Brand new laptop (compaq presario CQ62).apparently i am hitting something on my keys to cause it to switch to "key lock".i don't know why? or how? and do you think i can uninstall windows 7 and reinstall a windows xp program? i'm mechanically challenged (that is putting it mildly) and can barely operate my own toaster,so any help will be GREATLY appreciated. thanks a bunch! me. :-)
  • 1,679 Answers
You dont need to uninstall Windows 7 for this issue.
Usually the Key lock is enabled or Disabled if
1. You have pressed or if you hold the SHIFT key for long time ( usually 2-3 seconds )
2. If you tap the SHIFT Key twice, you will find the window to enable or disable the key lock.
Posted on Sep 07, 2010
How to fix compaq presario cq62-400 system disable error 55213902
when does this error happen
1: boot black screens before the windows login screen.?
2: after boot and login, and disktop shows.?
3: does it only happen running apps. or running IE11.
4: only doing what? fill in the blank here _______?
but this PC is 10 years old
and needs a new RTC coin cell.
and you need to run HDD tests, if it dont boot.
terry's link above is correct one to real HP.
and very good.
but COMPAQ facts are hard to find today.
this old.
is this a BIOS password screen , showing system disabled, if yes that is only cured by direct help from HP ,they have a magic back door password
for all old PC by them (HP/compaq)
next time show a photo of errors, 10x more easy.
to answer....
Mar 23, 2018 | Compaq Computers & Internet
Need a new product key
Please let me know what product key you need.
Mar 06, 2014 | HP Compaq Presario XG958UA CQ62-410US...
Keys not working
Either the keyboard or the ribbon cable connecting the keyboard to the mainboard is damaged or not fully connected.
The most likely problem is the keyboard is defective. They are not very hard to replace. In most cases you have to remove the button cover above the keyboard and then the screws for the keyboard will be accessible. You can get a new keyboard off the Internet (EBAY or such) or direct from HP.
Aug 22, 2012 | Compaq Presario CQ62-112TU
How do I connect my laptop to a projector
After connecting the video cable to you laptop (of course), change the display mode of your laptop to "Duplicate" or even "Projector Only" mode by holding the "Fn" key and selecting the display mode key which may be "F8" for you.
May 05, 2012 | Compaq Presario CQ62-112TU
Presario cq62 keyboard not working
Hook a external keyboard to make sure it is working, if yes! the laptop keyboard will need to be replaced.
Mar 17, 2012 | Compaq Presario CQ62-112TU
Keyboard has a padlock image on a key. what is that?
press FN (function key) button plus closed padlock -- it will lock keyboard -- to unlock press FN key + open padlock
Oct 23, 2011 | Compaq Presario CQ62-215DX Laptop
My compaq presario cq62-238dx felloff my hands, no scratches or damages are visible, when I first turned it on it worked as if nothing would have happenned, but later on the screen turned pink, the next...
I suggest you start diagnosing by using an external monitor, if available.
A VGA monitor.
(It can be a VGA monitor that looks like a small TV, {CRT}, or an LCD flat screen that has a VGA cable attached.
More information on VGA connectors,
http://en.wikipedia.org/wiki/VGA_connector
Laptop off, and VGA monitor off, connect the VGA cable of the monitor to the Left side of the laptop.
(Rear top port)
Turn the monitor on, and then the laptop.
Do you see a display on the external monitor? (VGA monitor)
No?
Press, and hold down on the Fn key (Function Key), and tap once on the F4 key.
A) If BOTH the external monitor screen, and the laptop screen have the same pinkish display, the problem is the graphics chip. (More on graphics chip in a moment)
B) If just the laptop screen is pinkish, and the external monitor graphics are okay, the problem is inside the laptop display.
1) Could be a loose connection of the Display Panel Cable.
{The Display Panel Cable attaches to the motherboard, and the LCD screen in the laptop display}
2) Could be a bad Display Panel Cable.
Possible damage to the Display Panel Cable is the the laptop display was open.
Look for signs of damage to the sheath of the Display Panel cable.
However the damage may not be apparent. The Display Panel Cable could have been stretched.
(Laptop display open when dropped)
The tiny wires inside the Display Panel Cable could have become damaged.
Testing requires that the Display Panel Cable be removed.
A multimeter is used to check continuity of each wire.
{Multimeter function knob is set to Ohms. 1K or 10K if these settings are available.
The Positive probe lead (Red) is touched to a wire at one end of the Display Panel Cable.
The Negative probe lead (Black) is touched to the other end of the wire.
Analog multimeter needle swings up, you have continuity. Don't worry about the Ohm reading at this point. As long as the needle moves.
No movement? Have a helper gently move the Display Panel Cable around.
See if there is continuity shown, or is intermittently shown.
Indicates a break in the wire.
Solution is to replace the Display Panel Cable.
Same with a digital multimeter. No reading, or intermittent reading indicates a broken wire.
Display Cable Kit - HP Part Number 595196-001
I have seen several listings on the internet.
3) Could be a bad LCD screen.
Check the connections.
Check the display panel cable
If this checks out okay suspect the LCD screen.
Compaq Presario CQ62-238dx Notebook PC - Service Manual,
(Free from HP Support),
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=4252487&
Left-click on -
Compaq Presario CQ62 Notebook PC and HP G62 Notebook PC - Maintenance and Service Guide
This is a PDF file. (The computer you are using now has Adobe Reader on it, which uses PDF files)
It may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
In the Bookmarks menu on the left, click on the + sign to the left of Removal and replacement procedures.
Now click on the + sign to the left of Preliminary replacement requirements, then go on to Component replacement procedures
For additional questions post in a Comment.
Regards,
joecoolvette
Aug 19, 2011 | Compaq Presario CQ62238DX Laptop
Compaq presario 700 the keyboard seems all messed up. For example when I press G it types O, when I press S it types a period etc. What would cause this?
Hold the ALT Key and hit the number lock key, It should go back to a normal keyboard.sometimes you need the Fn + NumLk key depends on laptop
Jul 13, 2010 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
119 people viewed this question
David Payne
David Payne
