Question about HP w19 19" LCD Monitor
I have a mac mini which I have hooked up to a hp w19 monitor. Apple logo appears when I start it, however screen turns black and then message Input not support shows up. EdReimanis@aol.com
  • edreimanis Sep 07, 2010
    First solution did not work.
    I am presently using a PC keyboard so I do not have Option or command keys.
    What should I use instead? Sorry about the difficulty.
    Guru:
  • 632 Answers
  • 1
    Press the power button on your Macintosh computer, and select "Shut Down" to power off the device. Insert the power adapter into an available electrical outlet, and insert the opposite end of the power cable into the power port on the back of your HP monitor.
  • 2Insert the DVI cable into the DVI port on the back of the HP monitor, which is the second to the last port on the monitor. Insert the opposite end of the DVI cable into the DVI port on the back of your Macintosh desktop, or the side of your Macintosh laptop. The DVI port can be found by matching the symbol on the cable with the symbol located next to the computer's port.
  • 3Press the power button on the front of your monitor, and press the power button on your desktop or laptop.
  • Although HP are not configured for use with Macintosh computers by default, recent Macintosh models are capable of using the monitor at 60Hz, according to the official Hewlett Packard site.
    Posted on Sep 07, 2010
    • 2,841 Answers
    Are you using the proper adapter? If so thy this. Turn your Mac Mini on with no monitor attached and wait 5 minutes. Plug the VGA/DVI adapter into the Mac Mini and then connect to the HP monitor. Turn the monitor on and wait for the Mini to auto detect. If that does not work try this curtorsey of Apple.com
    1. Shut down the computer.
    2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
    3. Turn on the computer.
    4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
    5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
    6. Release the keys.
    Your computer's PRAM and the NVRAM are reset to the default values. The clock settings may be reset to a default date on some models.
    • NOT ME Sep 07, 2010
      For the Command key on a Windows keyboard use Control. The Option key on windows is the Windows key. So you will do it as such on a Windows keyboard.
      2. Locate the following keys on the keyboard: Control, Option (Windows), P, and R. You will need to hold these keys down simultaneously in step 4.
      4. Press and hold the Control -Windows -P-R keys. You must press this key combination before the gray screen appears.
    IMac G5 iSight starts up with white screen and apple logo after trying to update OS X
    When white screen appear :
    • press Command Ctrl+R then
    • Mac OS X Utilities screen Appear then
    • try to Re-install Mac OS X.
    if still face issue and need more help then follow http://www.apple.com/support/ and Apple and Mac Technical Support .
    Jul 21, 2014 | Computers & Internet
    It won't start it just has apple on screen
    hi
    try to reset your phone
    To reset i Phone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
    If i Phone won't turn on, or the display freezes or doesn't respond
    1. Press and hold the Home button for at least six seconds, until the application you were using quits.
    2. If that doesn't work, turn i Phone off and turn it on again. Press and hold the Sleep/Wake button on top of i Phone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
    3. If that doesn't work, reset i Phone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
    More resets:
    Try This:
    1. Remove Sim Card
    2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
    3. Replace Sim Card
    4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
    Also, Try this:
    1.) Shut down the i Phone 3G.
    2.) Start up i Tunes
    3.) Hold down HOME button on the i Phone 3G
    4.) While keeping the HOME button depressed, plug in the Sync cable
    5.) A message will pop up to ask if you want to reset.
    6.) Just click YES and the reset process should start.
    if this was helpful kindly vote for this answer..
    thank you
    Dec 22, 2010 | Apple iPhone 3GS Black (16 GB)
    I have an RCA L32HD31 HDTV LCD TV. I am trying to hook up a mac mini into the PC input in the back through VGA. I have a DVI to VGA adapter from the back of the mac mini to the tv and the tv responds with...
    Be sure to update all the drivers! I have installed many set-ups like that and most often, I need to do all the updates to make everything work. Sometimes HDMI is even more troublesome. If you go that route, be sure to purchase it at a place that allows returns on such items. Best Buy and Staples, are a couple that are usually pretty good about that. You might want to ask a "Geek" at Best buy and see if they have further input on this.
    Apr 03, 2017 | RCA L32HD31 32 in. LCD HDTV
    I cant get my phone to turn on everytime I hold the reset button the apple logo appears for 5 secs then the screen turns black.
    Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
    Reset
    To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
    If iPhone won't turn on, or the display freezes or doesn't respond
    2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
    3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
    More resets:
    Try This:
    1. Remove Sim Card
    3. Replace Sim Card
    Also, Try this:
    1.) Shut down the iPhone 3G.
    2.) Start up iTunes
    3.) Hold down HOME button on the iPhone 3G
    Nov 30, 2010 | Apple iPhone 3G
    Whenever I turn on my desktop the screen just stays black.
    It appears that your power supply is good, the startup chime says that the system board has passed self diagnostics. If you have a black screen then the problem is either the video card or the screen itself. Unfortunately it is very difficult to tell which one. You might try to use an external monitor. If it works, then the problem is with the LCD.
    To use an external monitor you need a Mini-DVI to VGA adapter, or a Mini-DVI to DVI adapter if your display will use a DVI connection. Either adapter is available at any Apple retailer. The connector on the back of your Imac is next to the ethernet connector, and should be the last in the row.
    Apr 27, 2010 | Apple iMac G5 Desktop
    Check Signal Cable alert comes on when I put a mac mini to sleep (and is also seen if I disconnect the ethernet cable)
    that is beacuse when the mac mini is going to sleep .it shut off all its maximum power usage parts.thats why the message appears in monitor
    Jan 23, 2010 | Apple Mac mini
    Lcd
    try rsetting the iPhone:
    Reset
    More resets:
    Try This:
    1. Remove Sim Card
    3. Replace Sim Card
    Also, Try this:
    2.) Start up iTunes
    Jul 24, 2009 | Apple iPhone Smartphone
    W19-1 turning white, with small breaks of black screen
    there is an issue with the HP monitor which you using you need to replace it
    Jul 17, 2009 | HP w19 19" LCD Monitor
    Mac Mini G4 Flickering Screen at Start Up
    Did you check the wires?  Sometimes if you pull one loose it flickers.
    Aug 13, 2008 | Apple Mac mini G4 Desktop
    HP w19 19" LCD Monitor Logo
    80 people viewed this question
    Top HP Computers & Internet Experts
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
