Question about Canon PIXMA iP3000 InkJet Photo Printer
My pixma ip3000 wont turn on
My Canon Pixma IP3000 was working fine and then one day just shut off and is not turning back on. I have tried different outlets, making sure the power cable is snug, and nothing works. Is there a way to fix this?
  • 1 more comment
  • JOJOtx32 May 14, 2008
    My printer has been working fine also. I used it one day and later that day went to use it and it just acts as if there is no power to it. I have pulled out the power supply box and made sure everything was pluged in good, etc.
  • stocky54 May 25, 2008
    I got the same problem about 2 weeks ago & I've had my IP3000 for about 4 years & had it serviced once. I love the printer & don't want to get rid of it.
  • Anonymous Feb 09, 2009
    This same problem appears under several headings, a more technical version here: http://www.fixya.com/support/t282792-che.... So freetek, here's your chance at a FixYa! (4-star) rating:
    Tell us if the voltages observed are normal, or does the absence of a voltage across the black and yellow wires mean the bad cap problem has done in all of our psu's?
  • Canon Master
  • 5,568 Answers
This sounds suspiciously like a problem chronic to a certain type of power supply called a 'switcher' that uses a technique that employs high frequencies in the power conversion process and is caused almost always by the use of cheap capacitors in the path of high frequencies. The value of the capacitor shrinks from decay of the electrolytic solution used in these parts.
Currently, there are millions of these parts in circulation with a defective solution (poorly made in China) used in their manufacture causing failures in many different electronic devices.
The typical symptom is either a failure to turn on when powered up or simply stopping.
It is a problem that was endemic in certain fax machines in the 90s and since they were more expensive then, it made sense to remove the supply and repair them.
Quite frankly, this weakness earned me thousands of dollars as a sideline and once I had established the failure mode, I added a 50 cent part then could guarantee the repair for the 'life of the machine' and never had a single return out of many hundreds of repairs.
Unfortunately for owners, is the need for a capacitance meter to locate the faulty part and they cost more than a replacement printer.
If anyone has the instrument, the technical skills, and wishes to 'try this at home,' email me and I will detail what to look for.
freetek@lycos.com
Posted on Jun 10, 2008
  • 1 more comment
  • Steve Allison
    Steve Allison Jan 14, 2011
    Due to a direct email request on this pretty old thread, I'm adding the comment I sent to Chris N.
    It's gratifying to see an old post still benefit someone.
    I would definitely try replacing those caps; the cost is not prohibitive even if they must be ordered in.
    Go to Mouser.com and look for parts rated for both low ESR and switching service or at least the latter.
    I recommend Mouser since they do not have a minimum and charge actual shipping cost.
    They were founded by a SoCal teacher who wanted a source of parts for class work; there wasn't any who wanted that kind of business so he founded one.
    Good luck-
  • John Pendleton
    John Pendleton Dec 05, 2013
    What is ESR? What parts am I looking for and how do I get at them?
  • Steve Allison
    Steve Allison Dec 05, 2013
    ESR = Equivalent Series Resistance - it's the part of the losses of a capacitor that aren't capacitance but act like resistance. and is expressed in Ohms; the lower this value,the better and should be rated at some specific frequency and is higher in quality caps. 1 KHz (1000 cycles) isn't high enough for parts used in switched mode supplies.
  • 3 Answers
Try this - it worked for me: Go to control panel, click printers & faxes, delete all queues and restart computer - press power on printer.
Posted on Apr 27, 2009
My cannon ip3000 will not turn on, no light appear, I have tried changing the cord and different wall sockets
If you have tried multiple cables in multiple working outlets then you need to contact the manufacturer for warranty or return it to the store.
Aug 21, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
I've just replaced the black ink cartridge on my Canon Pixma IP3000 but it is not printing - absolutely blank. However the colour cartridges are printing fine. Any clues?
Assuming a windows computer ... go to the printers section, right click on the IP3000, click on propterties then the maintenance tab. Try cleaning or deep cleaning and then nozzle check.
Feb 01, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
My printer power wont turn on when i press button
Try removing your printer cartridges and then the print head from the printer. If the printer powers up with the print head removed, then the print head is either shorted or clogged. If it's shorted out then you will need a new print head (usually cheaper to just buy a new printer). If you can clean the print head without damaging it, sometimes it will work again. Usaully a good 24 hour soak in alcohol or a cleaning solution will work.
May 09, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 inkjet printer- print head is overheating
Try to remove the print head from printer and turn it on.If starts you need to replace the print head.It's part number is QY6-0064 becouse the old print head QY6-0034 is discontinued.
Oct 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My canon inkjet pixma ip3000 says it has no paper when it has. It has worked before but now it just says paper out when i try to print.
this i think is simple. you put the paper on wrong. it sometimes happens to me on me printer. look at your operating manuel to see how to properly put on the paper
Oct 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Service error 5200 on a cannon pixma ip3000
i have the same problem using nero cover designer
it's very slow quality is ok but at 1/4 of the page it gives me the error message....
PAT
Mar 22, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
IP3000 WILL NOT PRINT BLACK
Try Start --> Control Panel --> Printer and Faxes
Right click on the printer --> slect Properties
Look for maintenance and try "clean" or "Deep Cleaning"
If you cannot find "Maintenance" look for "Tools"
Jan 13, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
1,673 people viewed this question
old marine
old marine
Corne Viljoen
