM Selectric II is not advancing - it...
Typewriters
Hi thereI use the dymo labelmanager 300. It was working...
Typewriters
I am Diploma holder in L.E.E. and Ex-Servicemam...
Loading problems.
Repair Service
Find Typewriter Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
