Question about Bose Wave Radio
How do you adjust display brightness on a older bose wave radio without cd?
5 Suggested Answers
SOURCE: Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Posted on Oct 29, 2008
  • 20 Answers
SOURCE: Non-working CD in Bose wave radio
Try replacing the battery on the bottom of the system - alot of people miss it because you have it constantly plugged into the mains, but replacing this (somehow) re-sets the system, and 9 times out of 10 solves the issue.
Posted on Dec 31, 2008
BillB-SA
  • 2761 Answers
SOURCE: My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Posted on May 19, 2009
DigidocTN
  • 22 Answers
SOURCE: Bose Wave Radio AWR1 1W
I can tell you what to check if you know how to use an ohmmeter. But I warn you you could get shocked if you do not know what you are doing. The transformer has 3 windings, two are for DC voltages, and the other is 3V AC.Your meter can measure those using the AC scale. Next, check the voltage on the 3 terminal regulator IC. One leg will have 18V, the output will have 10V. Again please use CAUTION! Finally, the to-92 transistor Q1 is used as a 5V regulator. Check it (with power off and unplugged) for any shorts, especially base-emitter. If non of these ideas work, I would offer to buy your non working unit if you decide to get rid of it.
Posted on Jun 30, 2009
Why is my Bose radio is too dim?
The Bose Wave Radio has two brightness levels: Bright Hi (with a range of 8-15, and default of 10) and Bright Lo (1-8, default 4). The radio automatically goes from Hi to Lo when a room is darkened so the display doesn't interfere with sleep.
On recent models you can reset the defaults to make the display brighter or dimmer in both Hi and Lo levels.
1. Press and hold the Alarm Setup (Menu) button on your remote until -setup menu- appears in the display.
2. Then press the Tune/MP3 button until Bright Hi- appears. Use the Time - or Time + buttons to change the settings.
3. Go to Bright Lo- and adjust that setting too if necessary.
4. Press Alarm Setup (Menu) again to exit setup, or simply wait 10 seconds.
You're done! Note that if you set both Hi and Lo to 8, the brightness will stay the same all day and night.
Aug 21, 2014 | Bose Wave Radio
Why does my bose wave radio turns itself off every twenty minutes?
I am not sure how to fix your radio; but my wave radio wasn't working and I took it into a Bose store and got an excellent trade in for a new one. I traded a wave radio without a CD player for a new Wave radio with a CD player. I would take your radio into the nearest Bose store.
Jul 08, 2014 | Bose Wave Radio
How do you get the display light on a bose radio to stay on
Do you mean keep it from going dim in a dark room? The settings menu has "Bright Hi" and "Bright Lo" adjustments you can make in ranges from 1-8 (Lo) and 8-10 (Hi). Check your manual under the heading "The setup menu" for very clear instructions.
Jul 03, 2014 | Bose Wave Radio
Display not bright enough on Bose AWR1-1W clock radio
Yes...within a range. The display will automatically lighten and darken depending on the amount of light in the room. During the day or when there are bright lights in the room, the display will go to full brightness. When the lights go off or the room is otherwise darkened, the display will shift down to a lower brightness. You can make the "lower brightness" a bit brighter by holding down the CLOCK SET button and pressing the 'volume up' button.
Dec 26, 2013 | Bose Wave Am Fm Radio Awr1-1w Not Working...
During the day the LEDs are not bright enough to read the time. Is there an adjustment?
Actually, no. The brightness adjustment is for its automatic low-light situational dimming mode.
It's in the manual, page 18. get it at Bose.com.
May 27, 2011 | Bose Wave Radio
Bose wave does'nt display light ' can't see the time, Help
Hi
I read that if you hold down the Clock Set button and use the volume adjust you can change the display brightness.
Hope this helps with your rpoblem
Aug 09, 2008 | Bose Wave Radio
Mar 23, 2008 | Bose Wave Radio
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Feb 25, 2007 | Bose Wave Radio
Bose Wave Radio Logo
223 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
