Question about Samsung Televison & Video
I own a samsung syncmaster t229hd and we are connecting a dvd player to it and the video is showing black and white and we want color we tried everything even mulitpul dvd players what do we do thank you
SOURCE: Sony Bravia with Phillps dvd player
It's not compatible with the Phillips DVD player. We had the same problem with our old DVD player, something about reading it.
Posted on Oct 19, 2008
SOURCE: DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
Posted on Nov 29, 2008
  • 9 Answers
SOURCE: black and white grainy output to new samsung lcd
Your DVD player is using a PAL or NTSC variant which is not supported by your display. Somewhere hidden in the depths of the options in the DVD player should be an option to change the composite output type.
Posted on Jul 07, 2009
maatmartin7
  • 1210 Answers
SOURCE: my plasma, lcd tv only shows in black and white
Would you say say the color is intermittent, sometimes black and white an occasionally flashes streaks of color? The small signal board may be at fault. You can ask to have the board replaced or fix it at the component level. Parts for the board at component level could be PN#823827736071 location 1H00, this is i beleive a color crystal, and two capacitors , PN#223886975478, location #s are 2H08 and 2H09. This repair is very prettymuch the repair you will need. Theses are surface mount parts and will require a tech to do. Hope this will give you a good start for repair!!!!!
Posted on Oct 19, 2009
MLFnet
  • 328 Answers
SOURCE: Sony Bravia 40
If you plugged the yellow wire from your DVD player into the "Y" input of the TV this is to be expected. Please refer to http://en.wikipedia.org/wiki/Component_video for information regarding this.
You need to either see if the DVD player has component out, or see if there is a "Video-in" (that's yellow, not green in color) on the back of the TV and change to that input instead.
-=/ MLF /=-
Posted on Oct 20, 2009
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
A flat screen tv had to replace a tv that went out now there is no color only black and white will show from the vcr/dvd player what is the fix?
You need to set the tv for the standard set on the dvd (NTSC or PAL). If it's not helping, change the connection between the 2 devices (S-Video or RCA jack).
Mar 06, 2011 | Samsung DVD-VR320 DVD Recorder/VCR
Subject: Trouble shoot Samsung Synmaster 151 MP LCD monitor Hello, I have a NTSC compatible DVD player, (pioneer DVH-P7000) linked, pictured communication via S-video to the sumsung LCD, also NTSC. It is...
S-Video connectors have separate luminance (B&W) and chrominance signals.
Your symptoms are those of a bad connection on either pin 2 or 4, those responsible for chrominance signals. Check the connections and the cable. Try gently wiggling the connectors when the image is displaying. A flash of color imagery indicates that it is indeed a bad contact, hopefully in the cable (which can be replaced cheaply).
http://en.wikipedia.org/wiki/S-Video
Nov 02, 2009 | Samsung SyncMaster 151 MP (Silver) 15" LCD...
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Show movies in black and white no color
unit is in a progresive mode. need to turn back to interlaced.
Jun 01, 2009 | Sony DVP-NS575P DVD Player
My tv shows are taping in black and white
if you have the dvd's s-video plugged in and also something plugged into the yellow video input this will happen , does the piture on the tv show black and white?
otherwise the vcr head is dirty and needs to be cleaned
please rate a fixya and I'll be happy to even assist you further
electech
Nov 07, 2008 | Samsung DVD-V2000 DVD Player/VCR
I have a samsung 32 inch LCD HDTV and trying to hook up to Pioneer DVD player. There are three colors of wires to connect the DVD to the TV. I get the sound(audio) but not the video. It just shows black...
Just make sure you hook up the wires to the correct plugs. They should be colr coded - red and white for audio and yellow for video. The sockets on the TV will have the same color code. If not, its just a matter of trying various combinations. If nothing works, then try using a different cable.
Sep 26, 2008 | Televison & Video
Sony dvp ns50p dvd player
If you are using the s-video jack to connect the DVD to the TV, the jack could be loose or the wire could be bad. The s-video cable has 2 signals, the black-and-white (luminance) and the color (chroma). If the chroma signal is not getting through, the picture will be in black and white.
Sep 01, 2007 | Sony DVP-NS50P DVD Player
Black and White
There some thing that you had done to get black and white on your tv with the dvd ,check your connections.if the connections are properly connected then the tv could be having a problem in the video input, have a tech look at it.
Apr 03, 2007 | Zenith C13A05LG 13" TV
Dvd showing in black and white
I'm assuming you're using the yellow ended video cable and two audio cables hooked up to your TV to display the signal. If so, I would just make sure they are connected in the correct output jacks on your dvd player and that they match up with the input jacks on your TV. If so, then I'd try another DVD player to see if that one plays OK.
Jan 13, 2007 | Samsung DVD-P230 DVD Player
Televison & Video Logo
37 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
