Question about Amprobe Non-Contact Volt Probe Product ID: VP-440
Model ac/dc 1000 amprobe. what is the c & p switch.
Continuous & Peak
Posted on Dec 02, 2010
Reduce 67 volts to 48 volts dc
Just google for voltage regulator 48 V and you have lots of solutions. Be aware of the current going through a regulator. To reduce almost 20 volts each ampere will generate 20 Watts of heat, unless you use a switching regulator.
Jul 06, 2014 | Amprobe Pm55a Pocket Multimeter Ac/dc...
Tip
How to measure the voltage on TV
Voltage measured on DC scale, black cable multitester / avometer put on a negative path or can be slipped on the silver wire in the tube that is not disposable wrapping.
Next, measure the voltages are available:
  • For 180v voltage can be measured on the positive pin elco (10uf/250v) in PCB RGB tube.stick pin red wire multitester
  • Voltage 110v for TVs 14 "-21" and 130v for 25 "-29" in the B + FlyBack Transformer (FBT), find the path there is elco 100uf/160volt. measure on a positive foot elco.
  • For 12volt voltage, please measure at the foot of the right edge of IC 7812.
  1. For voltage 5V, please measure the right foot of IC 7805.
  2. For voltage 33v, please search at the foot of VT in tuner.
  3. To measure 90v-300v, scale use DCV 250.
  4. To measure the 12v-40v, use a scale of 50 DCV
  5. To measure the voltage of 1V-9v, 10 DCV-scale use.
  6. How to measure the voltage on the yoke and in plyback is;
    • From the yoke horizontal = Fcc 110v DC, 1000 V. AC voltage can be removed with a red plug in output and in use as dB meter.
    • From the yoke pertikal 24 DC current model, except for disposable coupling C = 1 / 2 Fcc. While it could be IC 120V AC (with dB meter)
    • At Fcc FBT kolector; 110v DC, AC voltage = 1000 V..
    • At Fcc FBT filement / heater = 5V-5, 5V AC.
    • In the FBT 20-32k anode voltage V measured with 40kv HV probe is added to the multitester 1000 V. DC.
    • Voltage others depending on model and type of TV. 180v out there (for RGB) directly from the regulators, transformers, Video Amp taken from FBT.
    • There are 24V and 46v vertical FBT, also 12-18V depending on brand and type.
    • Voltage 600 V DC and focus around the screen 400v DC.
    Thus tip n trick from me (AGUS YUSTIARA ), hopefully useful.
for more info , at http://trend2download.blogspot.com
on Aug 16, 2010 | Televison & Video
I need a service manual for a amprobe 5xp-a
it does not exist.
Say what a problem is and someone may help.
May 08, 2014 | Amprobe Pm55a Pocket Multimeter Ac/dc...
I have a voltage tester and I am looking for the setting rx1 . what is the setting
rx1 setting is the Ohms reading first or 1x. You are looking for a resistance under 1000 Ohms.
Aug 23, 2011 | Amprobe Pm55a Pocket Multimeter Ac/dc...
How do i measure capacitance with my amprobe 100 test meters
You can obtain the manual here:
http://amprobe.com/cgi-bin/pdc/prodlist.cgi?tid=mlist&rvalidate=manual%3Ano
If you are using the AM-100, the instructions are here on page 6:
http://amprobe.com/manuals/AM100.pdf
Post back to this thread if you have any questions after reading the manual. Please include the complete model #.
You should _always_ discharge a capacitor before testing it! You may damage the instrument if not.
One must treat capacitors with a LOT of respect. Especially DC caps. They have been known to kill people or at least deliver a shock that you will not soon forget. Discharging the higher volt DC caps sounds like someone fired a powerful gun. Don't use a screwdriver to discharge those caps, that's why they tell you to use a 100k Ohm resistor. Grounding probes work well for discharging caps too. BE SAFE, if you don't fully understand what you are doing, don't do it.
Mar 05, 2011 | Amprobe Manual Ranging Digital Multimeter
Have A non digital amprobe ultra clamp.does not read when using clamp.Can you help.It's real old.The probes work ok.has A thumb wheel with different volt,amp scales.On the side of the scale is...
When the voltage measuring is OK, are you sure you are on the correct position for Clamp AC current measuring.
If you have some positions for DC current they may be through probes, but can not be by clamp for such an old amprobe.
If every thing other is OK, but you can not use Clamp for AC current, you may have problem in the current transformer in the clamp.
I hope that this will be helpful, because I don't know exactly how your device looks like, but some people rank such an answer with 2 thumbs, which means useless.
Jul 23, 2010 | Amprobe Non-Contact Volt Probe Product ID:...
DC Motor Amp Draw?
Its a completely different principle for AC/DC. Its similar as the more amps the more current but with AC you will have more volts and less amps whereas DC you will tend to have more amps and less voltage. Think of it like this a 12v DC car battery puts out 500-1000 amps and a typical house on AC will have a 200 amp panel with the average circuit being only 15-20amps... So dont mistake the two as DC motors are more for variable speed operation and AC tends to be more of a set speed with minimal variation. Hope this helps
Dec 04, 2009 | Heating & Cooling
What does umax astra 3400 scanner power adapter looks like/
who cares if it is the proper voltage,amps and plug. . you need a wall wart , the plastic box with two flat blades sticking out that 12volts DC center positive ,700 milliampsfor the non negatine scanner and 1 amp(1000 milliamps) for thr negative scanneer model an AC/DC adapter look around at 2nd hand stores they usually have a selestion or order online from electronics supplier
Jan 13, 2009 | Umax Astra 3400 Flatbed Scanner
Amprobe Non-Contact Volt Probe Product ID: VP-440 Logo
148 people viewed this question
Top Amprobe Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Amprobe Electrical Supply Expert? Answer questions, earn points and help others
