Question about LG WM-2277HW Front Load Washer
Machine stops running and LE appears - LG WM-2277HW Front Load Washer
  • 122 Answers
LE error code if for your hall sensor or rps sensor, replace sensor
Posted on Sep 07, 2010
  • richardv88 Apr 21, 2011
    DON'T Buy a sensor..don't call a repairman...the FIX for the LE Error is easy!!! Turn the drum 4-5 times to resettle the load, set spin speed to highest, Speed Wash, Quick Wash. Hit the start button and you are good to go. I've had to do this 6-7 times in the last 5 years. Repairmen want to sell you parts and LG wants you to buy a new washer.
Le error code
The error code "LE" appears after an unsuccessful attempt to fill the drum with water that results in the water level being too low to safely begin cleaning. The product manual suggests calling for service, but there are several steps you can take to try to resolve the issue at home.
Read more: http://www.ehow.com/info_8696564_maytag-washer-repair-code-le.html#ixzz2zXrmqUO5
Apr 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
Drum starts to move then stops then Le appears and a slight hissing noise from direct drive motor. Looks like intemittant fault
The LE error message means "locked motor error" which means the control is not seeing the motor running.
The problem can be caused by a broken wire or loose connection but the most likely cause of the problem is a bad hall sensor.
The sensor can be accessed by removing the rear panel and the rotor assembly. See the image below for help with this. Remember to unplug the washer first.
Make sure the rotor and drum rotate. Anything blocking the tub rotation might trigger an LE code.
Aug 11, 2011 | LG WD-1080FD Front Load Washer
LG TROMM Direct Drive WM0642HW when filled and started LE light comes on and machine stops, why. how do I reste or fix
LE is for a overload error. Do the following:
1) Unplug machine
2) Drain machine
3) Open machine and rotate barrel clockwise 4 times and counter-clockwise 4 times
4) Plug in, power on, and run regular cycle
Feb 27, 2011 | LG Washing Machines
What does code LE mean? The washer stops and LE appears
Code LE signals an overload to the motor. Wait 30 minutes and restart the cycle. If the code is not released, you need to call a service technician.
Jan 07, 2011 | LG WM2487H Front Load Washer
Le comes up and stops cycle
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jun 28, 2010 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LE Tromm Washing Machine
i think you mean LG Tromm washing machine ... and the error code is LE ... thats a common failure with this machine .. often its cause by a defective " Hall effect sensor" this is used to detect the position of the wash basket ... if you are handy with tools then you can change it yourself at low cost ... but it does require removing a big bolt, the spin basket and several small bolts ... not difficult for a mechanic but probably more than aunt martha would want to tackle .. the URL listed below will give you good information on how to do that job ..
http://www.howtomendit.com/answers.php?id=28214
Aug 18, 2009 | LG WM2688HWM TROMM SteamWasher
LG WASHER WM1832CW HAS LE ERROR MESSAGE
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
Jan 15, 2009 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
210 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
