Question about Panasonic Audio Players & Recorders
How to connect traditional speakers to a receiver/component that is set up to connect 4 satellite speakers and a sub whoofer
  • 152 Answers
? what's a traditional speaker?
Posted on Sep 07, 2010
Please tell me all the connections on movie star 60+
Each of the five satellite speakers connect directly to an AV Receiver that you buy a separate device.
Here's the back of the sub. The sub either connects to the LFE Sub Out from the receiver to the white RCA/Phono Left Input. Or you can use speaker connection cables, AV Receiver front L & R to Speaker Level Inputs, and then Speaker Level Outputs to the front satellite speakers.
Aug 16, 2014 | Wharfedale Audio Players & Recorders
Why does my MCS sub 10 not turn on?
Is that the right part number, MCS 10, and not MCS100?
The MCS systems use a basic sub which is matched to the satellites. There's very few controls other than level on the MCS100. So as long as the power light is illuminated the there's very little other than the volume control that could be set wrong on the sub. So what it comes down to is either
  1. a blown fuse (no power at all at the sub);
  2. a broken input (#1 cable, #2 sub input socket, #3 blown sub plate amp);
  3. incorrect connection at the receiver end or the wrong settings
As a quick test, unplug the sub cab from the amplifier/receiver end. Switch on the sub and turn the volume down all the way. Briefly put your finger across to short the RCA/phono tip and ring. The sub should make a buzzing sound. You now know that the sub is working and the cable appears to be okay
Switch off the sub and reconnect the phono/RCA to the sub out socket on the receiver. You now know it is connected correctly.
Go in to the receiver's menu and check the speaker settings. Is subwoofer present? Yes/No
Are the satellites all set to Small? (they should be with this system)
Are you playing a 5.1 source in DD or DTS to ensure that the sub gets a signal? Play a BD or DVD.
On the speaker balances, is the sub channel set to 0dB?
As long as all the above is set as listed, then the only things stopping the sub working would then be insufficient volume at the sub's Vol control (so increase it), or an intermittent cable connection (wiggle the cable), or a broken subwoofer out signal at the receiver.
Aug 06, 2014 | Boston Acoustics Audio Players & Recorders
I have a set of technics SB-5000a speakers. one of them the 10" sub is blown. there is no resistance accross it. the cone is in good shape so i think it is the driver. normally you can unscrew the...
if there's NO resistance, see if the lead running to the cone (coil) has broken.
If so, you might be able to solder it back on and save the speaker.
Sometimes they separate at the terminals, sometimes at the cone.
If it separated at the cone, you may need to peel back a bit of paper to get to the wire underneath, and scrape the enamel coating off the wire so you can solder to it.
Otherwise, it's off to your local audio mart to buy a 10" whoofer at the same or higher wattage and same impedance. Take the old one with you to make sure the screw holes align too! (although that's not 100% essential as you can always drill new pilot holes wherever the screw holes aare....unless the screw holes have a metal insert)
If you did have to peel back some paper to do the repair, reinforce the torn area with toilet paper and fingernail polish. Use several layers as you don't want the movement of the whoofer to rip apart your solder joint or any more of the cone.
Mar 15, 2011 | Audio Players & Recorders
Cerwin Vega SUB8...how do I connect
grady66,
We will start with the easy one, Phase. The phase selector is a setting that can be adjusted by sound; which one sounds better? Either one will work fine. It's mainly for situations where the sub enclosure is located at a distance or behind the listening area. The 'in and out' crossover selector and the input from the receiver goes together. The 'in and out' crossover selector is asking if you want to use the internal crossover to block the bass from getting to the satellite speakers. Most home surround sound receivers only have the one sub out and most subs have both left and right inputs. When there is a single signal being fed to the sub you use the subs left input or buy a splitter and send the signal into both left and right, but either way will work equally the same.
There is two ways to connect the speakers to the receiver.
1) Cross-over 'In': you connect the output speaker wires from the receiver to the speaker inputs on the sub and the speaker outputs on the sub to the satellite speakers; the sub will get its sound from the input speaker wires.
2) Cross-over 'Out': you connect the sub to the receiver using the receiver's single sub out, then connect the satellite speakers directly to the receiver's speakers outputs; in this configuration the satellite speakers are given a full range of signal including the bass.
I have used #2 with the same system and had great results.
-Chris
Jul 05, 2010 | Cerwin Vega AVS-5.1 System
Receiver cannot recognize subwoofer
As I implied earlier, take a clue from the physical style of connectors for both parts of the subwoofer function in the old and new receivers:
RCA connections are for Line Level signal between components only.
The input (bare wire) at the speaker is for AMPLIFIED signal.
You can't just modify one to fit the other and expect magic to happen. Be glad you didn't do it the other way around and modify an amplified (speaker level) outout into a Line Level input. You likely would have smoked that component.
Your subwoofer is a passive speaker, that is, like any other speaker it needs an amplifier. Many subs are self-powered (amp built-in) and they would mate well with the RCA sub output of the receiver.
Get yourself an Active (self-amplified) Subwoofer and run UN-MODIFIED RCA cables to it, according to its instructions, from the Sub Out of the receiver. Or get an amplifier between your receiver and the sub you have.
Feb 21, 2010 | Pioneer VSX-D607S Receiver
I have a HK 595 sub. with no sattelite cables.
you need the the satellite speakers hooked up in order for the sub to work. its not a standalone sub the volume control knob on the satellite speaker is what powers on the sub. i have extra speakers i wish i could give you cuz my sub just blew out.
Dec 20, 2009 | Harman Kardon HK595 Computer Speakers
Lost remote controller of Pioneer VSX-D506S
You can buy Original Pioneer Remote from HERE for VSX-D506S
Feb 10, 2009 | Pioneer VSX-D506S Receiver
Home theater system protection kicks out
Nice write-up.
http://www.sherwoodusa.com/pdf/RD-6500(English).pdf
On page 6 of the manual it states you should use a powered subwoofer and the unit provides a sub output on the rear panel for it. The message from the amp kicking out is that you're not going to get away with your workaround.
I would advise you to purchase a nice amplifier (2-channel bridgeable or single channel) for the subwoofer. That way you'd be sending only LFE signals and your receiver has provisions for adjusting its volume relative to the rest of the channels. I use a nice 5-channel Carver for my 3 subs and both Rear Surrounds.
On eBay I see what I would get if I were you - a Carver M-200T (120W x2; 300W bridged). I have one.
http://cgi.ebay.com/Carver-Magnetic-Field-Power-Amplifier-M-200t-120WPC-Amp_W0QQitemZ200327110781QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item200327110781&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A1%7C39%3A1%7C240%3A1318
Mar 02, 2008 | Sherwood RD-6500 Receiver
JVC RX-809V
Go to the following website www.servicemanuals.net where you can get the service manual for $17.00, unbelieveable, don't you think? The service manual should help you sort out your hookup problems. Good luck.
Jun 10, 2006 | JVC RX-818V Receiver
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
