I wired up my replacement fasco motor for my condenser fan and it ran for maybe 30 mins and shut down. It was very hot and wouldn't come back on until it cooled down. I wired it like the dealer told me, but I wish I had a diagram. Model no.D5458
  • 76 Answers
Tough to answer without more information. Most likely the speed of the motor is too fast for the fan which causes unnecessary load on the motor causing it to overheat and shut off. Likewise the motor could be underpowered causing the same thing. I would bank on speed. The squirrel cage blowers have speed limits and won't go any faster regardless of how fast the motor can turn. Check the speed rating on the old motor and compair it to the new one.
Posted on Sep 07, 2010
  • did ya no Feb 12, 2011
    Could be your "run" winding capacitor.
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
Refrigerator wont run. Clicking noise coming from main board preceded by a short humming noise every several seconds. Unplug for 30 minutes then plug back in and compressor starts up after several clicks...
That condenser fan motor needs to be replaced. You and doing the right thing as far as using a seperate fan to keep compressor cool,buy replacing the fan the compressor will run cooler and click off by being too hot as you have heard/seen.
Find your model number and call your local appliance parts store and see if they have a CONDERSER FAN MOTOR in stock
Gene
Aug 15, 2011 | Refrigerators
The electric radiator fan runs after truck is shut off. Will turn off after 30-40 min. Is this normal?
no it is not normal....have a repair shop check the coolant fan sending unit or the coolant fan relay...a bad sending unit maybe sending a false overheating signal to the fan causeing it to stay on or the on off fan relay maybe sticking on..an make sure the jeep is not actually running hot the temp guage maybe reading the wrong temp
Jul 15, 2011 | 1998 Jeep Cherokee
The capacitor was bad and was replaced. now the system will work fine for about 30 min then the fan the outside unit will stop working. it sounds like the compressor is still on and cold air is will...
Yes, if you changed the three post capacitor that runs the fan and compressor, and the fan is still getting hot and shutting down until it cools off, you may have bushings out of the motor or an internal short. Sounds like you have a job ahead of you of changing your condenser motor. If you do this yourself just contact me I will step you through it . Mark
Jul 10, 2011 | Goodman CLJ36AR42 Air Conditioner
Cooling fans on aztek no coming on, ran hot wire to fans and works. checked fuses, jumped wires at temp. sensor and fans ran after shutting ignition off for aprox. 30 seconds, replaced temp. sensor and...
there are 4 steps to check and you've mentioned all but one the relay which cuts the fan on'off. At an elec shop you check in this order power to fuse block, fuse & output side, temp sensor, relay, and fan motors. Get a new relay
Apr 28, 2011 | Pontiac Aztek Cars & Trucks
I have a all in one or complete unit the fan motr
hopefully you replaced motor with the same Rpm HP Volts and made sure the rotation of fan was correct.. Might have a bad/defective motor I would take it back to whomever you purchased it from as the should exchange it. Good Luck
Jul 21, 2010 | Heating & Cooling
Stops cooling after a few mins
Check the condenser fan motor It probley has bad bearings and over heats and shuts down
after 15 or 20 min of run time
Jul 25, 2009 | Heating & Cooling
Fan motor runs for awhile and then runs hot and shuts off
Bearings in the motor may need oiling. look for a tiny funnel hole on a tube on the ends to oil it. Remove power first.
If none it could be permanently sealed and need to replace the motor.
Let it cool before touching anything. again remove power first.
Jul 06, 2009 | Heating & Cooling
I live in south texas overnight the ac stopped GOODMAN MODEL
Is the condenser fan (outside) turning? You mention that it's hot but don't say if it's turning or not.
These fan motors normally run pretty hot, but not so much that they shut down due to internal thermal overload protectors.
Both the compressor and the fan have termperature overload protectors to keep them from burning out the motor in the event of an overheated condition. The condenser fan must be running or high freon pressure will put an excessive load on the compressor and it will 'kick out' the high-temp overload protector.
Turn off the unit by pulling the outside disconnect (in a small box near the outside compressor unit) or flip the AC breakers in the breaker box. Wait about 30 minutes for the unit to cool off and turn it back on. If the compressor and fan both run for awhile then kick back off, or the fan motor seems to be working under excessive strain, you've probably got a bad motor start condenser (inside the unit) that little round can that is connected through the fan motor wiring. If it's swollen or leaking, it's almost surely defective and even if it's not, excessive load on the motor is a classic sign of a bad start condenser.
You can usually find these at electrical supply stores, well-stocked hardware stores, or most certainly at an HVAC parts house. Be sure to replace the old one with one of the EXACT same value (in voltage and Microfarads (mF) capacity. The shape may be a little different, but as long as the electrical characteristics are the same and is rated at the same or higher voltage than the original, it will work.
Connect the new condenser, mount it to the frame, and restart the unit. This should take care of the problem.
Hope this helps.
Jun 28, 2009 | Heating & Cooling
Heating & Cooling Logo
151 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
