Question about Hitachi NR83A2 2" To 3 1/4" Full Head Framer with Depth of Drive
Hitachi nailer does not sink nails completely, no matter what size nail.
    President:
  • Hitachi Master
  • 1,388 Answers
You must have broken tip or out of adjustment. Easy to check. Remove nails, and push safety against scrap air hose or rubber to absorb blow and squeeze trigger. Piston will stay in the down position until your release safety (on some models you will need to pull back on feeder sligtly). While piston is down examine the end of the driver for nice squared off tip protruding about 1/4 inch beyond nose. If no tip or looks broken, replace driver. If tip looks complete, adjust for more depth. Good luck
Posted on Sep 07, 2010
Hitachi roofing nailer shoots every other nail & doesn't sink the nails it shoots
i think you have two different problems , replace the feeder spring, and replace the oring on the driver piston. also make sure that the coil of nails is perfectly round if they are dropped or squeezed tool will not work right
Sep 11, 2012 | Hitachi NV45AB2S Coil Roofing Nailer
Bought hitachi nr90ad nail gun and it isn't firing right..what exact size nails should i get ( as in 35,33,or 30 degree nails)
Use 34 degree, paper collated, clipped head nails. They were always the most common strip nails years ago as Senco, Paslode, and a number of other nailers used them.
Jul 25, 2011 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
Hitachi NR83A2 nailer pushes next nail down
Are you using full round head nails?
The hissing indicates your O-rings are worn out and need to be replaced. This is not covered by warrenty and is common for all nail guns. Lots of kits are available on Ebay or your local Hitachi service center should stock them.
Hope this helps,
Cheers
Jan 22, 2010 | Hitachi NR83A2 2" To 3 1/4" Full Head...
Can I use paslode roundrive nails in a Hitachi NR90GC Gas Nailer
Yes, BUT the paslode Round drive nails and known to cause driver jamms due to the excessive paper used in the spacing of the nails.
Oct 27, 2009 | Hitachi Tools & Hardware - Others
Can i use any brand coil nailes in my nv 45ab2 coil nailer
Yes. Roofing nailers all use about the same size and spacing on coil nails. You will find that Harbor Freight is about 1/2 the price of Home Depot or Lowes for those nails.
-Jim
Oct 17, 2009 | Hitachi NV45AB2 Roofing Coil Nailer
It will double fire sinking second nail only half way. This happens every third or fourth shot. The nailer is a Hitachi NR 83A 3.25in. X .131
the pin pushing your nails is loose and the guides are warned .
try to change the guides and you will see that this problem will will be gone .
one last thing , make sure the coils are in good shape as it may create some feeding problems and push 2 nails at once
Sep 26, 2009 | Hitachi VH650 2 1/2" Full Head Fencing...
Need to know size nail that it shoots and do you have new lables for the gun
This gun takes 2"-3 1/4" .113" - .131" Paper striped 34 degree clipped head nails.
This is the Tool Card provided by Hitachi. Follow link:
http://www.hitachipowertools.com/product/files/pneumatics/framing_nailers/NR83AA3toolcard.pdf
Sep 07, 2009 | Hitachi NR83AA3 3 1/4" Clipped Head...
Sparks when shooting a nail
It is common to see sparks. It is metal striking metal. Although, if it sparks alot. It could be a chipped driver blade and the nail would not drive all the way. Does your sink `em?
Aug 15, 2009 | Hitachi NT65MA2 1 1/4 To 2 1/2 Inch 15...
Brad nails not in all the way
There are no adjustments on any electric stapler / brad nailer that I've heard of , only the pnumatics. The electric staplers/brad nailers only work well in softer woods
May 26, 2009 | Arrow ET200 Electric Brad Nail Gun
Hitachi NR83A2 2" To 3 1/4" Full Head Framer with Depth of Drive Logo
225 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
