Question about Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive
Dont remeber my password
I bought an acomdata hard drive and havent use it for a while I try using it and realized I had a password on it I have tried my best with all the passwords I know and still cant get it to open, at this point I dont care if I delect everything I have on it and be able to transfer my other files from my computer to it.
I need help
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 268 Answers
It is always best to include the OS in the post which would be more easy for us to give the instructions.
In this case you can format the hard drive.
Formatting the Drive
in Windows 2000 or XP
1. Disable any anti-virus software you may have running in
the background.
2. Double-click on My Computer/Explorer. In the My
Computer/Explorer window you should see the icon and
drive letter for the AcomData Drive.
(If you are not sure which drive letter represents the AcomData Drive, turn it off and see which one of the icons disappears. Then turn on the Drive and wait for the drive letter to reappear.)
3. Right-click on the drive letter and select Format… in the
pop-up menu. The Format dialog box will appear.
4. Under Capacity, verify the Drive capacity. It should be
close to the stated capacity of your Drive in gigabytes.
5. In the File System pop-up menu, select NTFS. As NTFS file system is more secure than the FAT32 or FAT.
6. In the Allocation unit size pop up, select “Default alloca-
tion size.”
7. In the Volume label field, type in a name for the Drive. You
should give the drive a unique name that will allow you
to easily distinguish it from other hard drives or storage
devices.
8. The default formatting option is Full format, however
under Format options you can select Quick Format. A
Full format will take about 30-90 minutes.
A Quick format will take just a few minutes, but will do less verifying of the Drive than a Full format will. Do not check Enable Compression.
9. Click Start. Once the format process is complete, the Drive
will be ready to use.
in Windows 98SE or Me
the background.
2. Double-click on the My Computer icon. In the My
Computer window you should see an icon and drive let-
(If you are not sure which icon represents the Drive, turn off the Drive and see which icon disappears. Then turn the Drive back on and wait for the icon to reappear.)
3. Right-click on the drive letter and select Format. In the
Format window, verify the Drive’s capacity; it should be
close to the stated capacity of your Drive in megabytes.
4. Under Format type, select Full; everything else should be
left at the default setting. In the Label field under Other
options you may assign a name to the Drive.
You should give the drive a unique name that will allow you to easily distinguish it from other hard drives or storage devices.
(The name you assign is limited to 8 characters and no
symbols are allowed.)
5. Click Start. The following warning message will appear:
“This device is either a hard disk or a large removable
disk.
Formatting it will destroy all files currently on the
drive. Are you sure you want to format this drive?” If no
data was previously written to the Drive or you already
backed up the data you wish to keep, click OK.
6. If you see a warning from an antivirus program, click
Exclude.
7. When formatting is complete, you will be asked to run a
thorough Scandisk. Periodically running Scandisk is a part
of regular hard drive maintenance. If you do not wish to
run Scandisk at this time, close the Format window.
in Mac OS X
the background.
2. Launch the Disk Utility application (Applications folder >
Utilities folder > Disk Utility). The Disk Utility window will
open with a small window at left and a larger window
with a series of tabs at the top.
3. You should see the Drive listed in the left window. Click
on the Drive to highlight it. Information about the Drive
will appear in the Information window.
4. Click on the Erase tab. In the Erase window you will see a
Volume Format pop-up menu and a Name field.
5. From the Volume Format pop-up, select Mac OS
Extended. (With Mac OS 10.3.x or later, you have the
option of selecting Mac OS Extended (Journaled).
(Journaling is a feature that helps protect the file system
against power outages or hardware failures, reducing the
need for repairs. We recommend using journaling, if avail-
able.)
6. In the Name field, type in a name for the Drive. You
devices.
7. Click Erase. You should see an alert pop up with the mes-
sage: “Erasing a disk will destroy all information on all of
the volumes of the disk…” Click Erase.
Once initializing is complete, you should see the Drive listed
in the left window of the Disk Utility screen with whatever
name you assigned. Quit Disk Utility. You should now see
the Drive icon on the Desktop.
in Mac OS 9
Before you can re-format the Drive you will need to restart
your computer from the Mac OS 9 System Software CD that
came with your computer or which you purchased as an
upgrade.
the background.
