Question about Cell Phones
Sim card error - Cell Phones
    President:
  • 1,912 Answers
If your mobile Phone says Sim Card error...means Your Mobile Locked to the Network.You need to Unlock the Mobile...You can get the Unlock code here
http://www.theunlockarena.com/supported-phones/rs13wp7/ and Unlock the Mobile..
Posted on Dec 14, 2010
    President:
  • 1,118 Answers
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by Sim card error
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Posted on Sep 07, 2010
Card error
SIM card errors can be caused from a malfunction in the SIM card holder, or in the SIM card itself. For best help, please visit your local mobile provider store.
Thanks,
Dish Guy
May 06, 2014 | HTC Pc36100
SIM Card Error on Blackberry Curve
Your sim card is crashing you will need to replace sim card
Oct 13, 2008 | RIM Blackberry Curve 8300
Tip
There is another Solution to get out sim card error / Invalid sim card from...
How to correct sim card error / insert sim card
Procedure to follow
Step 1: Check the sim tray or sim seater to see if it it broken, if it is, replace it
Step 2: If the sim seater/tray is not broken, clean the entire terminal.
Step 3: If the sim seater/tray is not directly on the board, trace the broken led and solder it, or you replace the broken led with another sim tray.
Step 4: If it is still not working, change the battery and put a new battery, because a virus infected battery will always give such problem.
Step 5: Finally, if the problem still persist, then check the sim card and replace with another sim card if the former is bad because a bad sim card will always display such message as insert sim card or sim card error.
on Dec 09, 2010 | Cell Phones
Tip
SIM card Rejected ? orvSIM Card unaccepted?
The SIM card is the small card inside your phone that establishes the network connection. In almost all cases, your operator or service provider is the best source of assistance with SIM card problems.
Your phone may display a SIM card error message if:
  • The SIM card is out of alignment. If the phone has recently been dropped, bumped, or opened, the SIM card may need adjusting. Follow the SIM card installation instructions in your user guide.
  • The PUK (Personal Unblocking Key) code is entered incorrectly multiple times. This can inactivate the SIM card. If inactivation appears to be permanent, contact your operator or service provider for a new SIM card.
  • You have recently changed service providers. In this case, either your SIM card or your phone may be configured for your previous operator and may require reconfiguring. Please contact your current operator or service provider for assistance.
If none of the situations above apply and you continue to receive this error message, your SIM card may be damaged. Please contact your operator or service provider to have the SIM card tested and/or replaced.
on Mar 14, 2010 | Cell Phones
Insert smart sim
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.
1. Check if the sim is properly inserted.
2. Turn off mobile phone
3. Remove battery
4. Remove memory card
5. Remove sim card
6. Check the copper pins of the sim if there are dirts stucked on it
7. Ure clean cloth to wipe sim gently
8. Wait for at least two minutes
9. Gently and properly insert the memory and sim card
10. Insert the battery
11. Turn on mobile phone
13. Check if you will still recieve insert sim error
14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
Dec 09, 2011 | AT&T LG CU720 Cell Phone - Silver
When i am switching on my phon....it is written in the screen that SIM CARD NOT VALID why??
There are some possible solutions:-
1. Check that your sim card is in perfect condition by insering the sim card in any other mobile phone... If the ssame error appears then it means the problem is in your sim card
2. Check that your sim card's slot is in perfect condition by insering any other sim card in your mobile phone... If the same error occurs then it means the problem is in your sim card's slot
3. Check that you are insering your sim card correctly or not
Aug 06, 2011 | Nokia 6120 classic Cellular Phone
Tip
How to correct sim card error / insert sim card Procedure to follow Step 1:...
Procedure to follow
on Jan 19, 2010 | Cell Phones
My reliance GSM sim card is not working in NOKIA 7230. It is showing the error 44'H,ME Error and its registration is failed in the hand set. This sim is working in other handsets and other sim cards are...
All sim cards are not alike. The card that is giving you the error is not compatible with your phone. Get a new sim card from your cell service provider.
Jul 28, 2017 | Nokia Cell Phones
Sim card
Procedure to follow
Take care
Apr 13, 2010 | O2 Samsung SGH-E250 Cellular Phone
Sim error on screen
this is my phone, so i don't know when this started. but i took out the battery and sim card, reinserted it, restarted it. but only SIM error on screen.. would not go to home screen. is the sim card corrupted?
Kindly Suggest
Regards
NETRA
netrauniversal@yahoo.co.in
fci.delhi@ge.com
Jul 03, 2008 | Motorola Mobility C168 Cellular Phone
Cell Phones Logo
424 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
