Question about Xerox Phaser 6250DP Laser Printer
How to slove the error "FP transfer roller expired" on P6250
2 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: error in xerox 6250dp of fp transfer roller expired
You need a new transfer roller.
Posted on Jan 25, 2009
I have a problem about transfer belt error 14
Error 14 is actually the transfer roller, error 16 is the transfer belt.
Error 14 is a transfer roller error and roller needs to be replaced. The part number is 059E05450 and can be ordered below:
http://www.iteminconline.com/059e05450_059e05450-xerox-6120-transfer-roller.htm
Jul 30, 2015 | Xerox Phaser 6120N Printer
HOW TO SLOVE THE ERCORE OF 000064 PLESES TELL ME SIR
composit power supply or DC controller pcb was faulty please check it.
or check all this connector on DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller,
developing assembly, transfer charging roller?
DC controller PCB (J301) <-> composite power supply PCB (J136)
composite power supply PCB (J130-7) <-> primary charging roller contact
composite power supply PCB (J130-1) <-> developing assembly contact
composite power supply PCB (FT133) <-> transfer roller contact
if all this are corrcet then you have to replace these pcb
Apr 06, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Printer displays 917.00 print error. seems to be transfer roller. changed the transfer roller same error.
The exact definition of this error is "Problem with transfer-transfer servo start error"... NOT the transfer roller. The service manual directs you to the Transfer roll service check.
The service check tests for proper operation of the HVSP, system board, and sensors.
The most likely cause of your problem is the HVSP ( High Voltage Power Supply ).
Change the HVPS and you should be good to go!
Feb 28, 2011 | Lexmark T640 Laser Printer
Need Help! What does the Error message "Set transfer roller" mean?
"Set transfer roller" means that the set transfer roller is missing or not installed properly. Install or reseat the transfer roller.
Mar 30, 2010 | Lexmark C500n Laser Printer
Error code e30-50 display on fp 7845 panasonic copier
Error code means that the cleaner for the transfer corona unit is not working correctly.
Oct 20, 2009 | Panasonic FP-7845 Black and White Copier
ERROR CODE E3 -50 (PANASONIC FP 7742)
E3-50 is the malfunction of the transfer wire cleaner. The transfer wire assembly is under the drum. The transfer wire is on the right. The cleaner moves back and forth. If you feel comfortable taking it out, respond. There are fine metallic wires in each slot, so don't break them
Oct 04, 2009 | Panasonic FP-7735 Black and White Copier
Lexmark t644 error code 917.00
This error indicates that there is a charging problem with the transfer roller. You could start by cleaning the contacts for the transfer roller (power off printer first). The transfer roller is the black foam-like roller under the toner cartridge. Handle it with paper because the oils on your hand could damage it. To remove it, just pry under the far left side with a screwdriver. Lift and pull to the left to remove. If this does not fix it, then you have a more serious problem. It could be one of the arms or the HVPS.
May 07, 2009 | Lexmark T642 Laser Printer
Gestetner 3225
SC401: Transfer roller leak error 1
SC402: Transfer roller leak error 2
-Definition- [B]
A transfer roller current leak signal is detected.
The current feedback signal for the transfer roller is not detected.
- Possible causes -
· High voltage supply board defective
· Poor connection of the PCU
· Transfer/separation unit set incorrectly
Jul 23, 2008 | Gestetner DSm618 All-In-One Printer
Printer problem
Your transfer roller needs replacing.
Feb 22, 2008 | Lexmark T630 Laser Printer
Xerox Phaser 6250DP Laser Printer Logo
102 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