2. Insert the System Software CD into your CD drive.
3. With your AcomData Drive connected and powered on,
restart the computer and hold down the C key while the
computer is starting up.
4. You will see the alert message: “This disk is unreadable by
this computer. Do you want to initialize this disk?” Click
OK.
5. In the Name field, type in a name for your Drive. You
devices.
6. From the Format menu, select Mac OS Extended.
7. Click Initialize. You should then get the alert message:
“Initializing will erase all information on this disk.” Click
Continue. Once initializing is complete, you should see
the Drive mounted on your Desktop with the name you
assigned.
8. Restart your computer and eject the Mac OS 9 CD, or go
to Control Panels--> Startup Disk and select the comput-
er’s startup disk. Restart the computer.
Good Luck.
Live, Love, Laugh.
Posted on May 14, 2008
I cant recall my password ...what can I do ?
You need to reset the hard drive, this will erase all files.
Jan 10, 2017 | Computers & Internet
How do i unlock a proscan plt8816k if i dont remeber the email and password?
Your problem doesn't make sense. You cannot try the password too often. Try a factory/hard reset.
Google search "reset android tablet"
May 10, 2014 | Proscan Recertified - PLT7035 4GB NAND...
What is the model number (and Windows 7 driver) for Acomdata external hard drive serial number AC07111300220
  • 1Connect the Acomdata external hard drive to your computer through the USB cable that came with the drive.
  • 2 Click the "Start" button on your computer screen and then click on the "Control Panel" tab.
  • Sponsored Links
  • 3 Click on the "System" button and then click on the "Automatic Updates" tab if you are running the classic view. If you are running the standard view, click on the "Performance and Maintenance" button and then click on the "System" tab.
  • Read more: http://www.ehow.com/how_6880582_troubleshoot-acomdata-external-hard-drive.html#ixzz345dOHa31
    got it by just searching and a whole buch of solution came
    May 05, 2014 | Acomdata Computers & Internet
    Trouble with my Acomdata external hard drive and my mac
    Unfortunately it seems that Acomdata is no more on businness.
    In order to get support you can try writing an email to techsupport@acomdata.com
    Feb 04, 2013 | Acomdata Computers & Internet
    Forgot my buffalo external hard drive password even with passwd hint still cannot remember it
    and can tell you this , just relax when you are prompted for the password , try not to think about it so much it
    will come to you , there's not much one can do for a lost password but to remember it .
    Jan 11, 2010 | Acomdata PHD060U2E-54 60 GB USB 2.0 Hard...
    I/O Error on Acomdata External Hard Drive
    Go into Control Panel/System/Device Manager and look for yellow exclamation marks. Delete any you find. Reboot your computer. Connect the external hard drive and turn it on. Let Windows discover it. If it asks for the driver, put in the CD that came with the drive.
    If this will not works means there is some problem in your HDD partition and you need to format them...
    if you donot want to lose any data then use any recovery software to recover data from your HDD.
    Good Luck!!
    Thanks
    Oct 14, 2008 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
    Password issues on new laptop
    have you tried to do it in the SAFE mode, I've had to fix alot on my Vista which all have been done through the safe mode and no problems so far
    Sep 06, 2008 | Acomdata PHD060U2E-54 60 GB USB 2.0 Hard...
    If the password you forgot is the user password, reinstalling the operating system will help you. If the password you forgot is the bios password(one which should be entered before boot up), you could reset it by removing and resetting the button cell present in the mother board.
    May 13, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
    Forgot Acomdata External Hard Drive Password
    Did you every get this resolved? I have same probelm.
    Apr 08, 2008 | Acomdata PHD060U2E-54 60 GB USB 2.0 Hard...
    Acommdata 250 problem
    I forgot my password and have tried everything I know andstill cant remember it, and i need help. Dont mind if i have to delect everything I have on the hard drive and reinstall it again.
    Can anyone help me please
    Mar 25, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
    Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive Logo
    166 people viewed this question
    Top Acomdata Computers & Internet Experts
    Jerry Umali
    terminalcon
    Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
